Cold Air Inductions
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 02-16-2013, 04:36 PM   #1
KKreme15
KKreme15's Avatar
Drives: C6 Z06
Can this Black 10 spoke be repaired?
I don't know a whole lot about wheels, but I have a scratch around the edge of my rim, can this be repaired in any way?
KKreme15 is offline   Reply With Quote
Old 02-16-2013, 06:53 PM   #2
ZL1-V
ZL1-V's Avatar
Drives: 2013 Camaro ZL1
Just had two right side wheels out for repair and repainting after curbing the car in a loop around! It was a total of 400.00 for both wheels and It was much worse than your picture! What did you do? Is that dirt from water drying on dirt, or a crack on the inner portion of the wheel.
ZL1-V is offline   Reply With Quote
Old 02-17-2013, 10:54 AM   #3
KKreme15
KKreme15's Avatar
Drives: C6 Z06
Dirt
Old 02-17-2013, 02:24 PM   #4
c4maroboy
[HOONIGAN]
c4maroboy's Avatar
Drives: 2012 ZL1 #1848[The HOONIGAN MOBILE]
2012 ZL1 BLack M6 ECF
c4maroboy is offline   Reply With Quote
Old 02-17-2013, 02:45 PM   #5
BigBlock69RS
Ed
BigBlock69RS's Avatar
Drives: 2013 AGM Camaro 2SS/RS/1LE
Take a black wide sharpy marker and color it in. you would be surprised how much it will blend it after. You will only see it if you look for it or while cleaning wheels.
Don't ask me how I know.
BigBlock69RS is offline   Reply With Quote
Old 02-17-2013, 05:19 PM   #6
ZL1-V
ZL1-V's Avatar
Ha,ha, I did that with my CCW wheels. It worked!
Old 02-17-2013, 07:55 PM   #7
FINALLYSATISFIED
Est.1775
FINALLYSATISFIED's Avatar
Drives: '15 Challenger Hellcat
That's a quick fix so others don't notice it, but you'll always know its there. I did that trick to my ACS Splitter I had on a previous Camaro, lol.
FINALLYSATISFIED is offline   Reply With Quote
Old 02-18-2013, 07:04 PM   #8
c4maroboy
[HOONIGAN]
c4maroboy's Avatar
i was just gonna say that!
Old 02-18-2013, 07:21 PM   #9
newagemuscle
Philippians 4:13
newagemuscle's Avatar
Drives: SLP Supercharged LS3
You could always try Plasti-dip... that seems to be the fix all for everything on here. The answere to you question is yes.
newagemuscle is offline   Reply With Quote
Old 02-19-2013, 11:20 PM   #10
rmyers
rmyers's Avatar
Drives: Both American Made
Yes they can be repaired.... I had mine done, and the repair is flawless but the paint peeled after I tried some different wheel cleaner. I am not happy at all with the factory coat on the 10 spoke black wheel, so I am likely going to have the set powder coated.
2012 ZL1 #213 M6 Black on Black
2013 ZL1 #2638 Convertible Auto
2010 Chevrolet Suburban
2011 GMC Seirra HD Denali
rmyers is offline   Reply With Quote
Old 03-02-2013, 12:36 AM   #11
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
Drives: /\yes, this is me/\
If we work out the deal in the other thread where we hopefully split the rims. I will take your rear tire.
I am trying to get a extra set for track day use.
R.I.P. http://www.camaro5.com/forums/showthread.php?t=373249
Back Street Performance has done a great job with ALL my Performance & Suspension mods, highly recommend them (Rich@BSP) he's in my friends list. https://youtu.be/Lht8sKe1Maw
TLSTWIN is offline   Reply With Quote
Old 03-03-2013, 05:16 PM   #12
Nemisis
Drives: 2013 Ashen Gray Metallic-M6
These black wheels can be fixed at home cheap. I bought prep/cleaner to get all the grease and dirt off and then used fine grit sandpaper to get the scratches out, used dupli color de1634 I believe, it's a high temp engine enamel, satin black. All done and looks new.
Nemisis is offline   Reply With Quote
Old 04-03-2013, 10:44 AM   #13
EvilZL1
Snake Eater
EvilZL1's Avatar
Drives: 2012 AGM ZL1
Could you link the Dupli color and what grade of sandpaper?
Build Thread: http://www.camaro5.com/forums/showth...95#post8351295
Make sure you don’t forget to subscribe to my channel! More content on the way. Like, share with your friends
https://www.youtube.com/channel/UC9Z...sP2wjsLLFeP1zQ
Follow me on instagram:
http://www.instagram.com/snkeatr/
EvilZL1 is offline   Reply With Quote
Old 04-03-2013, 07:31 PM   #14
WhiteyChev
Drives: 2012 Camaro ZL1. 1/94 produced.
i believe someone once mentioned that GM had a black touch up paint for wheels.
WhiteyChev is offline   Reply With Quote
