Old 02-20-2013, 01:14 PM   #1
Yeti
Yeti's Avatar
Drives: Summit White RS
30k injector throttle body cleaning?
My dealer recommended that the throttle body and injestors be cleaned at 30k miles. Not sure if this is the place to post this or not? Not that I dont believe them... lol, but just wanted your guys input. Around $210 for the job.
Yeti is offline   Reply With Quote
Old 02-20-2013, 01:23 PM   #2
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Throttle body is incredibly easy to do yourself. Not sure about injectors. I'm at 34k and haven't done them. But I also havent taken my car to a dealer in over 15k miles.
Sent from my SAMSUNG Galaxy S III using telekinesis.
BaylorCamaro is offline   Reply With Quote
Old 02-20-2013, 01:38 PM   #3
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
Yup this is in my 40,000km service. Ive never brought it to the dealer apart from first oil change and really dont want to give them my car.
It states its engine top cleaner
Check your manual. Debating on what to do, rather seafoam it my self
CAMARO
Old 02-20-2013, 02:23 PM   #4
Yeti
Yeti's Avatar
This is my daily driver and gets around 300 miles put on it each week. Just want to make sure that I am keeping up with the up keep of the car. I always have taken the car to the dealership for oil changes, yes I know that its cheaper to get it done else where. Need to stop, but they take such good care of it..... keeps me going back for the litle extra cash. Just wanting input on what you guys think.
Old 02-20-2013, 02:28 PM   #5
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
If you don't mind paying, I'd definitely go get it done.
Old 02-20-2013, 02:39 PM   #6
SC2150
I think they are reffering to an upper induction cleaning serivce. Put on a RX catchcan and you will never need it again.
Old 02-20-2013, 03:26 PM   #7
Yeti
Yeti's Avatar
Got a rx catch can on her. Put it on with in the first few months of having it.
Old 02-20-2013, 08:10 PM   #8
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Then I wouldn't bother with the dealer for this service. There's nothing to foul the intake or valves without the oil getting in there.
You don't need this service if you have the proper catch can installed, and you do.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 02-20-2013, 09:11 PM   #9
nikos30
HT5 EastSide
nikos30's Avatar
Drives: 2010 Camaro 2LT
if we put the catch can on it, will the oil that we already have in it eventually go away some how or will I have to clean that?
nikos30 is offline   Reply With Quote
Old 02-21-2013, 01:05 AM   #10
JohnnyBfromPeoria
It'll have to be cleaned out. Nothing but air (and oil, if you don't have a catch can) goes through there, all the way into the cylinders.
John B.
Old 02-22-2013, 01:37 AM   #11
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
Hold on, so if you have a catch can. You will have ZERO carbon build up? That doesnt seem to make sense to me
CAMARO
Old 02-22-2013, 07:29 AM   #12
BaylorCamaro
Track > 1/4 Mile
Drives: 2016 C7 Z51
No. Just not nearly as much. Thus not needing to be cleaned as often.
Old 02-22-2013, 07:49 AM   #13
SC2150
Not just ant catchcan.....were talking the RX catchcan that traps all, or nearly all the oil from ingestion. Most allow as much or more through than they trap.
And yes, if installed when new, we have a customers car (LLT DI) w/62k miles last we looked and the only deposits are a light colored coating we attribute to the other combustion byproducts as it has not changed the shape of the valve or port like the oil caused ones do.
Tell me your thought of why TJ91, and it will help me understand how your looking at it..here is a good thread with pictures of all:http://www.camaro5.com/forums/showth...=265217&page=4
Here are some pictures.
Anyone with a LS3/L99, remove your TB and look inside your IM and see what is ingesting. This car came the next day after delivery from the dealer:
Picture of SC and housing using a RX catchcan from day one for 16,000 miles VS a intercooler after 14,000 miles w/no can:
Scouring on pistons from carbon breaking loose:
Oil ingestion causes buildup on the piston rings and ring lands preventing them from moving freely to properly seal...resulting in loss of power and excess oil consumption:
Actual pictures from GM TSB:
Below is a LY7 3.6l GM V6 port injection with 140,000 miles:
Intake from LLT on left w/can from new, right w/out:
Old 02-24-2013, 10:28 PM   #14
rsflyer
rsflyer's Avatar
Drives: 2010 VR 2LT/RS A6
Arrow Ditto...
Regardless of having a CC oil vapor will still get into the intake. It will still get mucked up... only a bit less so than stock.
If one is under warranty it is a good idea to get the dealer service.
Documentation of dealer service performed... priceless.
Just my 2-cents... deposited.
rsflyer is offline   Reply With Quote
