Old 02-20-2013, 12:34 PM   #1
ebaugh1990
Permagrin since 2/11/13
Drives: '13 Camaro 1SS/RS L99
Short tube header install
I saw a video a while back on installing long tubes but is disconnecting the steering shaft really necessary for short tube install?
'13 Camaro 1SS/RS-L99
JBA Off Road Mid-Pipes
SFX Performance O2 Extenders
JBA 3" CAT-BACK Model 40-3114
Cold Air Inductions intake (near-chrome)
http://www.youtube.com/watch?v=9o-6g...ujjgV9wZo9jnXw
I agree, my car without cats doesn't smell like rotten eggs, it smells like high octane Bad@ssness emitted through a natural speaker producing "Muscle Car Music"
ebaugh1990 is offline   Reply With Quote
Old 02-20-2013, 01:04 PM   #2
SPCBA
Drives: pleather and Chiclets
i sure as hell hope not...no reason on these cars plenty of room.
SPCBA is offline   Reply With Quote
Old 02-20-2013, 01:15 PM   #3
ebaugh1990
Alright, thanks man. The video I saw they removed all kinds of stuff. Then looking at my cars engine bay, it seems there's plenty of room to do stuff.
Old 02-20-2013, 01:31 PM   #4
BlaqWhole
BlaqWhole's Avatar
Drives: 2017 Camaro ZL1 A10
I think ARH recommends removing it...I installed OBX headers and didn't have to remove it.
2017 Camaro ZL-1 A10 - Roto-Fab cai - Katech ported TB - MBRP Race catback - VTC!!
2017 Challenger Hellcat M6 - Legmaker CAI - MM ported TB - Sprint Booster!!
Saving the world...1 hp at a time!!
BlaqWhole is offline   Reply With Quote
Old 02-20-2013, 01:37 PM   #5
ebaugh1990
I hear ya. Only thing that sucks is ill be doing the install, if I buy them, on jack stands. I gotta wait till i can find an oil reservoir for my two post frame lift. So I can't use it till I find one
Old 02-20-2013, 03:03 PM   #6
A.R. Headers
A.R. Headers's Avatar
Drives: Pontiac G8 GT
Ebaugh1990, If you go with ARH shorties you don't have to remove the steering shaft but you do have to raise the engine on the drivers side to slide the header in from the top. There's only one bolt holding the mount underneath and it's very easy to access. The reason this is the case is because we did everything in our power to design the headers as close to equal length as possible. Most shorties have at least one tube on each side that hardly has any length. Our shortest tube is 7-1/2". Then we added a merge style collector with a scavenger spike and you now have a shorty so unique it was awarded a patent. PM me a phone number and I'll call with more information if you're interested. Thanks
Nick
A.R. Headers
631-608-1986
www.AmericanRacingHeaders.com
100% USA MADE
A.R. Headers is offline   Reply With Quote
Old 02-20-2013, 03:08 PM   #7
ebaugh1990
Nick
A.R. Headers
631-608-1986
Thanks For the Info Nick!
I appreciate it man.
Old 02-20-2013, 04:29 PM   #8
HoustonHotRod
Drives: 2010 Camaro SS IOM The Vixen
I just did this install a couple of weeks ago , and I tried for an hour to work past the steering shaft but couldn't. Needless to say I ended up moving the shaft , which is really not hard at all. It only requires removal of 1 nut and bolt and pushing up on the steering shaft. Wished I had done it prior to the install.
HoustonHotRod is offline   Reply With Quote
Old 02-20-2013, 04:54 PM   #9
heymatt
heymatt's Avatar
Drives: 2012 IBM 2SS Vert.
Had to disconnect the steering shaft with my DT shorties. Not a big deal. I did mine with solo hf cats, on jack stands, by myself. First time on a gen 5, took me six hours. Could definitely improve that time if I had to do it again!
LS3/M6 K&N, VMAX throttle body, RX Catch Can, skip shift eliminator, DT shorties and Solo HFC, DRL harness and 5K LED DRL, ZL1 rear sway, 1LE front sway
heymatt is offline   Reply With Quote
Old 02-20-2013, 05:09 PM   #10
ebaugh1990
Thanks for the info guys. I guess I was afraid of screwing something up by undoing the steering shaft.
Old 02-20-2013, 05:27 PM   #11
HoustonHotRod
Lol , I know the feeling, but after I moved the steering shaft the header slipped right in. To make it even easier u might want to remove the spark plugs. If you bang one of those u could damage it.
Old 02-20-2013, 05:29 PM   #12
HoustonHotRod
Also, will you be installing high flow cats?
Old 02-20-2013, 05:35 PM   #13
kevint
Drives: 2013 1SS
Nick
A.R. Headers
631-608-1986
patent number?
kevint is offline   Reply With Quote
Old 02-20-2013, 05:43 PM   #14
ebaugh1990
No I'll be using the JBA Catback with the JBA Off road/cat delete pipes
