Solo Performance
Old 02-16-2013, 02:25 PM   #1
Rocco70
THE YETI
Rocco70's Avatar
Drives: 2SS RS
catch can install
Just got my catch can but i wasn't sure if the check valve goes to the inlet of the can or the outlet. I believe its the outlet Also what did you guy use to cut the steal braided line.
Rocco70 is offline   Reply With Quote
Old 02-16-2013, 02:30 PM   #2
The Blue Ox
The Blue Ox's Avatar
Drives: 2010 SS L99 Inferno Orange
http://www.camaro5.com/forums/showthread.php?t=274191
Try this! Maybe it will help!
The Blue Ox is offline   Reply With Quote
Old 02-16-2013, 02:39 PM   #3
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
Cutting wire with diagonal cutters, commonly called dikes, u need to pey attenshun 2 where the waist end may not becausehardened wire, like instrument strings, can take off with spring-like intensity. If you’re cutting heavy wire, position the wire all the way in, at the joint between the jaws, for maximum leverage.
11.90's w/headers, CAI, tune, & some high-test (no bling).
Smirnoff is offline   Reply With Quote
Old 02-16-2013, 02:45 PM   #4
SC2150
Checkvalve goes on the outer fitting and connects to the intake manifold vacuum barb. The inner fitting gets no checkvalve in the line and connects to the crankcase (valley cover or rear of valve cover).
To cut, wrap w/masking tape tight at the spot to help keep the braid from fraying. A band saw, abrasive cut-off wheel, or like Smirnoff describes.
Most diagrams are on the website, lower left hand corner.
Old 02-16-2013, 02:49 PM   #5
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
From the my experience the tape and a cutoff wheel works best.
Sent from my HTC One X using Tapatalk 2
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline   Reply With Quote
Old 02-16-2013, 04:29 PM   #6
Rocco70
THE YETI
Rocco70's Avatar
Drives: 2SS RS
Thank guy for the replies im going to start the instal now. With the help im sure everything is going to go fine now. I just wish it wasn't 20 degrees out no heater in the garage.
Old 02-17-2013, 12:13 AM   #7
Rocco70
THE YETI
Rocco70's Avatar
Drives: 2SS RS
Well install went smooth just to help the next guy when cutting the hoses the inlet hose is cut at 14 1/2 inches. The outlet hose is cut at 15 inches this is for the braided line. I used a cut off tool wrapped the area tight with blue painters tape.The cut came out clean looks nice Im happy how it came out. Now one more thing the Vmax painted ported throttle body. Ill order that in a week or so then thats it for dress up under the hood.
Old 02-18-2013, 12:37 PM   #8
fastfreddie
FreakyFast!
fastfreddie's Avatar
Drives: 2010 2SS/RS S/C NicKey #55
Looks nice. I just ordered an Elite can. Contemplating the SS braided hoses or not. You going with a Summit White Throttle Body as well?
2010 2SS/RS #55 NicKey Stage 2S Super-Camaro custom painted by Pete (Mr. Showstopper)
Build Thread: http://www.camaro5.com/forums/showthread.php?t=250743
fastfreddie is offline   Reply With Quote
Old 03-12-2013, 11:46 PM   #9
Rocco70
THE YETI
Rocco70's Avatar
Drives: 2SS RS
Yes I am im waiting on it now cant wait should be here in a week or so.
Old 03-13-2013, 01:55 AM   #10
SSGUNNER
Chu no guat a hasa is?
SSGUNNER's Avatar
Drives: 14 Jeep G Cherokee Overland HEMI
Nice OP.
I have the same setup. I used a box cutter to cut the braided hose. Took a while.
11 2SS/RSL99No Longer Stock (Sold) 6/19/14:AAC Plasma DRL's | Plug n play harness | Elite CC | Tint: 35% & 5% | LED Dome light | Show-N-Go Plate Holder | Flowmaster AT | C.A.I. Intake | VMAX CNC Spiral Ported TB | Husky Splash Guards
SSGUNNER is offline   Reply With Quote
