Old 02-16-2013, 07:06 PM   #1
TheBandit18
TheBandit18's Avatar
Drives: 2010 Camaro 2ss M6
Cam install question
What all gaskets/seals so I need to replace is there any that are reusable on a cam install?
TheBandit18 is offline   Reply With Quote
Old 02-16-2013, 07:11 PM   #2
376LS3
Eh, that'll happen
376LS3's Avatar
Drives: 2010 2SS
Front cover gasket, water pump gaskets, red RTV for the corners, front main seal, and crank bolt. TSP sells a kit with everything you need.
2010 Camaro SS LS3 - No Modz
376LS3 is offline   Reply With Quote
Old 02-16-2013, 07:38 PM   #3
Fast6.3
Fast6.3's Avatar
Drives: 2016 2SS coupe 2015 3LT Stingray
If youre going with a 3 bolt cam you also need bolts and retainer valve cover gaskets are reusable but for the price i would change them also if youre doing lifters head gaskeys and bolts
Fast6.3 is offline   Reply With Quote
Old 02-16-2013, 07:44 PM   #4
Maxspeed
~COTW 6/30/14~
Maxspeed's Avatar
Drives: 2011 Camaro SS/RS
upgrade the timing chain
Mods: Heritage Grill, Blade Spoiler, Corrado Hoodliner Mural, Premium Engine Boxes, Radiator Shroud, Custom Painted Bowties, Dipstick & Engine Caps, RX Catch Can, Corsa cat back exhaust, CAI black powder coat cold air, Apex cold air intake scoop and Apex washer tank relocate kit, Dynatech SuperMAXX Ceramic Coated LT Headers, High Flow Cats, JRE470 Rough Idle Cam Package, DSS 1,000 RWHP Axels, Slowhawk Mustang Dyno Tune, QTP QTEC 66 Low Profile Cutouts and iTSX. 453 RWHP 427 RWTQ
WEB LINKS
BUILD
TIMING CHAIN FAILURE
TRANSITION FROM STOCK TO CAM VID
Maxspeed is offline   Reply With Quote
Old 02-16-2013, 09:16 PM   #5
TheBandit18
I need to replace the timing chain even though I don't have 10k miles on it? Why is that?
Old 02-16-2013, 09:36 PM   #6
Maxspeed
~COTW 6/30/14~
Maxspeed's Avatar
I had 3,500 on mine, 500 after cam install when it snapped. Read my timing chain link in my signature.
WEB LINKS
BUILD
Old 02-16-2013, 10:02 PM   #7
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
If your going in, upgrade. Do it once and right or pay twice.
These are the must get parts when doing a cam swap are
1) melling 10296 oil pump
2) C5r timing chain
3) ARP cam bolts (if your using a 3 bolt cam), don't forget a lil loctite on those and the retainer plate bolts.
You don't need valve cover gaskets though.
Old 02-16-2013, 10:04 PM   #8
Maxspeed
~COTW 6/30/14~
Maxspeed's Avatar
Don't forget an LS2 Dampener instead on the LS3 Tensioner
WEB LINKS
BUILD
Old 02-16-2013, 10:05 PM   #9
TheBandit18
Hmm... Ok I'll have to get that changed too. I need about $800 more until I will be ordering
Old 02-16-2013, 10:05 PM   #10
Camper
Banned
Drives: 10' 2SS LS3 M6
Dont forget Trunion upgrade
Camper is offline   Reply With Quote
Old 02-16-2013, 10:06 PM   #11
Camper
Banned
lol, you'll be in for about $1600 in parts when you upgrade everything you "should"
Old 02-16-2013, 10:23 PM   #12
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
Definately. I had to do mine later on when when one of the trunions broke down. Found two more close failing while I was doing the upgrade. The last couple needle bearings should be stuck to the oil drain plug now.
I don't see it mentioned but you will also need springs. And since a cam is about open the valves to get air and fuel flow, a cold air box will be needed so it can breath. And headers if you don't have them. Then a good tune.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
Old 02-16-2013, 11:02 PM   #13
TheBandit18
I already have the headers will be ordering CAI real soon then all the cam stuff
Old 02-16-2013, 11:21 PM   #14
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Yes I forgot to mention the suggestions after my post lol. Especially replacing the tensioner.
