JDP Motorsports
Old 02-15-2013, 04:11 PM   #1
ramsman34
ramsman34's Avatar
Drives: 2011 Summit White, 2SS/RS-LS3
converting 2SS to 1LE - yes I searched first
I have searched but can't find a comprehensive, "this is what you need to convert your SS to a 1LE.
does anyone have that info?
I have a 2011 2SS.
Thanks
414whp, 403wtq (Mustang Dyno) -Thanks Ray/Full Throttle Kustomz
ramsman34 is offline   Reply With Quote
Old 02-15-2013, 04:35 PM   #2
PYROLYSIS
Remember the Charleston 9
PYROLYSIS's Avatar
I don't think anyone has done it yet. How far do you want to go? Just suspension and gear pieces, or transmission and fuel pump too. Lots more to be added if you're going full on 1LE.
Old 02-15-2013, 04:58 PM   #3
ramsman34
ramsman34's Avatar
I guess the whole way with either GM OEM parts, or duplicating the 1LE with aftermarket and GM parts.
I am already targeting the wheels, the front splitter, ZL1 side rockers and spolier. I have upgraded bushings already and might try to get similar/better handling from Pfadt/Pedders products. I am interested in the gears and possibly transmission and???
Old 02-15-2013, 05:40 PM   #4
scubadoo7
Airborne Recondo
scubadoo7's Avatar
Drives: Crystal Red 2SS 1LE
Are you aware of the 2013 Chevrolet performance catalog? Listed within are the 1LE 3.91 gear kit (22813040) and 1LE track pack (231023311). Of course, as pyrolysis mentioned, so many more components are needed to make a 1LE. Good luck with your build.
scubadoo7 is offline   Reply With Quote
Old 02-15-2013, 06:29 PM   #5
slick rick
SoCal Mayhem
slick rick's Avatar
Drives: 2010 Camaro 1SS/RS
Copied/pasted from multiple threads. I might have missed something
Camaro 1LE Track Pack NEW 231023311
Give your 2010+ Camaro SS or Camaro V6 greater capability in curves with
the same suspension components used in the production 1LE performance package. Contents include a larger, 27-mm solid front stabilizer bar, and 28-mm solid rear stabilizer bar for improved body control, as well as ZL1 wheel bearings, toe links and rear shock mounts for improved on-track performance.
the system includes:
part number Detail Qty
22812942 Front Stab Bar Asm (bar, links, bushing, clamp, nut) 1
22786260 Rear Stab Bar Asm (bar, bushing, clamp, bolt) 1
22761221 Rear Stab Bar Link 1
22812982 Front Strut Asm, LH (strut, spring, mount) 1
22812983 Front Strut Asm, RH (strut, spring, mount) 2
22981391 Rear Shock 4
22922445 Rear Shock Mount, LH 4
22922446 Rear Shock Mount, RH 4
22845487 Rear Toe Link 4
20941932 Rear Cradle Bushing, Front 4
20941933 Rear Cradle Bushing, Rear 4
23102312 Installation Instructions 4
Rear Lower Control Arm (SS, ZL1, 1LE) (2) - 20942237 (Needed for 2010-2011 car conversion)
Tremec TR6060-MM6 - 92246731
ZL1 Short-Throw Shifter - 19299460
1LE Differential Assembly (3.91 Ratio) – 22806794
1LE Ring & Pinion Set (3.91 Ratio) – 22813040
1LE LH Axle – 22806795
1LE RH Axle – 22806796
1LE Strut Tower Brace – 22756880
ZL1 wheel bearings -
ZL1 & 1LE Front Hub – 22924740
ZL1 & 1LE Rear Hub – 22924741
ZL1 Fuel Pump – 19260557 (superceded from 19258436)
PCV Oil Separator Kit - 12653073 - 23102311
1LE wheel front - 22798741
1LE wheel rear - 22798743
285/35ZR20 Goodyear Eagle Supercar G:2 tires front and rear
1LE splitter - 22950575
Black hood wrap
Black spoiler
Old 02-15-2013, 06:36 PM   #6
Synner
Drives: not stock
...and transmission cooler and lines.
