Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > International Regions > Deutschland
Old 02-21-2013, 08:11 AM   #1
rx-hawk
rx-hawk's Avatar
Drives: 2SS M6
Euro plate mounts?
Anyone know where to get a mounting kit for euro style plates? Especially for the front of the 2010+ camaro. Mine doesn't even have the mount for US style plates up front, so there is nothing to bolt onto.
2011 Black 2SS/RS - Kooks headers, GM Performance Exhaust
rx-hawk is offline   Reply With Quote
Old 02-22-2013, 12:04 PM   #2
zcorvette04
zcorvette04's Avatar
Drives: 2012 Chevrolet Camaro 2SS/RS
You can buy plate mounts from several vendors on here and then modify them. Where are you at in Germany PM me and I might have a few other semi legal ideas I'm a MP so I know some tricks lol
zcorvette04 is offline   Reply With Quote
Old 02-22-2013, 12:17 PM   #3
TinyToasta
TinyToasta's Avatar
Drives: way too fast....
You'll get plate mounts from any Camaro Dealer in Germany, shouldn't be an issue.
If you don't wanna drill holes into your car you might also want to consider mounting your plate on the lower grill using clips or cabls/wires...
I didn't bother and drilled holes into the front bumper and screwed it on - as I'm not allowed to remove it anyway
custom build forged LSA, 379ci, TVS2300@15psi, 696rwhp/688ft-lbs, built by DH Individual, Customkingz, tuned by Jannetty Racing
JRE rough idle cam, JRE ported lower intake manifold, OD cog drive, 6% OD crank pulley, ported ls3 heads, NW102mm TB, 1/2'' RDS spacer, IW 8-rib drive
Pfadt Cradle Bushings, Arms & Rods, Pedders Supercar w/FE4 conversion, ZL1 sways, HE Twin Carbon Street Slayer, ZL1 Rear End (3.73)
CTS-V Brake upgrade, Street: 22'' Vossen CV1, Strip: 18'' Forgestar F14 on MT Street Radials
TinyToasta is offline   Reply With Quote
Old 02-22-2013, 12:21 PM   #4
zcorvette04
Boo holes in the grille are painful. But yes if you are patient you can zip tie it to the lower grille just don't get caught because it is illegal so hide the ties well
Old 02-22-2013, 02:21 PM   #5
rx-hawk
rx-hawk's Avatar
Drives: 2SS M6
I'm at Wiesbaden. Any dealers around here?
Old 02-22-2013, 10:12 PM   #6
zcorvette04
Aafes sells the euro plate mounts and zip ties if that's what you are looking at
Old 06-04-2013, 09:51 AM   #7
Sharp-ZL1
MSG,Retired US. ARMY
Sharp-ZL1's Avatar
Drives: 2012 ZL1, 11 XC 90, 15 BMW 328i SW
I made my own and mounted it to the screws on the bottom of the front splitter.
Check out our FB Page I am in K-town
https://www.facebook.com/AmericanCar...ax_wizard=true
My build site:
http://www.camaro5.com/forums/showthread.php?t=276256
2012 Camaro ZL1 #151, GCN, Dyno results 701 RWHP
Mods; 2.55 Pulley, CAI, LG Cam Package Ti Springs and 9G2X Cam, RX Can, KDI Heat exchanger, Hurst shifter, Orcale Ghosted marker lights, Kooks Long tube headers with Cats deletes and Tuned by Kraftwerks, Pedders 1 inch lowering Springs, Front and rear sway bars, Rear cradle bushing, BMR Trailing arms and toe rods.
Sharp-ZL1 is offline   Reply With Quote
