SDTW Custom Wheels & Tires
Old 02-17-2013, 12:44 PM   #1
onebad1le
Drives: 2013 1le
obx headers leak
Well installed my headers and the drivers side leaks.
so far I have email OBX to see if they can be warranty
suck, I have changed to gaskets several times ,even different types
onebad1le is offline
Old 02-17-2013, 01:22 PM   #2
whitedemon
whitedemon's Avatar
Drives: 2010 Camaro SS
Where is the leak coming from? You should see black soot around the area
2010 Camaro 2SS/RS, L99, OBX Longtube Headers, Magnaflow 3in Comp Cat Back w/ added Dynomax Bullet Race Mufflers, SCT Tuner w/ JRE Tune, CAI Black Intake w/ JRE Race Scoop, Eibach Pro Springs, Custom Sequential Tailights
whitedemon is offline
Old 02-17-2013, 01:26 PM   #3
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
factory gaskets , they work best , i had same problem and put my old factory gaskets on and fixed.
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline
Old 02-17-2013, 01:46 PM   #4
whitedemon
whitedemon's Avatar
Agreed, defiantly use factory gaskets. Also if these are the first headers you have ever owned you will have to get use to the "header" noise. Headers make a hissing exhaust leak sound, that's normal
Old 02-17-2013, 02:55 PM   #5
SPCBA
Drives: pleather and Chiclets
are they warped? if the factory gaskets dont work then there is something wrong with the headers.
SPCBA is offline
Old 02-17-2013, 07:50 PM   #6
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
Thanks
11.90's w/headers, CAI, custom tune, slicks/skinnys, shifter & 100+ Ethyl.
Smirnoff is offline
Old 02-17-2013, 07:54 PM   #7
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Thanks +2
litle88 is offline
Old 02-17-2013, 07:57 PM   #8
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
I ask too if its your first set of headers on a car? If so you may be hearing header ping. Its really pronounced with a good camshaft.
Bo White is offline
Old 02-17-2013, 08:08 PM   #9
LS3 SS
LS3 SS's Avatar
Drives: 2010 Cyber Grey Camaro SS (LS3)
Before you panic, take your headers off, make sure your OEM gasket is good, and then when you go to bolt it back down, go from the inside out first. If it still leaks, contact OBX to see what can be done.
LS3 SS is offline
Old 02-17-2013, 08:13 PM   #10
Muscle SS
All blackkk
Drives: 2010 2SS/RS LS3
Pics?
Drivin it like I stole it.
Muscle SS is offline
Old 02-17-2013, 08:26 PM   #11
SPCBA
mr white and ls3 ss give sound advice and ask the right questions...only question i would ask is if you installed yourself? otherwise you need to contact your header dealer/manufacturer and get it resolved.
SPCBA is offline
Old 02-17-2013, 09:03 PM   #12
BlaqWhole
BlaqWhole's Avatar
Drives: 2017 Camaro ZL1 A10
How about some details and a little follow up? More than likely the header isn't leaking. Like was mentioned before, it's probably just that you aren't familiar with the sound headers make. It took me a good few minutes to get used to it. If it's coming from the engine and you used the gaskets that came with them...then the problem is the supplied gaskets. take them off and re-use you stock gaskets. That will solve your problem. If you did use the stock gaskets and you THINK there is a leak, then see if the CEL comes on or scan the ECU for a code.
Other things to check...make sure you seated the headers properly and bolted them properly...maybe they aren't tight enough. Use a torque wrench. Do not use those springs that come with the bolts for the extensions/cats. If you still aren't sure then start the engine and try to feel around the piped for a leak...DO NOT TOUCH the pipes tho, just put your hand close and feel for air in pulses. Good luck.
2017 Camaro ZL-1 A10 - Roto-Fab cai - Katech ported TB - MBRP Race catback - VTC!!
2017 Challenger Hellcat M6 - Legmaker CAI - MM ported TB - Sprint Booster!!
Saving the world...1 hp at a time!!
BlaqWhole is online now
Old 02-17-2013, 09:10 PM   #13
onebad1le
Drives: 2013 1le
leak
had the stock gasket on it and it leaked on driver side only . I could see the (black markings)
its not just sound-- when i tried to tune it the O2 sensor were off.
replaced with after market gasket and leaks worse...
im pretty sure its warped --just gonna throw them away
and just buy some new 2 inch headers form texas speed.
Old 02-17-2013, 09:24 PM   #14
BlaqWhole
BlaqWhole's Avatar
Tell you what, don't throw them away. Send them to me along with the receipt. I'll pay the shipping. Consider this dibbs!!
