BORLA
Old 02-10-2013, 11:10 AM   #1
GFORCE1320
Drives: 05 GTO
Look what we are working on- 31 Spline axles
Our latest upgrade to our product line..
31 Spline axles.
Yep, we have made a major improvement that will soon be available on Gforce axles.
You might have seen us talking about out 33 spline Outlaw axles in a few big power high end builds.
The problem with the huge 33 spline axles was the cv joint was huge and you had to clearance the control arms to get them to fit properly.
What we needed was a larger axle bar that would fit in a standard 930 style cv housing.
There were a couple options available from a couple sources but we didn't like the fact that they were based on a standard cv star and sacrificed strength as the axle bar got larger.
So what we did was we designed and manufactured our own.
We used FEM modeling to show us where the weak areas were on the standard cv stars and then we added material to every aspect of the cv star to make it stronger, added over a 1/4" of spline engagement area and also made the new cv stars out of a really strong aerospace material that has even better impact shock load ratings then 300m.
We will also be coating our new cv stars in a special Maganese coating that you find on high end firearms to give it better surface lubricating properties.
Our new cv stars will be machined right here in house on our cnc machines.
Take a look at how our new cv stars dwarfs the standard 28 spline and even the 30 spline cv stars.
(28 spline on left, 30 spline in middle and our new 31 spline on right)
Here is a photo showing the stock axle on the left, a 28 spline axle, a 30 spline axle and then our new 31 spline axle on the right.
By designing a larger splined cv joint, it allows us to use a considerably larger and stronger axle bar.
Our new 31 spline axle bar is HUGE!
Preliminary testing has been done on these axles in our shop car.
We will be also testing the new axles in a couple of Camaro's over the next few weeks.
Production is in full swing so start looking for our new 31 spline axles being available in the next few weeks.
We can also add our 300m cages to this combination to make a bullit proof combination.
Give us a call if you have any questions.
Thanks
Chris
GFORCE1320 is offline   Reply With Quote
Old 02-11-2013, 06:41 PM   #2
StephenS_84
Drives: 2011 2SS/RS
I'll place my order once you have these in stock.
StephenS_84 is offline   Reply With Quote
Old 02-11-2013, 09:25 PM   #3
GFORCE1320
Drives: 05 GTO
Sounds great!
We are machining a batch of 50 right now.
Thanks
Chris
Old 02-12-2013, 02:24 PM   #4
TornadoSS
WICKDSS
TornadoSS's Avatar
Drives: 2011 1SS/RS IOM LS3
Looked great the other day when I stopped in there. Nice and stout.
2011 IOM SS/RS, M6. Look up our all generation Camaro club website at Heartland Camaros
Gforce Engineering Drivetrain, ECS 1500 Supercharger, TSP Cam, Alky Controls Meth single nozzle. 91 octane, 698 RWHP 625 rwtq. 4200#+, Tuned by Justin "Justune" Kalwei
11.57 @ 126.8 mph with a crappy 1.80 60'.....still learning to drive....M&H DR's and skinnies on 17" Welds.
TornadoSS is offline   Reply With Quote
Old 03-20-2013, 11:18 PM   #5
GFORCE1320
Drives: 05 GTO
We are in full production now on our 31 spline axles.
All 9" kits from here on out will come standard with our 31 spline axles.
Thanks
Chris
Old 04-24-2013, 07:27 AM   #6
GFORCE1320
Drives: 05 GTO
We have been testing these in our shop car, pulled a 1.27 60ft a couple weeks ago.
We have sent a few 9" kits out with the new axles and a few sets have been sent to some big power guys to beat on. Cant wait for them to give them a work out.
Thanks
Chris
Old 05-30-2013, 05:47 PM   #7
GFORCE1320
Drives: 05 GTO
All 9" kits are now shipping with the new Level 5 severe duty 31 spline axles.
We are just about ready to release the Level 5 axles for the OEM rear as well.
We've had a bunch of inquiries about the Level 5 axles, were getting there, it takes a bit of time to ramp up production for a new level of axles for 6 different platforms.
Thanks
Chris
Old 08-08-2013, 05:15 PM   #8
GFORCE1320
Drives: 05 GTO
Since we have changed to our 31 spline Level 5 or Outlaw axles as we've called them, we have not had a single issue, not a one. We didn't have many issues before the change but the way we look at it, if your going to offer a Lifetime warranty then you should provide the strongest and best performing axles you can and providing the newest innovative designs is always good too.
The new 31 spline cv joints wear really well and hold up to some serious abuse.
Thanks Guys!!
Chris
