ADM PERFORMANCE
Old 02-21-2013, 10:43 AM   #1
Larz29
Larz29's Avatar
Drives: 2010 camaro ss LS3 cyber grey
Underdrive pulley recommendations
I'm going to get a cam swap this spring, and since the labor will be free I was thinking about getting an underdrive pulley. The only issue was I might install an aftermarket JL audio amp for my factory speakers.
Will the pulley really add any noticable power and will the pulley hurt the daily drivability of the car with the A/C on?
Larz29 is offline   Reply With Quote
Old 02-21-2013, 11:31 AM   #2
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
Nice cam specs, let us know the results when installed.....
11.90's w/headers, CAI, tune, & some high-test (no bling).
Smirnoff is offline   Reply With Quote
Old 02-21-2013, 11:56 AM   #3
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
Did the same as you - added 25% UD pulley w/ cam swap. More power in theory - yes. Less parasitic loss spinning the accesories. How much - don't know. Did not dyno separately. Others have quoted 7-10 HP gain.
Daily drivability - zero issues - same as stock. Use A/C a lot here in SC - no problems or concerns 7500 miles later.
2010 Camaro 2SS Cam/Headers/CAI/3.91 gears
476 rwhp/440 rwtq (sold)
SSDan is online now   Reply With Quote
Old 02-21-2013, 12:05 PM   #4
2012InfernoSS
2012InfernoSS's Avatar
Drives: 93GMC sierra stepside/2012 SS
I think its a waste for only 10 hp but thats just me,others seem to like it but ive also got 900/5 jl amp and 10w7
2012InfernoSS is offline   Reply With Quote
Old 02-21-2013, 12:51 PM   #5
LeanPocket
Drives: 2010 2SS
its worth around 5-15hp. Dont get all wound up on HP numbers, the pulley will net you around a .1 off your ET at the track. To me, thats worth ~200$
trickflow sells the pulley by itself for $189 over at calspeed
LeanPocket is offline   Reply With Quote
Old 02-21-2013, 12:54 PM   #6
biggerisbetter
lll
biggerisbetter's Avatar
Drives: 2010 camaro ss L99
wich pulley do those of you who have them reccomend
biggerisbetter is offline   Reply With Quote
Old 02-21-2013, 02:10 PM   #7
Ivan @ Southwest Speed
The Powerbond and SLP are both really decent UD's for the price. They're right around 25% and are a simple install. Most do it when they swap cams since the original balancer comes off.
Both of those will yield you a solid 10-15. Better SOTP increases.....
Ivan
Old 02-21-2013, 02:29 PM   #8
VADER SS L99
VADER SS L99's Avatar
Drives: Z71, 2001 Trans Am, 2013 A6 GT 5.0
I still think there might be a relation between timing chain/tensioner failures and a aftermarket UD pulley/balancer. Choose your UD pulley wisely.
Old 02-21-2013, 02:49 PM   #9
Nightmare2012
come find out;)
Drives: stockish 2012 camaro ss
Bump
Nightmare2012 is offline   Reply With Quote
Old 02-21-2013, 02:58 PM   #10
DuskSS
Bayou City Muscle Cars
DuskSS's Avatar
Drives: 2013 2SS Dusk Edition
use a good chain(s) when you do the cam and you wont fail.
I still dont see how people blame the UD for chain failures.
we have been using UD pulleys for decades on many types of performance cars with stock cams and chains/belts.
Lethal Racing Stage V
PER 418ci Forged LS3
530/520 SAE
DuskSS is offline   Reply With Quote
Old 02-21-2013, 03:57 PM   #11
Powhusku
Powhusku's Avatar
Drives: 2010 2SS/RS M6
All the stories I've read about this have me scared to install an UD pully with my cam later this month. Granted the timing chain will be upgraded at the same time, is it just less risky to stick with the factory one rather than an aftermarket one?
Powhusku is offline   Reply With Quote
Old 02-21-2013, 04:09 PM   #12
Kelly@PCMofNC
Drives: 2010 RS/SS
I like Powerbond personally. Have them on my own cars and use them a lot in the shop as well! It's not an enormous amazing gain on its own but it does help complement a nice heads/cam package and pick up a few extra ponies.
I do not notice any difference at all with accessories or a/c.
I have never had a timing chain or tensioner failure because of an underdrive pulley.
Here's what I have on my own car, we also offer the belts and a new harmonic bolt to save you the hassle!
Camaro 2010+ Powerbond Pulley
Kelly - sales@pcmofnc.com - 704-307-4227 www.pcmofnc.com
Kelly@PCMofNC is offline   Reply With Quote
Old 02-21-2013, 05:07 PM   #13
VADER SS L99
No one can proove that some aftermarket pulleys don't do damage the same way no one can proove that they can. Its a double sided coin and a pretty big debate because there is no actual PROOF either way. I say better safe than sorry. Its only 5-10 extra HP. If I ever get a UD pulley it will be a ATI or maybe Fluidampr. Those are the only ones I would trust to fully dampen as good or better than stock. How do you know for sure the others are controling harmfull engine vibrations and harmonics at all rpm's with every engine combo. Even if you did put a stong enough chain on it to not break, a crank balancer not doing its job will take a toll on a motor over time. Granted I had a powerbond on my LS1 and never had a problem for over 100k miles but that was a bolt on only car and I wouldnt take the same risk with this one for 5HP but thats just me.
Old 02-21-2013, 05:46 PM   #14
biggerisbetter
lll
i have heard n othing but good things about the powerbond. when i buy mine that the one im going t go with.
