SDTW Custom Wheels & Tires
Old 02-13-2013, 11:44 PM   #1
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
LS3 Lifters Options and Opinions
Looking to get get some feedback on 2 different LS3 lifters by GM. I am in the process of a LS3 conversion on my 2010 L99. I had a custom cam designed and am deciding between different lifter options.
1. GM #12499225
LS Series camshaft lifter kit
An inclusive set of 16 lifters for the LS Series engines.
Newly redesigned for high RPM LS7 engine usage.
2. GM #88958689
DESCRIPTION: LFTR PKG set of 16tested to 8000 RPM
same dimensions as production
improved dynamics and stability at high RPM's
The price for the second part number is almost double. Any thoughts?
LSX Camaro is offline   Reply With Quote
Old 02-13-2013, 11:53 PM   #2
1sikRS
Drives: chevy
I used comps 8610s I Believe but I don't Spin my motor anywhere close to 7 or 8k rpms
1sikRS is offline   Reply With Quote
Old 02-14-2013, 12:08 AM   #3
trw427ss @ Futral
trw427ss @ Futral's Avatar
Drives: 2013 2SS/RS L99
Not sure of the part # but the GM Caddy Race lifters are better than the LS7's.
2013 2SS/RS L99/A6 Crystal Red Metallic Tincoat 12.76@108.98mph Bone Stock
12.46@111.19mph with New Era CAI & U/D Pulley
12.12 @ 114.16 after Stainless Power headers and no tune yet on stock P-Zero's!
12.007@ 115.20 With 18" Drag Radials - 11.93 @115.19 Added a PTB 11.76 @116.59 With Yank SS3200 Converter - 11.63 @116.52 After PI and Tuning 11.44 @118.75 New Best
10.72 @127.93 after heads and Cam and Yank SS3600
trw427ss @ Futral is offline   Reply With Quote
Old 02-14-2013, 12:11 AM   #4
tandtperformance
tandtperformance's Avatar
Drives: 2010 Camaro 2011 PACE CAR 2012 ZL1
Send a message via Yahoo to tandtperformance
second one listed is the set to go with .........
tandtperformance is offline   Reply With Quote
Old 02-14-2013, 03:55 AM   #5
K32 Camaro
V8 lounge member #5
Drives: 12 2SS Synergy Camaro, 05 PontiacG6
Always the one with the bigger part number. That means it was made at a later date with better tech. (I was BSing.)
Go with the shop guys advice.
K32 Camaro is offline   Reply With Quote
Old 02-14-2013, 06:16 AM   #6
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
1. GM #12499225
2. GM #88958689
First off what cam are you going with?
What lobes?
What will your spring pressures be?
What are you planning to be spinning to?
Your doing a very good quality build bud so start researching.
If you'll be using your stock lifter trays and want an awesome lifter thats BETTER than the stock GM's, look at these lifters by Brian Tooley racing (he used to own TEA) an awesome guy and an even better valvetrain expert. Give him a call
Here are his SLR (slow leak down rate) lifters.
http://www.briantooleyracing.com/slr...r-lifters.html
Now if your gonna be spinning it hard and pretty high and you want to not worry about spinning one in the bore due to lifter tray failure due to high rpm and high spring pressures and lift then I'd go with these:
http://www.briantooleyracing.com/mor...r-lifters.html
I used these on my 4th gen
BUT PLEASE some people here think that because its 8k rpm that they are the best. They are NOT!! There are ALOT of failure rates with these lifters because they MUST be setup appropriately!! And even when that have been still trouble since they came out. Search on Ls1tech and you'll see.
Keep up the awesome build bud.
Old 02-14-2013, 06:32 AM   #7
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
Yeah there are alot of failures reported on the caddy lifters. I think those need a really light valvetrain and certain springs to work well
Old 02-14-2013, 09:52 AM   #8
CGT
Drives: 2011 SSm6
I had the Caddy lifters take out an entire ls2 when one of the axles walked out of the lifter. Trailblazer SS, mild cam, ls3 heads, decided i was gonna "upgrade" to those lifters. Maybe it was just bad luck, but I wont be using them again.
CGT is offline   Reply With Quote
Old 02-14-2013, 12:54 PM   #9
LSX Camaro
LSX Camaro's Avatar
What lobes?
The cam is a custom grind from comp.
Lobes are EHI and LXL
Intake lift .638
Exhaust lift .612
Rev limiter will be set at 7000
Springs are Patriot Gold Duals
Old 02-14-2013, 03:20 PM   #10
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
What about duration?
How often will it see the track?
It doesn't seem radical, I think that the Brian Tooley lifters will be your best bet, you didn't cheap out on a single part of your build lol not even the plug wires. Don't do it on the lifters especially lol.
Old 02-14-2013, 03:52 PM   #11
realcanuk
realcanuk's Avatar
Drives: 2007 Corvette C6 983 RWHP
Usiing Morel link bar lifters from Brian Tooley. Give him a call. He will steer you the right way.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam
YSI / 3.0 pulley, ARH 1 7/8 headers, NPP
Dewitts / dual spals, A&A dual pump fuel system.
3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me.
ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper
Circle D Triple Disc stall
1009 RWHP @ 7000, 817 RWTQ @ 6000, Built & Tuned by Seth at FEDERAL PERFORMANCE
realcanuk is offline   Reply With Quote
Old 02-14-2013, 05:04 PM   #12
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Here too, too many people cant be wrong lol.
Old 02-19-2013, 06:32 PM   #13
LSX Camaro
LSX Camaro's Avatar
Thanks for the advice and opinions. I went with the BTR lifters and springs.
Old 02-19-2013, 06:39 PM   #14
VADER SS L99
What kind of reliability do those lifters have? I'm thinking about those or Morels for my next build. Pretty sure a destroyed lifter has ruined my motor so next time I need something better than LS7's.
