SDTW Custom Wheels & Tires
Old 02-15-2013, 09:05 PM   #1
Nightmare2012
come find out;)
Drives: stockish 2012 camaro ss
BEST SIZE PUSHROD FOR MY BUILD HELP!?
Well i bought some magnum compcams pushrods 5/16x7.350 and now reading all these review im nervous they will blow or make too much noise because they are not the right size my cam specs are 231/243 617/624 lsa 115, heads ported polished and milled to 20 thousandth, valve springs with a lift of 650
Nightmare2012 is offline   Reply With Quote
Old 02-15-2013, 09:53 PM   #2
JEFF75645
Drives: his wife crazy buying mods
Nice cam choice.
Gone But Not Forgotten
JEFF75645 is offline   Reply With Quote
Old 02-15-2013, 09:55 PM   #3
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Will you be doing the build bud?
Your best way of knowing without a doubt is by measuring and making sure you got the right size. It's really easy.
You are milled so I'd measure or have the shop do it.
Old 02-15-2013, 09:57 PM   #4
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Oh yea nice choice!!
Old 02-15-2013, 10:10 PM   #5
Nightmare2012
come find out;)
Thanks jeff and litle i hope i get upwards of 460whp, ive seen the night fury pull it off hoping for the same result here. Thanks for the advice also ill have my tuner make sure its a safe pushrod or if i have to buy a new one, which i would like to avoid since i don't want to spend twice lol
Old 02-16-2013, 12:31 AM   #6
Fast6.3
Fast6.3's Avatar
Drives: 2016 2SS coupe 2015 3LT Stingray
You buy the pushrods afteryou check length once you have the headsbolted you take the measurement taking into account the preload the lifters you will be using require since you already have this i wouldnt buy anymore with out measuring there is no predetermined length with custom parts
Fast6.3 is offline   Reply With Quote
Old 02-16-2013, 01:58 PM   #7
JEFF75645
I was trying to buy up a bunch of stuff for my cam install and the shop had to tell me to stop. I was about to buy pushrods and they told me dont waste my time and money. It would be easier to let them measure and order the right ones than sending the wrong size back and replacing.
Good luck. And damn that cam is so close to the one im going with. Who specd that cam or is it off the shelf. Im very anxious to see the final numbers.
