Old 02-13-2013, 07:48 PM   #1
Fallout
Mid Florida Camaro Club
Fallout's Avatar
Drives: 2012 Camaro SS Ashen Gray
NA power capable of 10's without gutting the Camaro
I have a 2012 Camaro SS ls3, with the current mods New Era OTR itake, LG 1 7/8 headers into a LG full 3" exhaust(no cats), TSW Nurburging 20" with NT555r tires on the back. I have not got it tuned yet or put on the dyno. The vehicle goes in the shop in a few weeks to get a TSP 235/239 .641 .615 cam, TSP aftermarket 255cc heads milled to unknown specs(shop still looking this over),fast 102mm w/NW 102mm TB, ATI balancer 10% underdrive, Dynotech 1 piece driveshaft (from GeForce), DSS half shafts, and Subframe/differential bushings. I will also be adding 3.91 gears.
With these mods do you guys think I'll be able to put it near or in the 10's. The idea was to stay N/A and get into the 10's then play with the spray a bit.
Give me a heads up if you see anything missing or know of better items to help me. Thanks in advance.
Fallout is offline   Reply With Quote
Old 02-13-2013, 07:53 PM   #2
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
u should be fairly close to 10's just throw out the stuff in the trunk and all that stuff. it would take a pretty aggressive tune. and alot of dail in work. but it can be done.
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 02-13-2013, 08:03 PM   #3
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
What made you pick that cam?
Old 02-13-2013, 08:09 PM   #4
SPCBA
Drives: pleather and Chiclets
what made you choose another set of 20inch wheels?
SPCBA is offline   Reply With Quote
Old 02-13-2013, 08:21 PM   #5
Camper
Banned
Drives: 10' 2SS LS3 M6
id say the 20" wheels are going to hold him back
Camper is offline   Reply With Quote
Old 02-13-2013, 08:22 PM   #6
SPCBA
most certainly
Old 02-13-2013, 08:29 PM   #7
Fallout
Fallout's Avatar
I originally planned on the LG g6x3 cam, but saw this one and wanted to experiment a little with something different. Should be close to the numbers the G6x3 put down. Yes wheels will be a factor will be a few months before funds are sufficent for purchasing different rims. Any patricular rims you guys suggest and size?
Old 02-13-2013, 08:31 PM   #8
SPCBA
depends on if you want to modify suspension and brakes.
there are lightweight 18's that can fit if you want to keep stock setup.
Old 02-13-2013, 08:36 PM   #9
Fallout
Fallout's Avatar
You guys think this stock clutch will hold up?
Old 02-13-2013, 09:25 PM   #10
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
How fast have you gone so far?
I think low 11's will take some practice. So I'll say eventually.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 02-13-2013, 09:30 PM   #11
Jason@JacFab
Jason@JacFab's Avatar
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
You may benefit from a different CAI. Pick up a set of 18" vette GS wheels for the rear, they are cheap, and will drop a bunch of rotating mass off the rear.
2016 1LT RS, 2.0T A8
13.462 @ 100.65, stock eng/tune w/ some weight reduction
12.957 @ 103.45, JacFab BigMouth TB & Charge pipe, Catless downpipe, LSD diff swap, Ghetto drag pack, unfinished tune.
Jason@JacFab is offline   Reply With Quote
Old 02-13-2013, 10:40 PM   #12
Fallout
Fallout's Avatar
I have not been to the track with this car yet. I have had a few runs with my previous vette, but two completely different beast. What's the issue with the intake? GS wheels I will look into thanks for the help.
Old 02-13-2013, 11:00 PM   #13
xjer22x
xjer22x's Avatar
Drives: 2010 rs/ss black # 10,308
I use a set of c6 z06 front wheels. They are 18in x9.5in wide +40mm offset. And I fit a 305 nitto nto5r on there..works great and beats the stock 20's by far. I'm struggling to get into the 10's too so best of luck to you.
sent from my galaxy s3. that would explain the errors.
xjer22x is offline   Reply With Quote
Old 02-13-2013, 11:02 PM   #14
trw427ss @ Futral
trw427ss @ Futral's Avatar
Drives: 2013 2SS/RS L99
Nothing is wrong with the New Era Intake as far as I am concerned! It works great for me!
2013 2SS/RS L99/A6 Crystal Red Metallic Tincoat 12.76@108.98mph Bone Stock
12.46@111.19mph with New Era CAI & U/D Pulley
12.12 @ 114.16 after Stainless Power headers and no tune yet on stock P-Zero's!
12.007@ 115.20 With 18" Drag Radials - 11.93 @115.19 Added a PTB 11.76 @116.59 With Yank SS3200 Converter - 11.63 @116.52 After PI and Tuning 11.44 @118.75 New Best
10.72 @127.93 after heads and Cam and Yank SS3600
trw427ss @ Futral is offline   Reply With Quote
