Emblempros
Old 06-17-2009, 01:25 AM   #1
hb-rocks
hb-rocks's Avatar
Drives: Chevy
Valvoline 300k mile Engine Guarantee
http://www.engineguarantee.com/
In what it’s calling a “game-changing” move, Valvoline has started a campaign in which it will guarantee your engine will keep running for up to 300,000 miles.
The catch? Use only Valvoline, of course, and change your engine’s oil and filter every 3,000-4,000 miles.
The guarantee only works on cars that already have less than 75,000 miles on the odometer, and must be a 1990 model or newer.
Three levels of coverage: Use Valvoline Premium Conventional Motor Oil and the company will back your engine to 150,000 miles; use MaxLife or DuraBlend for up to 225,000 miles; and Synthetic for the elusive 300,000.
If your engine goes kaput within the coverage limits, Valvoline says it will directly pay your service provider for all labor and parts to fix the problem. If the repair exceeds the car’s value, the company will pay you “an amount equal to the vehicle’s value as set forth by Kelley Blue Book or similar source,” the company says.
There is a slew of fine print, of course. Among the other caveats is that the guarantee is not transferable if you sell the car, and Valvoline’s maximum coverage tops out at $5,000 total.
It’s an interesting promotion, overall. Would you bite?
hb-rocks is offline   Reply With Quote
Old 06-17-2009, 01:29 AM   #2
GMtothecore
"That Guy"
GMtothecore's Avatar
Drives: Camaro SS...........what else?
Location: OOOOOOOklahoma where the wind comes sweepin' down the plains.
nah...cause I'm a Mobile 1 guy. Interesting promotion though.
GMtothecore is offline   Reply With Quote
Old 06-17-2009, 12:29 PM   #3
JJ#48Racing
Drives: 1998 Camaro SS
Nope, I'm out. Here's why:
Vehicle can not:
- Be used for competitive purposes.
- Have an engine that has been modified by owner with non-factory original parts.
I guess I could use it for the daily drivers, but I've always been a Mobil 1 fan anyway. This seems like one of those guarantee's that would be very hard to actually get them to pay.
JJ#48Racing is offline   Reply With Quote
Old 06-17-2009, 12:44 PM   #4
hb-rocks
hb-rocks's Avatar
Drives: Chevy
Vehicle can not:
Yes....I would never take them up on this in a million years. Where-ever fine print and lawyers are involved...I"M OUT too....!
You could almost say this is a desperate measure Valvoline is taking just to attract attention and keep their heads above water!
I just found it interesting the lengths business go....to get more business.
Old 06-17-2009, 02:38 PM   #5
JJ#48Racing
This could only work for someone who keeps their engine stock, keeps the car for a long time, and is meticulous about timely maintenance and record keeping. That's a very small percentage of people. But hey it'll probably get some people to start using their oil with the intent of doing all those things.
Interestingly, Valvoline requires you to change the oil every 3-4k even if you're using full sythetic, which is much sooner than most manufacturers recommend. I stick to 3k in my camaro, but go 5k on my other two cars (Mobil 1 sythetic and filters in all of them), which is still conservative for full sythetic. Now add up the cost of all those extra oil changes over 300,000 miles.
Old 06-24-2009, 03:33 PM   #6
FxsX24
FxsX24's Avatar
Drives: S10 283 V8,Jimmy 4wd 4dr bk/bk
you have a certain amount of miles you can change within (not exactly 3k) i want to get the exact details on it, i work at advance and can get the oil a little cheaper that some.
i want to find if intake and exh mods are considered to void the guarnatee
what about a motor that has been rebuilt ( bore and everything) does that consder it 0 miles (even though its a old motor) should try it for the 283 in my s10
or if the motor in my jimmy(not the orig motor) has less miles that the odometer has on it
FxsX24 is offline   Reply With Quote
Old 06-24-2009, 04:00 PM   #7
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
Not enough to make me switch from Royal Purple.
Plus, I'm not even sure how they would back something like that.
- X
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
To break in or not to break in? Emu the Foo 5th Gen Camaro SS LS LT General Discussions 68 03-15-2008 08:12 PM
5th Gen Camaro LS3 info from Chevy Hi-Po...READ TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 295 03-07-2008 11:06 AM
Axial Vector Engine Mr. Wyndham General Automotive + Other Cars Discussion 6 06-20-2007 05:00 PM
