Old 02-14-2013, 10:58 AM   #1
KalCorp
Space Coast Camaros
KalCorp's Avatar
Drives: 2012 Camaro Vert
Wavy Dyno Graphs -V6
Just starting a post to talk about the Wavy Dyno Graphs on V6.
Some get it and others dont.
KalCorp is offline   Reply With Quote
Old 02-14-2013, 11:05 AM   #2
KalCorp
Space Coast Camaros
KalCorp's Avatar
Ok here is a example Dyno with the issue.
2011 2LT/RS Vert A6 with BBK LT, Hi flow cats, ported TB, IM Spacer, Trifecta tune. MRTv2
I also did a data log at the same time. so we can review.
Old 02-14-2013, 11:08 AM   #3
KalCorp
Space Coast Camaros
KalCorp's Avatar
After looking at this today i it stops around 4,500 RPM.
So I looked in my data log around that RPM. I found this!
Its the only thing so far that matches up to it.
Ignition Timing Advance. What causes this? It looks like its close in time with the Knock retard. So i take it the knock is causing the timing and in turn is killing the power?
Now this cant be the tune since we seen IPF and Trifecta dyno done once after the other without this issue.
Wish we could see a log from a Dyno with out the wavy lines like this.
So this has to be a issue would our Camaros. How do we find out that it is since some have it and others dont?
Old 02-14-2013, 12:03 PM   #4
KalCorp
Space Coast Camaros
KalCorp's Avatar
Thanks for the 101.
Going by my graph. This looks normal and I should not worry about it correct?
I was just worried that maybe the IM spacer might have not been sealed the best and leaking. ( last thing i did before the first dyno that looks like this)
My butt Dyno does not feel this. The car runs and feels great.
I think i need to stop worrying about all this and drive and just have fun!
Old 02-14-2013, 12:41 PM   #5
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Originally Posted by KalCorp View Post
Thanks for the 101.
This is in fact Knock retard there is either bad gas in the car or too much timing in the tune.
It is amazing what you can see with a dyno that you can't Feel.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 02-14-2013, 03:03 PM   #6
KalCorp
Space Coast Camaros
KalCorp's Avatar
Ted.
Thanks, I been going by what everyone else is telling on on these V6's.
That the knock is normal on these LLT's and they have plenty of it. Too some of the v8 tuners telling me there should be 0.
I use 93 oct. but that does not mean its not bad. I can try another Place.
and is there any additives i should try before redoing the log? to see if its the gas or not?
Old 02-14-2013, 06:31 PM   #7
Jarp
Jarp's Avatar
Drives: Commodore SV6
This is my cammed LLT on road using 10% ethanol at around 97 octane.
Edit: I'll find a better way of attaching images...soz.
Jarp is offline   Reply With Quote
Old 02-14-2013, 07:45 PM   #8
KalCorp
Space Coast Camaros
KalCorp's Avatar
On the road I did a WOT run an data log. Sent in and was told it was great.
I checked the log and there was some knock about 4. On dyno it was up to 8.
Old 02-14-2013, 07:46 PM   #9
Jarp
Jarp's Avatar
Yeah...just looked at those pdfs again. Stuffed it up a bit...will do again. Alternatively can send you logs as is just Trifecta EZflash log or can SCANXL if you want?
Will do you a swap as would love to have a look at Glides logs. Particularly interested in LTFTs.
