SDTW Custom Wheels & Tires
Old 02-17-2013, 04:16 PM   #29
Rhyder
Drives: 2012 45 Anniversary Vert
Originally Posted by ICTsccaCamaro View Post
I just didnt want to install and have a looser steering rack, the point of the bushing is to tighten up the rack not make it so the bushing can be loose and move back and forth more than the stock rubber bushing. If you install a under sized bushing into a mount you arnt gaining anything but just doing the opposite
yep, the Pedders crew is looking into it and I have no doubt if an issue is found they will make it right. Makes me a little glad the alignment kit is on back order so I haven't installed anything yet
Rhyder is offline   Reply With Quote
Old 02-17-2013, 05:02 PM   #30
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
We are thinking the new electric rack is slightly different even though the part numbers for the strap and bush are the same for all model years. As soon as the OE straps arrive we'll let you know what we find.
Old 02-17-2013, 07:32 PM   #31
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
Or 2012 is not electric power steering thought thats was 2013+ SS only?
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's, Exhaust Commander, GTO Clutch reservoir, Forgestar CF5V 19's
SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Wichita Region SCCA #98
ICTsccaCamaro is offline   Reply With Quote
Old 02-17-2013, 08:04 PM   #32
JusticePete
The 12 ZL1 is electric.
Old 02-17-2013, 08:12 PM   #33
Rhyder
This appears to be an issue on the non electric as well, the OP has a 12 RS Camaro (I'm guessing that's a 2LT or it would have SS I imagine)
Unless your meaning they used the same brackets in all 2012 Camaros as the electric ones....
Old 02-18-2013, 12:02 AM   #34
JusticePete
According to the GM parts catalog the answer is the bracket and the bushing are the same for all Camaros. Tht is why we have ordered a number of brackets and bushes. We want to see if there is a difference within the same OE part number.
Old 02-18-2013, 10:33 AM   #35
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
I had the same issue with the BMR bushing. The fitment was very loose and the bushing was much thinner than the OE.
LSX Camaro is offline   Reply With Quote
Old 02-18-2013, 01:10 PM   #36
ICTsccaCamaro
ITCRNRS
So did you install it or wait?
Old 02-18-2013, 07:03 PM   #37
L99CAMA2011
L99CAMA2011's Avatar
I have a BMR steering rack bushing in at the moment and is installing the Pedders one because it is stiffer. I had no issues with the BMR bushing as far as fitment is concerned. I am going outside so measure now in 28 degree temps will possibly take pics.
Old 02-18-2013, 07:04 PM   #38
JusticePete
No OEM parts showed up today.
Old 02-18-2013, 07:04 PM   #39
L99CAMA2011
Hi ICTsccaCamaro are you still interested in rear monotube 1LE shocks. There are still on hand. If not I may install them.
Old 02-18-2013, 10:42 PM   #40
L99CAMA2011
Correct. GM put a few ZL-1 parts on the early 12s. My 12 doesn't have the electric assist rack but had the front sway bar, swaybar bracket thicker studs and the newer steering rack bushing. Pete it would be good to get the stock bush for 2012 and later not just the bracket. I was tempted to put a shim under the Pedders bush but the space on the sides are now an issue as well. The front K member flexes and it is good to have the bush as snug as possible from all sides not just top to bottom.
Old 02-18-2013, 11:56 PM   #41
JusticePete
We did order both and in multiples f from different sources.
Old 02-19-2013, 12:36 AM   #42
Kyle2k
LVL 50 Troll Stomper
Kyle2k's Avatar
Drives: 2010 Camaro
Could you pm me more info - interested!
Kyle2k is offline   Reply With Quote
