Solo Performance
Old 02-12-2013, 08:08 PM   #1
CamaroDIYking
Drives: 2010 Camaro 2SS/RS
DRL Harness
Can someone tell me why the DRL Harnes actually does? I'm talking about the harness that plugs into the light and then into the plug? I've had a a camaro for about a month and I'm just curious about little things like that
2010 2SS/RS- every option possible in 2010
Lighting- LED footwell, grille, trunk, and engine lights done via DIY. LED dome, DRL, and tag lights.
Paint- Painted engine cover, steering wheel bezel, speedometer bezel, front bowtie, tail light bezels, wheel center caps.
Exterior lights- tinted tail lights and sidemarker lights.
Wheels- powdercoated stock RS 20' wheels black
Exhaust- Cat-back Dynomax Bullet Exhaust system with bullet muffler delete.
Misc- rear blackout kit from Big Worm Graphix, black side Camaro lettering from Emblem Pros, and rear Camaro lettering from Emblem Pros.
CamaroDIYking is offline   Reply With Quote
Old 02-12-2013, 09:24 PM   #2
The Stig
knows 2 facts about ducks
The Stig's Avatar
Moved to cosmetics. Please don't make multiple threads asking the same question.
Thank you.
Click to view my build thread
Old 02-12-2013, 09:25 PM   #3
Top Thrill
BOD 5/28/09 #13485
Top Thrill's Avatar
Drives: 2010 Camaro 2LT RS
I think you ment WHAT it does.
Without the harness, during the day when you drive only the DRLs will be on. At night when you turn the headlight on the DRLs will go out.
With the harness in, the DRLs will stay on with the headlights.
Top Thrill is offline   Reply With Quote
Old 02-12-2013, 11:57 PM   #4
2SSRSinBama
Drives: 2010 2SS/RS Camaro CGM
you can splice the parking light and hot wire, then solder them together(I spliced them and them soldered a 14 gauge wire to join them and put heat shrink over the solder)... that is what I did... I mean I am an electrician by trade, but its nothing even a novice can't do, plenty of write ups online if needed...
you're also going to want to get rid of the yellow Halogens, I went with P13W Xenon White LED Bulbs, only like $40 for the set
2010 Camaro SS L99... has a few mods
2SSRSinBama is offline   Reply With Quote
drl harness, headlights, lights
