Old 02-11-2013, 02:44 PM   #1
SSICKO
SSICKO's Avatar
Drives: SSICKO
Supporting Mods for Cam Package?
I am going to do a Cam Package with the LS3 Conversion in the next few months by a very reputable Tuner. I am just wondering what other supporting mods are you people doing with cams doing?
Currently my mods are: LTs, HF Cats, 2.5" CB, CAI intake, YANK SS3200, custom tuned (365rwhp)
I have a RX catch can on the way and will be ordering a VMAX ported TB...
So...what else should I do? goal for the car is around 440-450 rwhp
Slowhawk Performance Built & Tuned
SSICKO is offline   Reply With Quote
Old 02-11-2013, 02:48 PM   #2
Ivan @ Southwest Speed
LS3/DOD conversion kit if you're planning on dropping the DOD.
For sure the TC will help the most and you can also consider some shorter gears as well. Esp with that Yank.
Everything else sounds good. Try to work as close as you can to the Cam grind and Tuner as you can.
That will make all the difference!
Good luck and let us know if you need anything!
Old 02-11-2013, 02:58 PM   #3
SSICKO
SSICKO's Avatar
Drives: SSICKO
im working with the tuner for sure, just trying to get a feel for what others are doing
Old 02-11-2013, 04:39 PM   #4
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
1. C5r timing chain
2. Replacing the Ls3 chain tensioner to Ls2 dog bone dampner.
3. Melling oil pump (10296)
4. Chromoly pushrods
5. Brian Tooley racing platinum valve springs "0" failure rate.
6. ARP cam retainer bolts (opt)
7. ARP cam sprocket bolts (opt)
8. ARP head bolts (only because you can reuse them many many times)
9. For L99's it's also a good idea to get your heads cncd and ported
10. Swapping out your L99 intake valves to hollow Ls3 valves
11. Rocker arm trunion upgrade.
To name a few off the top of my head.
Old 02-11-2013, 04:48 PM   #5
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
I am with the above. Maybe add drag radials and trailing arms to put the power down. Other than that I can't think of anything. The L99 is very forgiving on the rear end and the trans when tuned properly. Ohh yeah make sure you have a tranny cooler. If you had a M6 car I would say throw the suspension catalog at it as well as a 9inch rear end and strong clutch. LOL
Old 02-11-2013, 05:13 PM   #6
flyer08
Drives: 2010 2SS/RS
http://www.camaro5.com/forums/showthread.php?t=273945 there is my build and what we did
flyer08 is offline   Reply With Quote
Old 02-11-2013, 05:23 PM   #7
LeanPocket
Drives: 2010 2SS
Originally Posted by litle88 View Post
1. C5r timing chain
THISSSSSSSSSSSSS
Remember OP, TSP can port those heads for 800$ or have advanced inductions do it for a little more. You might aswell since you are alrady there if its within the budget, and you'll exceed your goal of 450+. AI also does badass valve jobs.
You can always have your intake ported for rather cheap, around 350$, or buy the fast 102 with the vmax ring so u can retain your TB.
pay the extra 20$ and get the cam custom spec'd from a rep., ive always been bias towards vengeance racing, martin from tick perf, pat g, geoff, to name a few.
You can opt for a thinner gasket to bump compression. People like to use the ls9 gaskets.
160 thermostat ~25$ from TSP
25% underdrive pulley, they are $189 @ calspeedperformance and you can buy the belts from TSP. its about 25$ ~ for the arp crank bolt and about 5$~ for the gm TTY bolt.
Hope that helps
LeanPocket is offline   Reply With Quote
Old 02-11-2013, 05:28 PM   #8
JEFF75645
Drives: his wife crazy buying mods
Looks like yall got this covered.lol
Gone But Not Forgotten
JEFF75645 is offline   Reply With Quote
Old 02-11-2013, 05:29 PM   #9
LeanPocket
Drives: 2010 2SS
bro we got this thread on LOCKDOWN
Old 02-11-2013, 06:20 PM   #10
SSICKO
SSICKO's Avatar
Drives: SSICKO
haha i appreciate the insight, most of the foremention things are included in my tuners package. I cant wait to get this work done, this is the first time ive spent some coin on go fast goodies.
Old 02-11-2013, 06:48 PM   #11
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
That's cool! Do it once and do it right, or end up paying twice is what I always say.
Old 02-11-2013, 10:09 PM   #12
rahallfly
rahallfly's Avatar
Drives: 2010 2SS/RS
Have you been reading all the threads on VVT Cams? I was in your shoes looking around for everything i wanted and decided instead of LS3 conversion, I went with TSPs VVT cam kit. with doing the AFM/DOD delete.
TSP VVT2, OBX LTs Catless mids, Flowmaster, Half K&N, Half Fastlane Pipeline CAI, Tuned by RDP Motorsports! Thats the main fun adders
SHAKE ANNNNNNND BAKE!!!!!
rahallfly is offline   Reply With Quote
Old 02-12-2013, 09:38 AM   #13
SSICKO
SSICKO's Avatar
Drives: SSICKO
yeah, im up in the air with the vvt cam, maygo ahead and do the vvt
Old 02-12-2013, 01:26 PM   #14
Nightmare2012
come find out;)
Drives: stockish 2012 camaro ss
By forgiving you mean good or bad sorry i didn't quite get it lol
Nightmare2012 is offline   Reply With Quote
