JDP Motorsports
Old 02-12-2013, 07:41 PM   #1
bcamaro1
bcamaro1's Avatar
Drives: Blue ray w/ silver stripe 2ss
coated headers
why should you get stainless steel headers verses coated ones? I understand rusting... but won't the factory headers rust over time as well and they would work fine.
New car- 2013 ls3, dusk special edition, muffler delete, CAI intake, ported vmax throttle body, next will be headers and tune...
First car-2011 L99, Vmax ported throttle body 90mm, Vararam intake, flowmaster outlaw exhaust, TSP 1 7/8 headers w/ Cats, PCM tune
bcamaro1 is offline   Reply With Quote
Old 02-12-2013, 08:05 PM   #2
Alvin@PCMofNC
Drives: 2010 IOM RSS
Appearance, and coating can help keep temps down a bit.
I personally just run stainless kooks and don't coat them. They look fantastic still after three years, I like the look of the natural stainless and it won't rust.
Alvin@PCMofNC is offline   Reply With Quote
Old 02-12-2013, 08:18 PM   #3
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
SS shouldn't rust but it will discolor from heat cycles. Coating them makes them stay shiney considerably longer. For the most part, it's a cosmetic mod. It also holds a little more of the heat in, but the amount is debateable. The factory manifolds are cast iron, so they'll rust. They are also VERY thick, which means a little rust is no issue. The only other header material type is mild steel which will rust and rust through over time.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 02-13-2013, 09:31 PM   #4
Juiced1
Juiced1's Avatar
Drives: 2012 2SS CAMARO 45th
Aftermarker headers are a lot thinner the the factory manifolds and if they are mild steel they can rust through. Having mild steel ceramic coated will help them last longer but stainless steel is king. Some like getting stainless steel ceramic coated too some call it over kill. It sure looks pretty but unless you're hot lapping at the track all the time in the summer heat you wn't have any performance advantage.
GET MORE POWER PER DOLLAR!!!
We carry all the hottest brands for your Gen5 and Gen6 Camaros! Get awesome deals on Corsa, SLP, ARH, SW, Whipple, Kooks, Procharger, CAI, K&N, Rtoto-Fab and much more! Call us for your CAMARO5 discount today!
224-63-JUICE OR INFO@JUICEDMOTORSPORTS.COM
Juiced1 is offline   Reply With Quote
Old 02-17-2013, 04:09 PM   #5
NJIOMSS
NJIOMSS's Avatar
Drives: 2010 IOM SS/RS
Can anyone else chime in who has been running stainless steel headers for a long period of time? There's no true advantage of coating them other then keeping under hood temps down, correct? Besides the obvious cosmetic advantages of course. I'm just looking to make sure there are no issues from having them uncoated since my car is a daily driver and I would like to get stainless steel headers for the car this spring. Thanks for the help in advance.
NJIOMSS is offline   Reply With Quote
