BeckyD@RodgersChevrolet
Old 02-25-2013, 02:02 PM   #1
Russ2485
Drives: 10' White w/black stripes Camaro RS
Questions on what everything is
Sorry for being such a noob on here...... BUT what would I need to get for a catback exhaust does everything I need come with the exhaust I would buy? does catback replace the cats? what are hi-flo cats? Do they make a big difference? Would I need a tune after getting exhaust? also what are these like x pipes or j pipes, whats the best? and if I were to get headers too would they just match up to any catback?
I know this is a lot of questions but if anyone could help me understand this before I make a purchase please help me!!!!
2013 Zl1 M6. JL W3 Picasso amp. Kooks LTs and Rotofab Intake.
Russ2485 is offline   Reply With Quote
Old 02-25-2013, 02:11 PM   #2
ayyob83
Drives: Camaro SS 2013 / Tahoe LTZ 2009
the cat back systems are full exhaust systems and gives you more horsepower and great exhaust noise and it depends on what company you want Borla, Corsa .. etc
this is the only thing i know
the rest my brothers here will explain to you
ayyob83 is offline   Reply With Quote
Old 02-25-2013, 02:15 PM   #3
biggerisbetter
lll
biggerisbetter's Avatar
Drives: 2010 camaro ss L99
catback hoos up to he factory cat and replaces everything back. they dont add huge horsepower on these cars the only thing they change is sound. if it is an auto you will likely have droning issues due to the afm. everything bolts right up and comes in the kit. you can do a tune to tune out the afm wich will make it much more enjoyable
biggerisbetter is offline   Reply With Quote
Old 02-25-2013, 02:18 PM   #4
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
catback exhaust is the piping AFTER the cats. you can keep the stock cats for just a catback. Everything is included. if you want headers, you can run no cats, or get hi flow cats. which are just aftermarket cats that help the exhaust flow faster, but not as fast as no cats. (still a little restrictive with hi flow cats.) depending on which headers you go with, some include hi flow cats, or have an "off road" application. which is no cats. You don't need to worry about midpipes, x pipes, j pipes with a catback. those are usually for people piecing together their exhaust.
Old 02-25-2013, 02:18 PM   #5
IDEALG
Chevy's "Rumble" Best!
IDEALG's Avatar
Drives: 2015 ZL1 6 speed
Send a message via AIM to IDEALG
LOL i like that response "this is all i know"
Cat- back exhausts come complete you don't need anything else when you buy one.
Cat- back exhaust are from the Cat back meaning they start after the cat.
you don't need a tune for a Cat-back.
X-pipes are exactly that a X. both pipes come together in an x usually right after the cats, Most Cat-back system already come with X pipes.
J pipes are used by the mufflers to eliminate drone from the interior of your car.
If you do Headers and high flow cats then you will need a tune.
IDEALG is offline   Reply With Quote
Old 02-25-2013, 02:18 PM   #6
SinisterEcho
SinisterEcho's Avatar
Drives: 2010 2SS/RS M6/LS3
If you are getting a quality CAT back system then it SHOULD come with everything you need to install it. It will not replace your CATs. If you are getting high flow cats then I would reccomend getting headers as well. Most cat back systems will mate to any header but i would talk to the vendor to be absolutely sure. Most headers either come with high flow cats and connections or test pipe (no CATs) connections. I think i hit all of your questions.
This is not the case. Cat back systems are only for sound.
My Mod Journal <-- Its updated... again!
SinisterEcho is offline   Reply With Quote
Old 02-25-2013, 02:29 PM   #7
ayyob83
LOL well it's true because i'm at the beginning of the modding
and i liked it
Old 02-25-2013, 02:37 PM   #8
Goober
Drives: Camaro
Catback systems are not full exhaust systems so this is not all you know. You know nothing
Only kidding man, you know a lot.
Goober is offline   Reply With Quote
Old 02-25-2013, 02:42 PM   #9
ZED SLED
ZED SLED's Avatar
Drives: 2013 CRT ZL1 Vert M6, 2015 Terrain
And if you don't know and say you do, you can bet your a$$ there will be no shortage of people on here to call you out. But that's how we learn. I know it's true because I read it on the internet.
Under hood airbrush by JT's Custom Paint Garage
Moroso CC, CAI Inc intake
Old 02-25-2013, 02:42 PM   #10
ayyob83
lol if you say this at one year ago then i'll say yes i don't know anything and now i know a little
and after 1 or 2 years i'll know everything about modding
Old 02-25-2013, 02:47 PM   #11
Goober
Drives: Camaro
The answer is 42.
Old 02-25-2013, 02:49 PM   #12
Frid
Frid's Avatar
Drives: '11 Camaro 2SS/RS LS3
-Cat back will better the sound of yo car.
-Headers/cats will better the power of yo car.
-A tune isn't required for just a catback, but preferred after headers.
-As far as the 'BEST', there are none, just what you like compared to the rest.
-For fitment: Most headers will be fine connecting to any Cat-Back. But you can always get a brand of header with it's respective mid pipe and run different mufflers/axleback.
I run the American Racing headers/x-pipe and Borla ATAK axleback. Everything hooked up perfectly.
Frid is offline   Reply With Quote
Old 02-25-2013, 03:13 PM   #13
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
In order from engine back:
Long Tube Headers with high flow cats or no cats provide the most power increase but require a tune (which will void warranty)
High flow cats or a mid-pipe as they are also called will provide a decent HP bump and do not require tuning. It bolts in place of stock cats. Some people will combine them with Shorty headers for a small gain.
An X-pipe will replace the factory H-pipe and offers a small increase in power (not much) it usually bolts up to cats and will require cutting off the H-pipe section and then either welding or clamping to the back half.
Most Catback (i.e. from the cats to the back) exhausts include an X-pipe and replace everything after the cats and usually just bolt in easy.
An axel back just replaces the mufflers and only offers a sound change. They require cutting the exhaust and then again either welding or clamping the new pipes to the existing section.
J-pipes are used to counteract the drone of some exhausts or the AFM on the V8 auto and are welded just before the mufflers.
Hope it helps.
9/26/09 Took delivery!
Old 02-25-2013, 03:26 PM   #14
jd10013
Drives: 2012 camaro
isn't it illegal to remove cats? I was under the impression that cats are a mandatory component of a car's exhaust system. I know here in VA you will not pass either a 12 months safety inspection or an emissions inspection without them.
jd10013 is offline   Reply With Quote
