BORLA
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 02-25-2013, 10:01 AM   #1
Titan
Titan's Avatar
Drives: 2012 Camaro 1SS
5th Gen Console '67
I am restoring a '67 Camaro. It is a V-8 car and will be a Black RS/SS Clone with white bumblebee when complete.
I do not care for any of the consoles made for the '67 whether factory or repro and I do not want to spend the dough on a complete one off. So I was thinking of going with a 5th Gen console in my '67. Mine is an auto on the column so I would make up a filler panel for the shifter and gauge area and either paint the thing tuxedo black or cover it in a matching interior black vinyl. I have Procar Rally Seats in white vinyl going in and would like something to accent them. Also I am putting in the LOKAR floor mounted emergency hand brake so I would make the e-brake relief on the 5th gen console functional.
Who has thoughts and opinions on this?
Titan is offline   Reply With Quote
Old 02-26-2013, 02:42 PM   #2
itsadryheat79
itsadryheat79's Avatar
Drives: 2018 ZL1 1LE (2)79Z28 72RS 67SS 69Z
Send a message via Yahoo to itsadryheat79
Not sure the trans shift location would fit or look the same. At least the 5th gen has Cup holders and you may also want to look at the console on the 2004-06 GTO for ideas too.
- Buttons and Skulls -
miss my annimated signature.
itsadryheat79 is offline   Reply With Quote
Old 02-27-2013, 08:11 AM   #3
Titan
Titan's Avatar
The shifter on my 67 is on the steering column, not on the tunnel so the shifter is not a problem. I just got a console from a forum member so the project is on.
Old 03-15-2013, 11:14 AM   #4
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2012 2LT RS
I can tell u from experience getting custom consoles made are expensive. I had one made for my 67 and paid $1600. I even had quotes in the $3k range. If u found one from another car that u like, u probably saved a ton of money.
2012: e85, 80mm TBody, CAI w/scoop, Solo HFC, ZL1 FP, Magnaflow TruX, Dynomax VT, Elite catch can, HP Tune, Throttle Contoller, BMR; Springs, Sways, Trailing Arms, Toe Ends, & Safety Loop, Koni str.t, Pioneer Z150bh, Phoenix Gold Sub, Hertz speakers & 5ch Amp, 1LE rear with 3.91 gears, BMR bushings, Baer Decela Rotors, Goodridge brake lines, Brembo(GM) 4 piston calipers, Hawk Ceramic pads, ported intake, Circle D 5c. 12.3@112 old setup
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
IneedAZ is offline   Reply With Quote
Old 03-16-2013, 10:48 PM   #5
Titan
Titan's Avatar
Tell me about, there is nothing about these cars, the new or old ones, that are cheap. My '67 is in the body shop right now getting a nice Black BC/CC and I will get it back next month. I picked up a console from a forum member and I have Scat Rally Seats to go into it when I get it back. I just have to figure out what I am going to do in the area where the shifter and gauges go. I may put in a set of gauges but I will wait to see what I am working with when I get the car back.
I like your '67. How is the visibility with the 4" cowl? Any must do mods or pieces that you recommend on the '67's? Is your 5th Gen IBM. If so good choice, my '12 is IBM.
Old 03-18-2013, 08:27 AM   #6
IneedAZ
IneedAZ's Avatar
Thanks, yes my 12 is IBM. NO visual issues so far with the 4" cowl. I will take a pic of my interior and post it. Changed all my gauges last year and went digital. Figured my car was too modded for stock type gauges even though 2 years earlier i had put new stock gauges.
Old 03-18-2013, 09:06 PM   #7
intofx
Drives: 2011 RS/SS Camaro
Post pics as you go!!! I'm interested in seeing how this turns out.
Matt
2011 RS/SS camaro
1969 RS/SS camaro
2007 Hummer H2
intofx is offline   Reply With Quote
Old 03-22-2013, 06:49 PM   #8
Titan
Titan's Avatar
Car is getting jambed and interior painted today and then it will hopefully go for paint in the next few weeks. So the interior will be the next project.
Old 04-01-2013, 06:14 AM   #9
monstertodd
monstertodd's Avatar
PICS please?????
Old 04-02-2013, 05:15 PM   #10
IneedAZ
IneedAZ's Avatar
Sorry it took so long for the pic as its the first time taking it out of the garage in nearly 3 weeks.
Old 04-07-2013, 01:14 AM   #11
Titan
Titan's Avatar
I'm going to guess that you fabricated that dash panel with the double din opening! That looks great!
Old 04-09-2013, 07:17 AM   #12
IneedAZ
IneedAZ's Avatar
Yes, I didn't want the standard box looking console configuration. The console is wrapped with same material they use for dash pad so it looks as it could have come that way minus the digital components.
