BeckyD @ James Martin Chevy
Old 02-22-2013, 12:44 PM   #1
Anthony @ LG Motorsports
Drives: 1994 1LE / 2006 Z51 Corvette
*RELEASE* LG Motorsports G5 Camaro Coil Overs
LG Motorsports is proud to bring you the G5 Camaro coil overs.
Years of testing the new Generation 5 Camaro platform have let us build a shock and spring package that will make your Camaro come alive on the track and still be completely street friendly. Our shocks feature Camaro specific valving and spring rates. The shocks are built with custom lengths that allow your Camaro to be lowered without running into shock travel problems.
  • 22mm front strut piston shaft
  • 15mm rear shock piston shaft
  • LG Motorsports approved custom spring rates
  • LG Motorsports designed and tested valving
  • Easy ride height adjustment
  • Bolt on installation
  • Compatible with all Gen5 Camaros
  • Track tested and daily street durable
Ride height
Ride height is simple to adjust with the LG Motorsports coil overs. Simply turn the spring adjuster on your strut/shock up or down to lower the ride height of your Camaro to your liking. This also will allow you to corner balance the weight of your Camaro, something that can not be done with the OEM design.
Track Tested
We have worked for decades on our Corvette systems, and the Camaro is no different. Taking from our years of street and race track development we put all of this into this coil over for your Camaro. Using data from our in house SS and ZL1 Camaros we put together a kit that is easy to install on your Camaro and give you confidence and improved handling both on track and the street.
Spring Rates
Using the data over the One Lap of America, street, and track testing we developed a spring rate that left your Camaro balanced and easy to drive. Both on track and the street you will find a new level of confidence not experienced by even the ZL1. If would like to use these on a custom application please talk with one of our sales reps about possibly changing the springs for AutoX, drag racing, or any possible combination.
Pickup a set of our G5 Sway bars and end links to finish out your suspension package!
Bang for the buck you will not find a better coil over system on the market!
Anthony @ LG Motorsports is offline   Reply With Quote
Old 02-22-2013, 12:53 PM   #2
WheelmanSS
Logic is dead
WheelmanSS's Avatar
Drives: 2010 Camaro 2SS/RS
Send a message via AIM to WheelmanSS
Looks nice.
What's the $$$$$$$$$$?
2010 Camaro 2SS/RS (LS3)
573 RWHP 498 RWTQ
- Vortech V3 Supercharger
- Kooks Stepped Headers, Magnaflow 16580
- Suspension by Pfadt, Hotchkis.
2007 Trailblazer SS- Sold
2001 Trans Am WS6 431 RWHP 408 RWTQ - Sold
1994 Camaro Z28 - Sold
WheelmanSS is offline   Reply With Quote
Old 02-22-2013, 12:55 PM   #3
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
Caswell239 is offline   Reply With Quote
Old 02-22-2013, 12:57 PM   #4
WheelmanSS
Logic is dead
WheelmanSS's Avatar
Ah, didn't see another post.
573 RWHP 498 RWTQ
Old 02-22-2013, 01:08 PM   #5
Can't post pricing any any tech section.....forum rules.
Old 02-22-2013, 02:03 PM   #6
Ivan @ Southwest Speed
Amped up about these....thank you for pushing to get these out RIGHT and at a killer price.
Ivan
Old 02-22-2013, 02:20 PM   #7
Caswell239
Caswell239's Avatar
Drives: 2011 2ss/rs
Old 02-22-2013, 03:37 PM   #8
Powhusku
Powhusku's Avatar
Drives: 2010 2SS/RS M6
Really liking the look of these. Promising price tag as well!
Powhusku is offline   Reply With Quote
Old 02-22-2013, 04:17 PM   #9
caverman
caverman's Avatar
Drives: '69 SS Convertible
So, based on the looks of this coilover, the adjustment from the rear is at top. If that's the case then I'm guess you'll have to put a whole in the trunk.
Personally, I love having a whole in my trunk to make adjustments. Makes it super easy.
Build Journal
Old 02-22-2013, 04:35 PM   #10
These are not adjustable shock valving, just adjustable ride height.
Adjustable kits are coming down the line
Old 02-22-2013, 08:01 PM   #11
Parabolica
Drives: 2011 2SS
How far out are the adjustable ones? Mono tubes? Independent adjustments (compression and rebound)?
Parabolica is offline   Reply With Quote
Old 02-23-2013, 08:58 AM   #12
Possibly a month or so. Price changes a lot more than these. Mono tube, just like these and I believe they should have independent bump and rebound.
Old 03-15-2013, 12:16 PM   #13
ALLTRBO
ALLTRBO's Avatar
Drives: V8 up front and 7-spd out back FTW
Hey Anthony,
What are the spring rates on these?
How would you say these compare to stock FE4 shocks/springs? I'm sure they're light-years ahead of the FE3 in terms of damping rates, but my FE4 feels much more controlled than the FE3. I imagine these are even better yet, but roughly how much?
How much stiffer is the ride with the chosen springs?
I'm exploring many options right now for mild lowering and this is one of them. I want to do it right, but track use will be very rare for this car so I don't want to give up too much in ride quality (mainly for my wife, honestly).
ALLTRBO is offline   Reply With Quote
Old 03-24-2013, 10:43 AM   #14
ALLTRBO
ALLTRBO's Avatar
