Old 02-17-2013, 01:42 PM   #1
godeepdown
Jeremy Frye
godeepdown's Avatar
Drives: 2016 Hyper blue 1SS
Dupli-Color tire shine review
So I just installed new tires and thought I would try the new Dupli-Color tire shine coating. Washed and scrubbed the tires, taped off the wheels and did four coatings following the can directions. It is alot more work that the other tire dressings. I did it yesterday and the next morning here are the results. Im sure they would say I did something wrong but I don't care. It is a pain to do and it sux. I don't want a tire dressing that is that much work or that easy to mess up.
godeepdown is offline   Reply With Quote
Old 02-17-2013, 01:46 PM   #2
montreal2010yellow
montreal2010yellow's Avatar
Thanks for the info.
Old 02-17-2013, 03:28 PM   #3
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
Interesting, thanks for the review! Sorry it didn't work out for you.
Got a couple questions:
What did you clean the tires with and what did you use to scrub it?
What does the instructions on the bottle say on prepping the tires?
Thanks again!
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
Old 02-17-2013, 04:09 PM   #4
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Yuck, hope it's easier to remove than it was to apply. Looks like somebody sneezed on your tires.
[B]
Old 02-17-2013, 04:12 PM   #5
Frid
Frid's Avatar
Drives: '11 Camaro 2SS/RS LS3
Wow, that looks disgusting. Thanks for the review OP.
Frid is offline   Reply With Quote
Old 02-17-2013, 05:08 PM   #6
godeepdown
Jeremy Frye
godeepdown's Avatar
All the instructions say is a thoroughly with a high quality cleaner.
Not sure if that meant car wash, wheel cleaner, or what. I went with hot water and dish soap with a wash mitt, thought it would help remove any oily residue on the surface. Probably not what they had in mind but I want something that would fit in with my normal washing routine. I normally use a car wash liquid with a mitt. I thought the dish soap would be stronger. If I have to go out and buy a special cleaner etc.. Then I am happy with the way I have been doing it. With all the taping and waiting to spray coats it takes ten times as long to apply.
Thanks again!
Old 02-19-2013, 12:21 PM   #7
Blau camaro
Blau camaro's Avatar
Drives: #1 CAMARO FAN
If my tires looked like that I would get some Adams APC and remove that snot from the tires. Never been a fan of tire shine products. IMO they look much better with a nice clean black look.
Blau camaro is offline   Reply With Quote
Old 02-19-2013, 12:26 PM   #8
ihaveacamaro
I like teeth.
Drives: #198
gotcha, in my experience even dish soap is nowhere near strong enough to remove silicone containing dressings. In my opinion, that may have been the issue. But yeah as you said, whatever time you may save is spent just on the prep work lol.
Old 07-19-2013, 02:17 PM   #9
meissen
Founder - Michigan FBody
meissen's Avatar
Drives: 1994 Camaro LT1, 2016 Camaro LT
How dry were the tires? I was just checking to see if anyone else did a review before I posted, and I'm almost positive your tires were still damp when you applied the product or you had some residual tire shine product on the tires...
2016 Camaro 1LT V6 A8 - "Elmo" - LGX V6 with 8-Speed Automatic, NPP Dual Mode Exhaust
1994 Camaro LT1 A4 - "Red Alert" - v6-to-LT1 Swapped Cruiser; Cammed, Stalled, Enjoyed
"Gone But Not Forgotten"
2014 Camaro 1LT M6 - "Cherry Bomb"
2012 Camaro 1LS M6 - "Clifford"
Michigan FBody Association
http://www.mifbody.com/
meissen is offline   Reply With Quote
Old 07-19-2013, 02:46 PM   #10
kostnkost
Roof expert detail noob
kostnkost's Avatar
Drives: 2013 BRM 2LT RS
That kind of looks like a sunburn I got a few years back while roofing. Looks painful!
kostnkost is offline   Reply With Quote
Old 07-19-2013, 06:14 PM   #11
GEEKFREEKSCOTTY
Autoboticus Roboticus
GEEKFREEKSCOTTY's Avatar
Drives: 2011 Camaro 2SS/RS
Do NOT use this stuff (or Turtle Wax's version) anywhere near Plasti-Dip..
Just... don't.
GEEKFREEKSCOTTY is offline   Reply With Quote
Old 07-19-2013, 06:15 PM   #12
GEEKFREEKSCOTTY
your best bet is a good quality tire gel and an applicator.
Old 07-19-2013, 06:40 PM   #13
meissen
meissen's Avatar
Just... don't.
I just posted a review further down. I haven't had any problem on two of my cars, and I've had it on my 5th gen for over a month with over 1,000 miles. I'm positive something in the prep was done wrong on these tires (no offense to the OP) - either they were too wet or there was some past tire gel residue still on the tires.
That said -- I bet if the OP sprays another LIGHT layer of tire coat on the tires now that the brown will go away.
http://www.camaro5.com/forums/showthread.php?t=308140
I would NEVER use gel again after using this stuff - it works great and it lasts MUCH longer!
Old 07-19-2013, 11:14 PM   #14
kostnkost
kostnkost's Avatar
Just... don't.
Good to know! If this stuff does this to tires, I can only imagine what it would do to my dipped rims. I will stick to SVRT until I find something better. That might be a while though.
