BORLA
Old 02-22-2013, 04:33 AM   #1
nebchevy
nebchevy's Avatar
Drives: 2011 2SS SGM Camaro
Cool fuel rail question....
Hope someone can answer my question
If I buy the holley LS Hi-Flow Fuel Rail Kit http://www.holley.com/534-210.asp
Do i need to buy and do the Fuel Line Conversion kit that JDP Sells or will the holley fuel kit move the fuel line off the intake??
Has anyone installed the Holley kit and if so how hard was it and will i need to do any fabricating??
nebchevy is offline   Reply With Quote
Old 02-22-2013, 09:24 AM   #2
Nightmare2012
come find out;)
Drives: stockish 2012 camaro ss
It says its a direct bolt on, but idk might want to give them a call
Nightmare2012 is offline   Reply With Quote
Old 02-22-2013, 09:30 AM   #3
2012REDSS
Drives: 2012 Camaro SS
The directions say this: P/N 534-211 - Adapter kit, required when directly connecting Holley fuel rails to GM factory fuel line quick-connect. Includes (1) 3/4-16 O-ring port plug and (1) -6 to GM quick connect adapter.
2012REDSS is offline   Reply With Quote
Old 02-22-2013, 09:37 AM   #4
Nightmare2012
come find out;)
Srry must have missed that, what he said! Happy modding
Old 02-22-2013, 10:40 AM   #5
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
Those look pretty sweet. I think I found out what fuel rails I want when I get heads/cam.
ADM tuned 412HP/407RWTQ. Kooks 2" headers w/ cats, ADM race intake, Vmax TB, Pedders XA coilovers and ZL1 sways. 1le clone
ackeight is offline   Reply With Quote
Old 02-22-2013, 10:48 AM   #6
blazzin1
blazzin1's Avatar
Drives: 2016 2SS (A8)
Yes, but that part number (534-211) is an "Optional Accessory", so it will ordered separately from the fuel rails.
blazzin1 is online now   Reply With Quote
Old 02-22-2013, 12:42 PM   #7
nebchevy
nebchevy's Avatar
So i guess its saying i need to buy P/N 534-211... then it will work just fine???
Old 02-22-2013, 01:33 PM   #8
blazzin1
blazzin1's Avatar
Yes, that is my interpretation. You will need P/N 534-210 & 534-211.
Old 02-22-2013, 02:06 PM   #9
Kelly@PCMofNC
Drives: 2010 RS/SS
Do you have a picture of that? I'm just curious myself.
OP what you're lacking is a fitting to get you back to the aluminum fuel line (near the frame rail). Not sure what 534-211 includes or is but essentially what you need is something like this
The bottom 'U' shape unscrews. You slip that under the bottom of the lip on the factory fuel line, slip the threaded part over, and tighten. Now you have a -6 fitting to screw your -6 straight fitting on to from the other kit.
Kelly - sales@pcmofnc.com - 704-307-4227 www.pcmofnc.com
Kelly@PCMofNC is offline   Reply With Quote
Old 02-22-2013, 02:08 PM   #10
Kelly@PCMofNC
Drives: 2010 RS/SS
And a word of advice to anyone making fuel lines for these fuel rails...tighten it as much as possible before it makes its way onto the car. Once it's on, if it's leaking, it's tough to get a lot of travel with a wrench back there to go any tighter.
Old 02-22-2013, 05:44 PM   #11
nebchevy
nebchevy's Avatar
So is something like this a tuff install??
Old 02-23-2013, 12:33 AM   #12
nebchevy
nebchevy's Avatar
If i get this and the P/N 534-210 & 534-211 then this should be all i need? Will i need a fuel rail tool to help disconnect the fuel lines?
I was reading somewhere about braded fuel lines leaking gas a bit... is that true??
Old 02-23-2013, 01:34 AM   #13
Moreno Motorsports
Moreno Motorsports's Avatar
Drives: G5.R
I was reading somewhere about braided fuel lines leaking gas a bit... is that true??
Yes, go to my thread and learn how I eliminated that concern.
Moreno Motorsports is offline   Reply With Quote
Old 02-23-2013, 02:08 AM   #14
nebchevy
nebchevy's Avatar
I may be a complete dumbA$$ but i cant find it on your thread... could you help me out pls...
