Jason 98 TA
Old 02-18-2013, 06:53 AM   #1
MauiSS
MauiSS's Avatar
Drives: 2011 Black/Black 2SS A6
Mounting MSD bap
I am planning on getting the SLP SC soon and was wondering where most of you using the bap are mounting it. Any pictures would also be helpful.
MauiSS is offline   Reply With Quote
Old 02-18-2013, 09:25 AM   #2
2SSCAMARO
2SSCAMARO's Avatar
Drives: 2010 Camaro Auto
MSD BAP Install
I installed it under the rear seat on the driver's side, run the power wires directly to the battery in trunk and the wires that go to the FPCM along the existing bundle under rear seat. The pressure hose to the MAP is routed along the L/H side of the floor pan beneath the interior trim and through the firewall via an existing plug near the brake reservoir that can be drilled and used as a gromet for the MAP hose.
2SSCAMARO is offline   Reply With Quote
Old 02-18-2013, 09:36 AM   #3
TinyToasta
TinyToasta's Avatar
Drives: way too fast....
here u go!
custom build forged LSA, 379ci, TVS2300@15psi, 696rwhp/688ft-lbs, built by DH Individual, Customkingz, tuned by Jannetty Racing
JRE rough idle cam, JRE ported lower intake manifold, OD cog drive, 6% OD crank pulley, ported ls3 heads, NW102mm TB, 1/2'' RDS spacer, IW 8-rib drive
Pfadt Cradle Bushings, Arms & Rods, Pedders Supercar w/FE4 conversion, ZL1 sways, HE Twin Carbon Street Slayer, ZL1 Rear End (3.73)
CTS-V Brake upgrade, Street: 22'' Vossen CV1, Strip: 18'' Forgestar F14 on MT Street Radials
TinyToasta is offline   Reply With Quote
Old 02-18-2013, 12:44 PM   #4
MauiSS
MauiSS's Avatar
Thnaks a lot 2SSCAMARO and Tiny Toasta, both good places. Tiny where are you running your hose through? Anyone else have a different location?
Old 02-18-2013, 01:36 PM   #5
2SSCAMARO
2SSCAMARO's Avatar
You're welcome. One advantage to installing the MSD unit under the rear seat is that you can leave the USB cord permanently plugged in to the MSD unit coiled up and stored under the trim at the front of the back seat. It will then reach the center console where you can change programming and view the data in live time. The MSD software will not record and save the data in a log form but it will display the voltages and boost in live time as you are driving. I exposed the cord a bit for your viewing.
Old 02-19-2013, 01:02 AM   #6
MauiSS
MauiSS's Avatar
Thanks again 2SS that makes sense. I think I got my mounting spot.
Old 02-19-2013, 06:55 PM   #7
PaulT
Drives: LS7 2SS RS
Mounted mine in the trunk just over the driver side wheel well. Not sure how to insert picture.
PaulT is offline   Reply With Quote
Old 02-19-2013, 07:57 PM   #8
MauiSS
MauiSS's Avatar
Thanks PaulT.
Old 04-12-2013, 05:43 PM   #9
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
I like the rear seat location. Thanks for posting.
Iam Broke is offline   Reply With Quote
Old 12-10-2014, 01:13 PM   #10
ZL1Naboz
ZL1Naboz
ZL1Naboz's Avatar
Drives: '13 ZL1,'15 BMW X5 and '15 Chevy SS
Anybody have a close image of the red/white wire going into the FPCM?
If I am thinking correctly the end of the red/white wire to the FPCM plug is the fuel pump side? this gets the RED wire from the MSD box. And the wire going back up the harness is the switched side from the fuse panel? which gets the ORANGE Wire from the MSD Box
just want to make sure I grab the right wire
Rotofab CAI, Big Gulp & Washer Bottle Relo, MGW, Kook's w/Hiflo Cats, SCT4, Jannetty, 35% tint, Oracle Side Markers, MTX Sub, Escort 9500ix - Blendmount, 18% Lower, ATI Super Damper, ID850 Injectors, Moroso Catch Can, MSD BAP, AFCO Heat Exchanger
Pre-Pulley Dyno
559.92 RWHP 519 RWTQ
ZL1Naboz is offline   Reply With Quote
Old 12-10-2014, 03:50 PM   #11
SSawdusty
Crewel Jewel
SSawdusty's Avatar
Drives: RJT-2SS-RS-6M
Heres a thread I did on my Whipple install. Page 2 has the MSD installation.
Hope it helps.
http://www.camaro5.com/forums/showthread.php?t=211238
Whippled
SSawdusty is offline   Reply With Quote
Old 12-11-2014, 10:09 AM   #12
2SSCAMARO
2SSCAMARO's Avatar
Your understanding is correct. Cut the red/white near the FPCM plug and connect the red from the MSD to the cut end of the wire that is still connected to the plug.Then the MSD orange to the remaining cut end of the red/white.
Just livin' life
