Old 02-12-2013, 01:52 PM   #1
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
Boost Solenoid Question
For all you turbo experts, I've got a question. The EFRs I have can each have a solenoid attached directly to the turbo. My AEM boost controller comes with a single solenoid. If I put a Borg-Warner solenoid on each turbo I should improve response time dramatically (cut down on spikes), but I can't figure out how this would affect the controller. Surely there is a change in resistance or voltage that I would need to account for somehow. Anyone have any ideas?
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 02-12-2013, 02:29 PM   #2
Can't_C_Me
Don't Sleep on My V6
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
To be safe I would add another boost gauge and run one for each turbo. I'm assuming yours one is split into both turbos right? Where does yours have the adaptor at on the turbos?
Can't_C_Me is offline   Reply With Quote
Old 02-12-2013, 02:49 PM   #3
GretchenGotGrowl
My current setup has it mounted on the bracket where the original washer bottle was mounted. The EFRs have a solenoid that mounts right on the turbo.
Old 02-12-2013, 03:01 PM   #4
Can't_C_Me
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
Look and see if adding another gauge would help. Or if they sell some that supports 2 solenoids. I'm also assuming you tried just using a "T or Y" fitting to split off the hose to the one gauge you have.
Old 02-13-2013, 10:03 AM   #5
GretchenGotGrowl
Don't want to run two boost gauges. There may be a way to rig it so you only need one (ideal because I don't have to change out my current gauge), and there are some that support two solenoids. Aaron sent me a document I'm trying to get through that shows one that supports both a single or dual. Haven't finished reading it, but it looks like the same gauge so that may indicate it is how you run the tubing. The question is, do I tie the two reference tubes together with a "T" or the two waste gate actuators? So far, I haven't found the diagram that shows that.
Old 02-13-2013, 10:53 AM   #6
Can't_C_Me
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
I wouldn't see why a "T" wouldn't work. I am running waste-gate pressure now but when I wasn't just like your old set up. I was using a "T" out of the solenoid to each waste-gate. Should still be the same concept just that your running the hose from the gauge to a "T" into 2 solenoids. But I do see your frustration in trying to figure this out. I'm on the hunt for this answer now also lmao!
