BeckyD @ James Martin Chevy
Old 02-12-2013, 05:57 PM   #1
amerimuscle
Drives: 2011 Camaro 1SS
Tunnel brace?
So i got my long tubes put on by a fairly reputable shop here and when i got my car back i noticed that my tunnel brace was in the box with my old manifolds and cats. How important is having the tunnel brace on? does it not fit most aftermarket systems? how many of you are brace-less ?
I have the LG super pro LTH 1 7/8, catless into a full 3 in system.
amerimuscle is offline   Reply With Quote
Old 02-12-2013, 06:08 PM   #2
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
Mine is still sitting on my shop floor. I've had it off for several months now. I just need to get some spacers and put it back on, but I haven't noticed any changes with it off.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 02-12-2013, 06:52 PM   #3
nukemustang
nukemustang's Avatar
Drives: 2017 Raptor, 2017 SS
You might be able to adjust the exhaust up far enough to clear the brace. If not, several companys offer modified braces to have an offset so that a 3" exhaust will easily clear the brace. One is from ARH and is like $450, ad one if from Stainless Works and is $180.
I only have the 2.5" exhaust and know i have about a 1/2" of clearance to the front (convertible) and rear braces.
Saving for: 2019 ZL1 convertible.....
SOLD:2016 2SS Red Hot Convertible with black metallic rally stripes
SOLD:2011 Silver Ice Metallic 1SS/RS Convertible. Completed modifications: installed factory HUD, deleted AFM/DOD, Dynatech LT coated headers with high flow cats, Solo Cat back exhaust, CAI inc. intake, Vmax ported TB, SIM quarter flares/splash guards, steering wheel radio controls, PDIM iPod interface in center console, RX catch can, JRE cold air scoop, windshield washer bottle relocation.
nukemustang is offline   Reply With Quote
Old 02-12-2013, 07:02 PM   #4
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Do you have a convertible? If so that is the reason they removed the brace as there is not much clearance. We do offer the Stainless Works Convertible Brace Kit.
Part#: CA11CONVKIT
The Stainless Works convertible kit adapts the clearance around the convertible frame bracing to allow for the use of 3" dual exhausts. Kit includes heavy duty 14 gage 304 SS front bracing to replace OEM brace, as well as spacers to provide extra clearance behind the differential at the rear bracing. All 304 SS construction with 304 SS hardware included.
Feel free to call, PM or email me with questions.
Best regards,
Tyler
888-308-6007
Old 02-12-2013, 08:12 PM   #5
rdblan2
Drives: 2SS RS
Mine has been off the car since about June of 2010. I'm adding the BMR subframe connector and bought the tunnel brace to go with it as well. I noticed no difference with the factory tunnel brace being gone.
Livernois 2C cam and tune, LS3 conversion, Roto-Fab intake, Kooks headers, DSS driveshaft and axles, BMR suspension parts, VMax ported throttle body, Whipple blower. (623hp).
rdblan2 is offline   Reply With Quote
Old 02-12-2013, 08:27 PM   #6
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
It's there for a reason and has been debated numerous times. Searching this section will come up with several threads on it.
Basically, it provides structural integrity across the tunnel. Some are very in tune with their cars and can feel the difference while others can't. There are several routes you can go to remedy the problem. New lower hanging brace as JDP suggested, add washers to lower the OEM one, or try to get the exhaust to push up higher. The choice is yours and all will work.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 02-12-2013, 09:10 PM   #7
amerimuscle
my buddy said it may add some stiffness to the car, so it got me thinking. Its not a convertable. I didnt notice a difference. So in conclusion the shop i got it done at isnt completely incompetent and there are aftermarket braces. good work guys, thanks a lot!
Old 02-13-2013, 10:41 AM   #8
Sack Rat 2SS
Sack Rat 2SS's Avatar
Drives: Silver SS/RS, Man 6
The driveshaft is a two piece unit. The middle joint is directly ABOVE where the tunnel brace attaches. It is there for additional stability to the middle joint bearings. I would not drive very long without one.
Silver 2SS/RS Man/6
CTS-V front 6-Piston Calipers,
GM 3.91 Rear Gears
Sack Rat 2SS is offline   Reply With Quote
Old 02-13-2013, 11:48 AM   #9
BowlingSS
Camaro Owner Since 1987
BowlingSS's Avatar
Drives: 2011 2SS/RS L99 RJT
I bought an Elite Engineering Tunnel Brace and still had to space it down.
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop
Rx Catch Can;Rx Breather;Roto-Fab Washer Container
VMax Ported RJT Throttle Body
XSPower Headers and XSPower 3" Exhaust System
Elite Engineering Tunnel Brace,
Gorilla Wheel Lock System; Bear Rotors, Hawk HPS
Tinted Windows 35%;EFILive Tune
BowlingSS is offline   Reply With Quote
Old 02-13-2013, 12:27 PM   #10
blake-b
blake-b's Avatar
Drives: Black 2010
I have 3" exhaust and a BMR tunnel brace and didn't have to space it down. I used a floorjack and a piece of wood and elevated the exhaust up as high as it would go without hitting anything on top. I then tightened the exhaust from front to back. When I lowered the jack, it didn't drop much, if any, at all.
I then put the brace on and have no rubbing issues.
