Old 02-24-2013, 05:13 PM   #1
BeardWS6
BeardWS6's Avatar
Drives: 01 WS6
Rear End fluid Change! What to use?
I had the dealership change it, still makes the noise. Someone posted about a certain fluid to change it to. Can anyone recommend what to use? Thanks!!
2013 Red ZL1 Auto modded
2015 C7 ZO6 Luguna Blue stock
BeardWS6 is offline   Reply With Quote
Old 02-24-2013, 08:42 PM   #2
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '17 ZL1 A10
correct part for the ZL1 is the "LS Dexron gear oil" part #88862624. All additives are in it already. Don't get fancy with other stuff...just get this as it is what was designed to go in the ZL1 rear. It is expensive at $20ish per quart. http://www.gmpartsdirect.com/results...umber=88862624
'17 ZL1 A10 Mosaic Black PDR/Nav 2:08.35 VIR Full
'15 Z/28 #325 black a/c & stereo. 2:10.1 VIR Full 1:44.74 Summit Point Shenandoah Circuit (sold)
'12 ZL1 10.52@131 1.55 60' 2:13 VIR Full (sold)
Stephen12ZL1 is offline   Reply With Quote
Old 02-24-2013, 09:10 PM   #3
Al C.
Al C.'s Avatar
Drives: ZL1 #529 "El-Jefe"
How many quarts can I expect to use?
Al C. is offline   Reply With Quote
Old 02-24-2013, 09:13 PM   #4
1MtnGoat
1MtnGoat's Avatar
Drives: '12 SIM ZL1, 1 of 49
I think it's 2.1 qts.
Under Hood - Painted strut bar ends with custom SS mounting hardware, E2 CC, RotoFab CAI, ZL1 underhood decal, Amsoil oil, Black billet strut covers, Metco tensioner pulleys, intercooler reservoir
Chassis - Hawk ceramic brake pads, ZL1 wheel decals, Amsoil fluids
Interior - A pillar gauge pod w/Aeroforce Interceptor gauges, Polished ZL1 speaker rings, ZL1 mats and console lid, Custom GPS mount
Exterior - 3M bra, LED driving lights, PIAA Plasma Ion yellow fog lights, Custom front flaps, Window tint, CF bowties, Splitter skid plate, Technostalgia sequential tail lights
1MtnGoat is offline   Reply With Quote
Old 02-24-2013, 10:07 PM   #5
Stephen12ZL1
Drives: '17 ZL1 A10
correct...buy 3
Old 02-24-2013, 10:39 PM   #6
Al C.
Al C.'s Avatar
Thanks
Old 02-25-2013, 02:07 PM   #7
BeardWS6
BeardWS6's Avatar
Drives: 01 WS6
Do you think this is the same fluid the dealership use when changing ours. I`ve done ths once already!
Old 02-25-2013, 02:20 PM   #8
hognutz
hognutz's Avatar
Drives: 2013 ZL1
I would verify the part number the dealership used if you still have the invoice. I think mobile 1 also makes fluid that would work as well that has the adative in it. Someone posted in they used royal purple and had some noise issues.
rule of thumb is make sure the oil you buy has the addtive in it or if you buy expensive fluid witout it you add it in.
I am always nervous about dealerships. they pretend to know cars but many of them are marginal at best.
On my Z06 I took the TSB to the dealer made sure they fluid they used matched the part number on the TSB and the problem was solved. On the corvette side many dealers just told the owner that noise and draging tires in sharp turns were normal. Thats how brilliant some dealers are.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 02-25-2013, 07:32 PM   #9
Stephen12ZL1
Drives: '17 ZL1 A10
I tried Royal Purple and I have no doubt it is a great rear end fluid but it does not have the additive packge that GM requires to make the ZL1 rear noise free. In other GM vehicles it is probably a "non-issue". Mobil 1 is similar...great fluid but not the correct additive that GM requires. Try them if you like, but you will come to the same conclusion as I did. Just use the right stuff from GM and forget about it.
Old 02-25-2013, 09:01 PM   #10
hognutz
hognutz's Avatar
Drives: 2013 ZL1
I figured mobile 1 probably made the GM.
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
Old 02-26-2013, 01:12 AM   #11
RiCorvette
RiCorvette's Avatar
Drives: 2017 Corvette Grand Sport 3LT
Royal Purple whined A LOT in my '10 SS. I think I read somewhere here that Pennzoil Synthetic was good and had the additives.
http://www.pennzoil.com/other-car-pr...ear-lubricant/
RiCorvette is offline   Reply With Quote
Old 02-26-2013, 07:47 AM   #12
davidcroft
Sellin Chevy's since '06
davidcroft's Avatar
Drives: 18ZL1 02Z-28
Royal purple whined in my rear end too. GM's solution was the LS gear oil used in the corvettes. For 10-12 SS cars it required an axle seal change over to accept the LS gear oil. I haven't heard of diffs being noisy on ZL1s. Just certain '12 and earlier SS cars...I'm curious as to what comes of this.
2018 MBM ZL1 6spd Coupe https://youtu.be/fM9silIzdcI
02 Z28-Kooks true dual headers/TSP heads&cam/full suspension & Kmember sub35K orig miles. https://youtu.be/h6faSdcvNew
SOLD!'16 SS Sedan-Forgestars/ARH/rotofab
TRADED!2014 SS Sedan
SOLD! 2013 Blue Ray1SS/1LE 1of20.
TRADED! 2012 White 1SS/RS
davidcroft is offline   Reply With Quote
Old 02-26-2013, 11:55 AM   #13
BeardWS6
BeardWS6's Avatar
Drives: 01 WS6
They did change my axle seals to change the oil when I brought it in. I`m going to go by and ask the service department what is on record what they used and did since my car is at G-Force.
Old 02-26-2013, 02:53 PM   #14
RoketRdr
RoketRdr's Avatar
Drives: 2010 Duramax; 2012 CTS-V Coupe
Ummmmmm....never mind.
RoketRdr is offline   Reply With Quote
