JUICEDMOTORSPORTS
Old 02-23-2013, 02:20 PM   #1
StreetSS
Drives: 2011 Camaro SS
Measuring AFR w/ Wideband
I plan to install an AFR wideband. Car has headers w/cats and x-pipe. Where is the best place to install the sensors, and do I need two sensors to measure AFR on each bank? Or, is measurement at only one side sufficient?
StreetSS is offline   Reply With Quote
Old 02-23-2013, 02:43 PM   #2
FrankT
400HP used to be enough..
FrankT's Avatar
Drives: 2010 2SS rs manual
One side will do, although both is better. Make sure you install the sensor(s) BEFORE the cats.
Currently in the fleet... 2014 Cadillac CTS-V, 2010 Camaro SS single turbo, 2006 Chevrolet 2500HD Duramax, 1967 Camaro SS350, 1969 Camaro SS427.
Build thread: http://www.camaro5.com/forums/showthread.php?t=47925
FrankT is offline   Reply With Quote
Old 02-24-2013, 07:54 PM   #3
StreetSS
Thanks! I ordered 2 since there seems to be some value added.
Old 02-25-2013, 09:47 AM   #4
Iam Broke
PHAT B33
Iam Broke's Avatar
Drives: 2012 TF3 Camaro 2SS/RS M6
Usually the DS bank runs a bit leaner so I put one there. Let us know what you see on the dual setup.
Iam Broke is offline   Reply With Quote
Old 02-25-2013, 05:11 PM   #5
StreetSS
Will do. I'll post some logs. May end up not being a good use of funds, but at this point, what's a few extra bucks... Plus I had a few beers by the time I got around to ordering.
Old 03-02-2013, 10:21 PM   #6
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
Make sure the wideband is at like the 3 o'clock position so the head doesn't get wet.
Tampa Tuning is offline   Reply With Quote
Old 03-21-2013, 08:19 PM   #7
StreetSS
As promised, if anyone is interested here are the datalogging results with 2 Aeroforce widebands. There are differences in readings in both the logs and on the gauge while driving normally, usually slight. Not sure if the info on both sides was useful to the tuner or not...
Old 03-21-2013, 08:40 PM   #8
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Pretty rich, but that should be good data for an updated tune!
GM LSX parts, builds, and calibration. Home of some of the fastest LS powered vehicles in the world!
http://www.gwatneyperformance.com/
ryan@gogwatney.com jzajac@gogwatney.com aaron@gogwatney.com
Rhino79 is offline   Reply With Quote
Old 03-21-2013, 10:09 PM   #9
StreetSS
Already got the retune and ready to upload it tomorrow. Quick turn around at JRE!
Old 03-22-2013, 12:30 AM   #10
newb
newb's Avatar
Drives: 2013 1LE
Did you install the O2's before the cats? If so, do you have a pic of them installed? I am considering the same setup. Just curious about the positioning because I will have to get the bungs welded onto the mid pipe. I have been told that you can just use the downstream (post cat) bungs since you tune out the second set of 02s anyway.
It's a Dingledarm. It's there to dampen side fumbling. If your marzelvanes fumble too much they can cause total protonic reversal. It gets ugly from there. This is really the biggest problem with the new Camaro. That and the tri-pronged blivot.
Delivered 21 Jan 2013
newb is offline   Reply With Quote
Old 03-22-2013, 08:21 AM   #11
StreetSS
I installed before the cats just after the collector. There is not much real estate in this area on my car. I used the do-it-yourself AEM clamps with the bung pre-welded. I got tired of taking my car to shops and having them ding or scratch it. Easy install using a stepped drill bit. Not the best picture...
Old 03-22-2013, 08:30 AM   #12
Can't_C_Me
Don't Sleep on My V6
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
I thought about adding a 2nd wideband sensor also but was told the reading would be off a little. But it doesn't look to off. May try this later on also. What meter are you using?
Sent from my Samsung Galaxy S III
Can't_C_Me is offline   Reply With Quote
Old 03-22-2013, 09:00 AM   #13
StreetSS
Using an Aeroforce Interceptor w/ their AFR kit. Also using SCT handheld to log.
Old 03-25-2013, 08:09 AM   #14
newb
newb's Avatar
Drives: 2013 1LE
I am not sure why its so important to go in before the cats? On the dyno. The probe is inserted at the tail pipe. Obviously well after the cats. Why can't the now useless post cat bungs be used? Since the secondaries are tuned out... Hopefully someone can help answer my question
Sent from my iPad using Tapatalk HD
