SDTW Custom Wheels & Tires
Old 02-19-2013, 12:58 AM   #1
11Huggerwhite
11Huggerwhite's Avatar
Drives: 2013 Camaro SS supercharged
Stroking to a 427
I just bought a 2013 SS LS3 and have put around 2500 miles on it. I want to stroke the motor to a 427, I will be staying N/A. I ordered a TSP 235 cam and 2" headers. I have a Hennessey intake installed. I want to know how much more horsepower I will get from the stroker with my header and cam set up. I'm going to use the Texas Speed 427 kit thanks for the help.
11Huggerwhite is offline   Reply With Quote
Old 02-19-2013, 01:22 AM   #2
429
Drives: 2010 camaro ss
Having been there and done that, go with a 416, and not a 427. Your engine internals will thank you for it. The longevity isn't quite there with the long stroke on a stock sleeve (though if its a sunday driver, you'll be fine)
429 is offline   Reply With Quote
Old 02-19-2013, 01:45 AM   #3
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
Correct since the factory sleeves do not go down far enough to properly support more than 4.000 stroke.
Old 02-19-2013, 01:46 AM   #4
11Huggerwhite
I drive it a lot. So how much hp would I probably be looking at with the cam and headers. I'm going to add some good heads later on. Thanks
Old 02-19-2013, 01:58 AM   #5
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
A few have made over 500whp NA but you give up some driveabilty to do so. It requires a large cam and ported heads. Then you have to look at a better clutch and quite a few suspension mods to keep it planted. The question is, how much do you want to make and what are you willing to give up to do so.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 02-19-2013, 02:02 AM   #6
11Huggerwhite
I really don't care about the money but I don't want FI. I don't care about the driveabilty either. I want to stroke the motor and forge it for nitrous later on.
Old 02-19-2013, 03:32 AM   #7
Bo White
Bo White's Avatar
4.000 stroke will get it done.
Old 02-19-2013, 03:37 AM   #8
11Huggerwhite
How much Hp should that put me at? Is that a 418ci I've never stroked a motor before sorry for the stupid questions. What pistons do you recommend for a N/A stroker? Thanks
Old 02-19-2013, 03:52 AM   #9
Bo White
Bo White's Avatar
I'm a cp fan but also like mahle pistons. A 416 is a STD bore and 418 is the next bore up on the stroker size.
Old 02-19-2013, 05:23 AM   #10
csjcsj
csjcsj's Avatar
Drives: 2010 Camaro SS/RS 6spd
With my 416 and Vengeance Racings KaotiK cam, I am at 500/508! Does that help any!
csjcsj is offline   Reply With Quote
Old 02-19-2013, 06:25 AM   #11
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
STOP Your doing it wrong, so if you want to get it right START doing some reading and get a goal.
Nobody knows exactly what hp your going to make, first you want to stay NA then you wanna add a lil spray later, well a builder would need to know how much spray you want to put on it to choose the right piston for you. Also the right cam! That cam is a baby cam for a 416! It's gonna need a manlier cam than that. Your going to need better heads to achieve a goal and keep up with the added CI's so nobody will know how much hp you'll be leaving on the table but since money is not an issue then get some MAST or a small bore Ls7 head.
Need a goal and some knowledge to do it right the first time bud, or you'll be paying twice. Just saying.
Old 02-19-2013, 07:54 AM   #12
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
Bo -- FYI, I have 2 price quotes from very reputable hipo shops that 100% support forged 427 internals on a stock block.....claim to install everyday?
11.90's w/headers, CAI, custom tune, slicks/skinnys, shifter & 100+ Ethyl.
Smirnoff is offline   Reply With Quote
Old 02-19-2013, 08:48 AM   #13
axis
Search Ninja
axis's Avatar
Do they include the sleeves to extend the wall down to accomodate the longer stroke? As has been said here and from many of our trusted vendors, the stroke required for a 427 will drop the piston too far down. Thats not to say it hasn't been done, but it's not the safest.
Halltech CF 102 fed
Old 02-19-2013, 09:08 AM   #14
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
I agree 4inch stroke on stock sleeves. The reliability of a 416 far outweighes the small HP gain from a longer stroke 427. If its a resleeved block then sure you can go longer stroke and since its staying NA even a bigger bore for 440+ ci.
