Cold Air Inductions
Old 02-11-2013, 12:41 PM   #1
ColoradoSS
Drives: 2010 camaro SS/RS
pre cat o2 sensor connector
when I was installing my LT headers instead of disconnecting the pre cat o2 sensor from the harness i pulled the wires out of the plastic housing, all parts are intact but I have no idea which wire goes where, ive tried to find a wiring diagram for the connection but no luck. any ideas?
ColoradoSS is offline   Reply With Quote
Old 02-11-2013, 01:27 PM   #2
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Damn!
Wish I was home to take a pic for ya! Sorry bout that.
Old 02-11-2013, 01:29 PM   #3
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
Pretty sure I posted this for someone else. Let me see if I can find it.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 02-11-2013, 01:36 PM   #4
IndeedSS1
IndeedSS1's Avatar
Check here. http://www.camaro5.com/forums/showthread.php?t=256493
Old 02-11-2013, 10:47 PM   #5
ColoradoSS
yes that first top image is the one im talking about., underneath where it says "wires" are the abbreviations the color code?
Old 02-12-2013, 07:49 AM   #6
IndeedSS1
IndeedSS1's Avatar
Yes.
TN = Tan
PU/WH = Purple White
PK/BK + Pink black etc
Second being the stripe.
Old 02-12-2013, 06:29 PM   #7
ColoradoSS
the wires im talking about are the ones that lead off the o2 sensor, I have 2 black, 1 white, 1 blue
Old 02-12-2013, 10:05 PM   #8
The Blue Ox
The Blue Ox's Avatar
Drives: 2010 SS L99 Inferno Orange
Forgive me Colorado, but not sure what your exact question is!Please try and explain more clearly so that some fellow members or myself can help you! And post some pics if you can! Just trying to help,Thanks!
The Blue Ox is offline   Reply With Quote
Old 02-12-2013, 10:25 PM   #9
ColoradoSS
couldn't figure out how to attach picture to this message but I put a picture of the wires/connector under my album "camaro work"
Old 02-12-2013, 10:33 PM   #10
The Blue Ox
O k thanks! I see the wires are pulled out the connector! Let me check mine out and I'll get back to you!
Old 02-12-2013, 10:50 PM   #11
The Blue Ox
P m sent!
Old 02-12-2013, 11:13 PM   #12
The Blue Ox
Not sure where you got your extensions from but mine came with my Kooks headers, the white wire goes to my blue, the blue goes to my purple,....on the other side of connector,I've got green going to black, and black going to black! Dam! If the dang thing had 4 different colors,it would be easy!(like the extension does) But, since there are two black wires not sure which one hooks up to green!
Old 02-12-2013, 11:55 PM   #13
ColoradoSS
should I just take it to a gm mechanic? those two black wires are whats stumped me too
Old 02-13-2013, 11:58 AM   #14
The Blue Ox
No! Not no, but hell no! Lols! Here's another idea Colorado! You might can find a fellow c5 member that has one stripped out and isnt any good anymore so you can trace it to it's exact location! Or, maybe you can buy a o2 sensor (saw em on eBay for less than 50) use it for your diagram, then keep it for future or sell it to a c5 member that has stripped theirs out! I would trace mine down, but don't want to really cut my insulation!!
headers, oxygen sensor, wiring
