Old 02-20-2013, 10:49 PM   #1
TheBandit18
TheBandit18's Avatar
Drives: 2010 Camaro 2ss M6
Question in cam power
I have a friend that has a 2012 camaro has headers, CAI and cam. Before the cam he was making like 416rwhp and after he was making around 460rwhp. (his cam is the biggest you can go without flycutting)
My question is, is 50rwhp really good or is something wrong? Seem like thats not much power for a big cam.
whats the average gain in cams?
TheBandit18 is offline   Reply With Quote
Old 02-21-2013, 12:50 AM   #2
SSMickey
SECC
SSMickey's Avatar
Drives: 2010 IBM 2SS
Hard to say really. What was his baseline power before anything was added? I just got mine back from Vengeance tonight. Gained 90 rwhp over stock. The tune has a LOT to do with it.
Vengeance Stage II Cam, Halltech CAI, RX Catch Can, Full ARH Exhaust, QTP Cutouts, Powerbond 25% Underdrive, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 02-21-2013, 09:19 AM   #3
rahallfly
rahallfly's Avatar
Drives: 2010 2SS/RS
416 with headers and cai sounds really high but it all depends what cam u run. Do u know what the specs are and who makes it ? That gain doesn't seem right tho from 416 prior ...
rahallfly is offline   Reply With Quote
Old 02-21-2013, 09:25 AM   #4
Nightmare2012
come find out;)
Drives: stockish 2012 camaro ss
Night fury cam owners make 500rwhp with almost identical mods im hoping for the 500rwhp once my cam goes in so ill give you my personal experience on the subject
Nightmare2012 is offline   Reply With Quote
Old 02-21-2013, 10:19 AM   #5
TheBandit18
He has a tune on it too. I don't know the specs it was a custom grind. He said the guy does this cam a lot.
Old 02-21-2013, 10:29 AM   #6
Juiced1
Juiced1's Avatar
Drives: 2012 2SS CAMARO 45th
Don't forget there are plenty of factors involved here as well. You can define a cam as "Big" a couple different ways too. He could have a ton of lift on the cam but less duration.....The tune could be very conservative.....It could be a "BIG" cam for an L99 or mabye the stock springs (not advised by the way).....Or just a big cam for the street.....or it can be a tighter dyno that reads low. Either way, 50 rwhp out of a cam isn't a bad gain.
GET MORE POWER PER DOLLAR!!!
We carry all the hottest brands for your Gen5 and Gen6 Camaros! Get awesome deals on Corsa, SLP, ARH, SW, Whipple, Kooks, Procharger, CAI, K&N, Rtoto-Fab and much more! Call us for your CAMARO5 discount today!
224-63-JUICE OR INFO@JUICEDMOTORSPORTS.COM
Juiced1 is offline   Reply With Quote
Old 02-21-2013, 11:01 AM   #7
TheBandit18
It's an m6 ill have to figure out all the specs for it. He said it is a little bigger than the tsp 231/236
Old 02-21-2013, 11:07 AM   #8
DuskSS
Bayou City Muscle Cars
DuskSS's Avatar
Drives: 2013 2SS Dusk Edition
Yup mines going to Lethal for the 500rwhp treatment next month.
They are so busy the first available appointments were mid next month.
Man.. the days are DRAGGING...
all i can do is watch NF cam videos and think about it..
ugh...
Lethal Racing Stage V
PER 418ci Forged LS3
530/520 SAE
DuskSS is offline   Reply With Quote
Old 02-21-2013, 11:11 AM   #9
Jason P
Jason P's Avatar
Drives: 2011 2ss
I have a 231 / 243 in my m6 and it kind of sucks to drive with the stock gears. I love the sound of the cam and the power it makes once it gets moving so now I'm going with 3.73 gears and a supercharger. I guess what I am saying is you may consider gears with that large of a cam.
2011 2ss Ram twin plate ceramic clutch, Texas speed 418 LS3 235 /243 .621 / .624 cam, ported and polished heads with dual springs,magnum push rods, Hotchkis race pack, Stainless Power long tube headers with no cats, Magna Flo competition exhaust, lpe fuel pump, magnuson supercharger with overdrive and port matched blower plate, IW 8 rib pullies, AEM meth kit, id 850 injectors, 3 bar map, halltech cai, zl1 rear diff
Jason P is offline   Reply With Quote
Old 02-21-2013, 11:21 AM   #10
DuskSS
DuskSS's Avatar
the thought has crossed my mind but want to drive it first and see how it feels.
Lethal did say it should be fine on stocks.
530/520 SAE
Old 02-21-2013, 12:54 PM   #11
SC2150
Was the cam degreed when installing? Most shops install dot to dot, and that may or may not be degreed correctly. Always check. Also, most use a preselected pushrod length and that is a guess as well. You can't guess on the proper preload and push rod length to achieve this, has to be the last thing measured for.
All will effect the power made from a cam swap.
Old 02-21-2013, 02:17 PM   #12
Ivan @ Southwest Speed
A gain of 50 would be pretty good actually.
Remember a dyno is a tool used to measure so, "what he had coming in and coming off" are going to be quite relative.
Gaining 50 is about the norm for most regular/mild swaps.
You can drop a LS9 cam in, get 20/25 all day long while you could drop a G6X3 or one of our SWS II's in and see 75/80.
Tuning will make all the difference in "max effort" cams and thats where you'll see the difference of a "I only made 50" as opposed to "I hit 500 rwhp!"
Remember, those two statements above, can actually mean the same exact thing as well.
Baseline, reference, and measuring stick. That's what were talking here when we are dealing with Before and Afters.
GL and let us know if you're ever needing more help. This is what we do well.
Old 02-21-2013, 03:39 PM   #13
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
416rwhp on a M6 car with LTs/intake/tune is about were it should be. Mine makes 411.
Old 02-21-2013, 04:13 PM   #14
Kelly@PCMofNC
Drives: 2010 RS/SS
Yep. Totally normal numbers on a Dyno Jet, right where it should be.
The after cam numbers seem fine too. A lot depends on specs and tuning, but generally cammed LS3 cars with all the bolt ons will end up in the 460-470 range on a dyno jet.
Here's a link to a car we did showing similar numbers. Cold air intake, Kooks longtubes, underdrive pulley and custom cam. Fantastic power gains and stock driveability!
2010 LS3 Custom Cam
Kelly - sales@pcmofnc.com - 704-307-4227 www.pcmofnc.com
Kelly@PCMofNC is offline   Reply With Quote
