Caryle Racing
Old 02-17-2013, 08:52 PM   #1
rahallfly
rahallfly's Avatar
Drives: 2010 2SS/RS
Advice Please, hoping rhino will see this lol
I just put in TSP VVT2 cam and AFM delete. TSP said i should not worry about upgrading timing chain. But after reading some more on here i am getting nervous. How many have the L99 that kept same gear on cam and stock chain and is it ok?
Oil pump?? replace?? all the problems have been LS3 any L99 oil pump problems?
I kept my stock chain damper instead of puttin on the block one. good idea?
Trunion upgrade with a VVT2 needed?
Thanks guys
TSP VVT2, OBX LTs Catless mids, Flowmaster, Half K&N, Half Fastlane Pipeline CAI, Tuned by RDP Motorsports! Thats the main fun adders
SHAKE ANNNNNNND BAKE!!!!!
rahallfly is offline   Reply With Quote
Old 02-17-2013, 08:58 PM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
You can PM Rhino as well. I'm not sure what NEEDS to be replaced but a lot of replacement parts people get are for peace of mind. I think I remember a post from him on what he feels NEEDS to be replaced. I'll look to see if I can find it.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 02-17-2013, 08:59 PM   #3
flyer08
Drives: 2010 2SS/RS
I did chain and oil pump just to be safe since was already changing stuff out
flyer08 is offline   Reply With Quote
Old 02-17-2013, 09:33 PM   #4
axis
Search Ninja
axis's Avatar
Here are a few quotes from the threads.
Throw the afm lifters as far as you can, go pick up some ls3 lifters, 4 ls3 trays, an ls3 valley cover, a phaser restrictor and the vvt grind of your likeing. You wont be disappointed.
Ok. The afm lifters are weak. That has nothing to do with the vvt though. Once ls3 lifters are installed, you're set. My valve train consists of the mast ss cam, stock rockers, stock ls3 lifters, stock pushrods, comp beehives, and comps phaser limiter. Rev limit is at 7200, and I shift at 6900-7000. Durability has not been an issue and I drive my car daily. I drove it to the track too. I found 20 rwhp with just cam phaser changes on the dyno.
Stock pushrods arent weak, they just arent the right length with many aftermarket base circle cams. I have proven, over and over all the bs myths about the oil pump, timing chain, rod bolts, pushrods are just that....myths. Are those nice compliments and upgrades, yep, are they always needed....no.
Halltech CF 102 fed
Old 02-17-2013, 09:54 PM   #5
rahallfly
rahallfly's Avatar
Drives: 2010 2SS/RS
Thanks axis. I have my engine almost completely back together only thing not on is water pump and radiator. I have already replaced lifters and everything else in the package. I just didnt do oil pump, because common problems have been on LS3 Oil pumps.
Thats why i was asking about cam chain with stock gears on cam and crank and trunion upgrade. those are whats on my mind unless someone has seen a L99 oil pump stop ??
Old 02-17-2013, 11:25 PM   #6
axis
Search Ninja
axis's Avatar
Personally, i'd change them but I'm more of a overbuild it kind of person. It's much cheaper and easier to do it NOW, while it's already apart than to have to possibly redo it later.
Halltech CF 102 fed
Old 02-18-2013, 07:26 AM   #7
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
Use the LS2 damper not the stock tensioner. Yes a C5R timing chain and trunion upgrade will be worthy additions. Just be aware even when you build stuff right using good parts and install sh!t can happen. Overbuilding with the best parts lessons the chance of this. More on that in a few days after I tear into mine a little.
Old 02-18-2013, 07:50 AM   #8
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
If your spinning to 7k+ pushrods and a dual spring are a must for proper valve control. Especially on a VVT cam. Just my .2
Old 02-18-2013, 08:56 AM   #9
rahallfly
rahallfly's Avatar
Drives: 2010 2SS/RS
Dual springs and new chromoly push rods were installed with this kit. Trunion upgrade is my question?
Thanks for the advice guys
Old 02-18-2013, 11:31 AM   #10
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Rhino has told me on the phone once or twice that he's not a fan of the L99 lifters, and thinks they should be changed out for a cam.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 02-18-2013, 11:39 AM   #11
Synner
Drives: not stock
Oil pump in L99 is fine. Chain is fine too. Your money would be better spent on an ATI damper. I think the trunion upgrade is good for anyone running their engine hard or adding power.
Old 02-18-2013, 11:40 AM   #12
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
If you can spare the money, why not? I'd do it.
Old 02-18-2013, 02:40 PM   #13
Fast6.3
Fast6.3's Avatar
Drives: 2016 2SS coupe 2015 3LT Stingray
I have am l99 dealer just replaced oil pump 20000 miles
I have the trunnion upgrade on another build and i highly recommend it its cheap and takes a couple of hours to do it if you can i would also change lifters and ouil pump if your keeping vvt idont think you can change the sprocket
Fast6.3 is offline   Reply With Quote
Old 02-18-2013, 02:41 PM   #14
Fast6.3
Fast6.3's Avatar
+1