Old 02-15-2013, 07:49 PM   #7
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
I can't find it at the moment, but someone posted the "conversion" price. Let's say it's not cheap...and not cost effective.
Mods are always a money loss anyway, but as long as you enjoy it, that's all that matters.
Perm-a-grin in place.....
JimE is offline   Reply With Quote
Old 02-15-2013, 08:09 PM   #8
Synner
Drives: not stock
When you consider the lost value of selling a 2-3 year old model for a new one you're looking at a loss of about 8-10k. So at that point it starts to make more sense if you can do all the labor. Its more for people who want to keep their car and have a history with it versus a financial benefit as you'd still lose money. Plus even if I got a 1LE I'd want to replace the shocks, sways, wheels, brakes, bushings and a bunch of other stuff as would most who become hardcore track junkies. Biggest expense is the transmission at 3.5k then the wheels at 3k. Might as well get forged wheel for 4-5k that are 5-8lbs lighter. And for the price of the tranny you could take the SS one and put in the same gear set, carbon syncros, etc etc. You could end up with something better but it'll cost you as I'm finding out since thats basically what I'm doing.
Plus they don't make them in green so screw that.
Old 02-15-2013, 08:45 PM   #9
cornerspeed92
cornerspeed92's Avatar
Drives: 2013 1SS 1LE
Wouldn't it just be cheaper to go 1LE SS all the way
cornerspeed92 is offline   Reply With Quote
Old 02-15-2013, 08:52 PM   #10
Synner
Drives: not stock
I think everyone is saying that. But if you're truly hardcore then you'll likely replace most of what comes with the 1LE too. If thats the case then the financial benefit starts going away depending on how far off the deep end you go. But thats probably .0005% of the people who buy a camaro. My only big regret is upgrading my sway bars before the redesign happened.
I would have gotten it if it were available when I bought. But trading in every couple years for the newest fastest thing is a good way to go broke with nothing to show for it. Trade in and get the 1LE now and then the 6th gen comes out and trade for that and then the 6th gen 1LE comes out and trade for that... It's a vicious cycle.
Old 02-15-2013, 09:44 PM   #11
Bad@ssCamaro
Rogers' Rocks :-)
Bad@ssCamaro's Avatar
Drives: 2015 1SS/1LE
2015 CRT 1SS/1LE RS/Recaro's/NPP/Nav/Rear vision pkg./BA speaker upgrade.
ARH 1 7/8 headers, CAI, BMR 1.25 drop springs, JPSS Billet Bushings, Peddars Cradle Bushings, DSS driveshaft ...421 whp...so far.
Old 02-15-2013, 09:55 PM   #12
ramsman34
ramsman34's Avatar
Thanks guys - lots of info. What I am really trying to do is duplicate the performance of the 1LE with some of the look by using a mixture of OEM and aftermarket parts. I have a MGW short shifter, Pedders bushings, OEM wheels coming...
I will probably go pfadt/pedders to get the same or better handling, get the OEM gears and decide what to do with my MG vs the OEM 1LE M6. I am getting some ZL1/1LE exterior stuff and some aftermarket stuff as well (not a fan of the murder hood), not sure about the axles, hubs, bearing etc. as am only just getting into track training.
Damn, I have already sunk almost $10K in mods into this beast as it is and still want to do a whipple + necc upgrades and possibly a smooth blower cam.
Destination: The $80k SS, LMAO
Old 02-15-2013, 10:51 PM   #13
Synner
Drives: not stock
That's the other benefit. Piecemeal is way easier to hide the total price from the wife. But its totally worth it to spank a Porsche at the track and laugh at their confused expressions as the American tank flies past them.
Old 02-16-2013, 12:44 AM   #14
FINALLYSATISFIED
Est.1775
FINALLYSATISFIED's Avatar
Drives: '15 Challenger Hellcat (sold)
Black hood wrap
Black spoiler
I believe this is missing a few things. For the OP for $3,500 its cheaper to buy an outright 1LE. Good luck with your build, keep us updated with pics and let us know the progress!...
FINALLYSATISFIED is offline   Reply With Quote
