Gen5DIY
Old 02-14-2013, 08:46 PM   #1
Algeron
Algeron's Avatar
Drives: 2016 2SS/RS vert, 1998 Z28, 1991 RS
Convertible Spoiler?
Are there any spoilers for the convertibles? Almost all of the pics I have found are of the stock one, and I am looking to see what options I have to change it.
2016 Red Hot 2SS convertible Adrenaline Red interor, A8, MRC, NPP, Black Bowties, NAV
Installed Mods:
CAI intake
http://imgur.com/a/kurVF
Algeron is offline   Reply With Quote
Old 02-14-2013, 08:50 PM   #2
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
Thought coupe and vert shared the same spoiler bolt pattern. As coupes have swapped on vert spoilers so any spoiler should fit vert or coupe correct?
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's, Exhaust Commander, GTO Clutch reservoir, Forgestar CF5V 19's
SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Wichita Region SCCA #98
ICTsccaCamaro is offline   Reply With Quote
Old 02-14-2013, 08:52 PM   #3
Algeron
Algeron's Avatar
I am not sure. I have seen several on the GM site, and they all say NOT for convertibles.
Installed Mods:
CAI intake
Old 02-14-2013, 08:57 PM   #4
Eric-MPD1.com
Drives: Cool parts for cool cars
They do share the same bolt pattern but the convertibles have an antenna inside the spoiler.
We are currently working on a new bottom for the MPD1 spoiler just for the convertibles. I have done several conversions so its time to make a dedicated mold.
Eric-MPD1.com is offline   Reply With Quote
Old 02-14-2013, 08:58 PM   #5
Algeron
Algeron's Avatar
Which antenna? I knew they moved the fin to the trunk lid.
Installed Mods:
CAI intake
Old 02-14-2013, 08:59 PM   #6
Eric-MPD1.com
The AM/FM antenna
Old 02-14-2013, 09:02 PM   #7
ICTsccaCamaro
ITCRNRS
Thats it and cant you just buy a aftermarket internal antenna and locate it in the trunk
Old 02-14-2013, 09:04 PM   #8
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Drives: 16 Encore, 07 G6, 99 Astro, 16 VW
I have seen where people have removed the antenna from the stock vert spoiler and installed it in the dovetail blade spoiler. You have to be careful when removing it to keep from damaging the antenna wire. An antenna inside the trunk won't work because the trunk lid will block the signal.
The Bird is the word!
Old 02-15-2013, 12:49 PM   #9
GnyaTek
GnyaTek's Avatar
Drives: 2011 SIM 2SS/RS Vert
KalCorp has done a quick writeup on relocating the AM/FM antenna into the rear fascia for the convertibles here: http://www.camaro5.com/forums/showthread.php?t=272540
The issue with the "non-convertible" spoilers is generally due to that AM/FM antenna located inside the factory spoiler. Not sure how difficult it is to remove the antenna from the stock spoiler, but could order a replacement antenna and relocate it to the rear fascia, leaving the original antenna in the factory spoiler in case you'd be interested in "un-doing" the process later if you sell the car or change your mind on the mod.
GnyaTek is offline   Reply With Quote
Old 02-15-2013, 03:59 PM   #10
United_727
Parts Guru Extraordinair.
United_727's Avatar
Drives: '02 SS 'Vert M6
On a side note,does anyone make a copy of the factory 'vert spoiler already painted for coupes?
Please check out my other hobby ; http://jetphotos.net/showphotos.php?userid=1008
United_727 is offline   Reply With Quote
Old 02-15-2013, 04:24 PM   #11
Angrybird 12
There is a company on e-bay called The Spoiler Company that lists a painted one for $209.
http://item.mobileweb.ebay.com/viewi...id=81758359352
Old 02-15-2013, 04:37 PM   #12
United_727
United_727's Avatar
Thanks,I will have to message them to make sure theirs has the same bolt pattern as a genuine 'vert spoiler.
Old 02-15-2013, 04:47 PM   #13
ctinatx
ctinatx's Avatar
Drives: 2014 SS Sedan
I have the Z/TA Spoiler and they have a convertible version. It allows you to transfer the antenna from the stock to the new one.
Pics can be found in this thread
http://www.camaro5.com/forums/showth...ghlight=z%2Fta
Also SLP makes a spoiler for the convertible as well.
Z/TA
http://www.phastekperformance.com/20...poiler-114.htm
SLP
http://www.phastekperformance.com/20...ng-100041c.htm
2014 Phantom Black Metallic SS Sedan
Sold - 2011 2SS/RS Convertible IBM/gray interior/black top/silver rally/L99/polished wheels - ordered 11/18/2010 - Built 02/09/2011- Delivered 4/2/2011
ctinatx is offline   Reply With Quote
Old 02-19-2013, 04:51 PM   #14
United_727
United_727's Avatar
I emailed them Friday about fitment. Still have not heard back . They lose.
convertible, spoiler
