Old 02-15-2013, 07:08 AM   #1
family man
Drives: .
Question breather on oil fill tube
While checking out some engine pics on here, I noticed some people have breathers on their oil fill tube. Why is that? Will it help with cranckcase ventilation and reduce the amount of oil being run though a catch can?
family man is offline   Reply With Quote
Old 02-15-2013, 07:16 AM   #2
Camper
Banned
Drives: 10' 2SS LS3 M6
I have always ran one and I essentially have no oil running through my system. when I pulled my intake manifold I was pleasantly suprised at how clean my intake ports on my heads were.
Camper is offline   Reply With Quote
Old 02-15-2013, 08:30 AM   #3
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
Just another method of getting the fresh air side of PCV system. But, it will mess with your fuel trims. Since it essentially replaces the makeup air that is mormally and intentionally seen by the MAF sensor it isn't being accounted for.
The breather with the check valve helps reduce this by reducing the incoming airflow, but it will still skew the fuel trims by 6-7% as I recall. I've posted this somewhere on here when I was testing them out. The good news is most people that are considering breathers are modded enough to be tuned. The change in fueling can be corrected by tuning.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 02-15-2013, 09:45 AM   #4
grocerygetter
instigator
grocerygetter's Avatar
yeah...breather on an oil cap plus catch can is 10psi FI territory in a nutshell. ANother way to release crankcase pressure. ECS's doesn't have a valve I don't think...just open breather...Doug told me like a 3-4% adjustment for idle/tip in possibly needed. I'm putting mine on with my Elite catch can when I pulley down. I can have Ted tweak the tune if need be. I pulled the oil cap to test it last week and it idled fine...little different, but fine. Could be Ted's tune.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
