HeadlightArmor
Old 02-22-2013, 03:50 AM   #1
1sikss
Drives: 2011 camaro ss
exhaust problems ????
so today i installed my magnaflow cat bak exhaust comp series and everything was good until i drove on the highway it makes like a griding noise has anyone installed this exhaust could it be my drive shaft cause the muffler is too pushed up? thanks for the help in advance
1sikss is offline   Reply With Quote
Old 02-22-2013, 03:53 AM   #2
nebchevy
nebchevy's Avatar
Drives: 2011 2SS SGM Camaro
I know when i installed my AMT cat back system, i had a nosie when driving and had some performance issues.. What happened with mine was that all the pipes where not high enough and tight enough and the computer thought the engine was knocking. All i had to do was put it up on a lift and just fine tune all the exhaust pipes...
All of that was thanks to talking to TED!!!
nebchevy is offline   Reply With Quote
Old 02-22-2013, 03:54 AM   #3
nebchevy
nebchevy's Avatar
Forgot to say that my exhaust was hitting the tunnel brace underload and thats where my noise was coming from
Old 02-22-2013, 06:40 AM   #4
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Yes check the brace that will do it.
Old 02-22-2013, 10:31 AM   #5
1sikss
it runs good is just that noise ima check it out today thanks
Old 02-22-2013, 10:32 AM   #6
1sikss
the tunnel brace is the plate that holds the muffler up right?
Old 02-22-2013, 10:35 AM   #7
1sikss
did you remove the tunnel brace or how did u fix it
Old 02-22-2013, 12:51 PM   #8
nebchevy
nebchevy's Avatar
The tunnel brace does hold anything up... well i shouldnt be. Its the plate that had 4 bolts under the car closer to the spot you met the cats to ur cat back system.
I put shims in mine.. aka washers till i buy my new one in a few weeks. Also i loosened everything up and used a jack to push and hold pipes up while i tightened them down again. Just make sure you have clearance on everything the pipes might touch..
Old 02-22-2013, 01:05 PM   #9
Juiced1
Juiced1's Avatar
Drives: 2012 2SS CAMARO 45th
A couple of washers/spacers will do the trick. ARH and Stainless Works both came out with aftermarket braces that look trick and can house a 3" system without any issues.
Get more power for your dollar! We have the best prices on the hottest parts and we price match!
JUICEDMOTORSPORTS.COM
224-63-JUICE 224-635-8423
Juiced1 is offline   Reply With Quote
Old 02-22-2013, 01:19 PM   #10
1sikss
ok so i took off the plate and drove it and it didnt make any noise den after a couple of drives it started making a hissing sound at low speeds or high rpms.... i checked the bolts and there all tight but the muffler went down a little since it didnt have the plate u think thats why its making the hissing sound
Old 02-22-2013, 01:23 PM   #11
1sikss
but it has no loss of power it runs good and once im up to like 50 and i cruise the noise stops
Old 02-22-2013, 01:32 PM   #12
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
It sounds like you need to loosen the clamps and readjust the exhaust system. You should be able to adjust it to not hit or rest on the the tunnel brace. The hissing sound is most likely a leak.
Best regards,
Tyler
888-308-6007
magnaflow noise
