Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Northwest / Pacific Northwest
Old 02-13-2013, 10:43 PM   #1
Brianstanley
Brianstanley's Avatar
Drives: 2012 2LT RS Coupe in CRT
Greetings from a new Member & What is the hotest Engine temp you have ever seen?
Greetings from a new member here from Auburn WA!
I have been on here for a few months and just listening and learning. Today, me and the CRT 2LT/RS got stuck in bumper-to-bumper-stop-and-go traffic on Hwy-167 north bound when a blocking accident that happened at the Kent Des Moines (Hwy-516) exit (Pray no-one was hurt.) No movement for 45 minutes in all lanes.
Got really bored and decided to watch the digital read-out of the engine coolant temperature. It climbed from the normal 187 degrees to degrees to 222 and back down to 203 on a 50 degree day. The first time it reached 222, I was worried.
So what is the hottest you have ever seen the engine coolant temperature climb to and what kind of driving were you doing and what was the outside temperature and are you a V6 or V8?
Brianstanley is offline   Reply With Quote
Old 02-13-2013, 11:26 PM   #2
Ladybugsmom
Older than I look....
Ladybugsmom's Avatar
Drives: 2010 VR Camaro 2SS/RS LS3
I've never looked at the digital display of that.... then again, I don't often do stop and go traffic in the Camaro...
Have you been able to find out if that was normal? I recall reading that the 200 range was normal...
High Heels and Fast Wheels!!
Ladybugsmom is offline   Reply With Quote
Old 02-14-2013, 12:13 AM   #3
camaroguy2010
camaroguy2010's Avatar
Drives: 2010 Camaro 2SS
Can't help either. I changed mine out to a 160 thermostat. So mine runs around the 160 to 170 range. Factory setting is a 195 thermostat.
camaroguy2010 is offline   Reply With Quote
Old 02-14-2013, 10:41 AM   #4
heRS
Raised by Wolves
heRS's Avatar
Drives: IBM 2010 2LT RS M6
Welcome, Brian! I can't really answer your question since my Camaro is stored for the winter and I don't recall my summer temps.
I can say hi though, glad you joined us.
Tori
Old 02-14-2013, 02:36 PM   #5
keving2873
keving2873's Avatar
Drives: 2011 Camaro 2SS RS
That is still in the normal range for what I have seen. I look at that readout a lot when I let the car warm up in the morning. I usually wait to roll until it gets up to 100F. In stop and go, 220's is something you might see, but once you start rolling it will drop down as it starts recycling the fluid.
476whp 455trq / Tuned by Tom Wong
CAI Intake with ADM Scoop, Borla ATAK cat-back, ARH 1 7/8 Headers and HF Cats
Custom Comp Cam 231/234 114LSA 617/598 lift, Katech timing chain
Apex Catch-can
VMAX Ported Throttle Body
20" Niche Essen's wrapped in Michelin PSS 315/295
keving2873 is offline   Reply With Quote
Old 02-15-2013, 09:36 AM   #6
Ir0nM4n
Love me some Tacos
Ir0nM4n's Avatar
Drives: 14 1LE
227 When driving in stop and go traffic. Like Keving2873 said it drops pretty fast once you get moving.
Ir0nM4n is offline   Reply With Quote
Old 02-17-2013, 06:24 PM   #7
CaryE1
CaryE1's Avatar
Drives: Black 2011 2LT
I recall there being some discussion about this in the 6cyl engine forum... And if I remember, it was normal. I'll see if I can find it.
CaryE1 is offline   Reply With Quote
Old 02-17-2013, 06:32 PM   #8
CaryE1
CaryE1's Avatar
Can't find it... I'll keep looking and let you know...
Old 02-17-2013, 09:02 PM   #9
Cam 427
Cam 427's Avatar
Drives: 2010 2SS
The fans kick on around 220 degrees and go off around 200 degrees. I'd say what you saw was normal.
Cam 427 is online now   Reply With Quote
