| Cosmetics Modification Discussions External and Internal cosmetics modifications. |
Thread Tools |
![]() ![]() ![]() ![]() Drives: 2010 Camaro 1SS/RS Join Date: Aug 2008
Removal of front bowtie questions
Has anyone removed the front bowtie on the grille? Is it glued in place or secured by clips?
Black 2ss/rs Mid-August
Drives: 1999 Silverado, 1978 Corvette Join Date: Jun 2009
1st. Open the glove box, in the back there is a nut, turn the nut untill all the tention is off the bolt.
Next pop the hood and look for the little red anchor rod( pass. side below the a/c). unbolt all the retaining bolts and remove the rod. Go back to the glove box, A phillips head screw will now be visible. unscrew it and you will feel the slack pull back. Finally get your kahooter ring puller and put it on the embelem, turn 3 turns and it comes right off!
BLACK 2SS/RS INFERNO ORANGE INTERIOR (Ordered 6-10) ....... Pratt & Whitney J58 Jet Engine On Order, (Swap Details Soon!)
![]() ![]() ![]() Drives: 2010 VR 2SS/RS A6 Join Date: Oct 2008
hmmmmm.......
Intelligence plus character that is the goal of true education.
BrianC. ![]() |
![]() Drives: . Join Date: May 2008
It doesn't matter really. If you remove it, you will have a large impression of the bowtie since it is inset into the grill.
"Going forward, I have three priorities for the new GM: customers, cars and culture. I list “customers” first because they are our top priority. For some time now, we haven’t been as focused on this simple point as we should have been. Now, we’re going to be obsessed with it - because if we don’t get this right, we don’t get to do anything else. It’s that simple." - Fritz Henderson, General Motors CEO |
I took a picture from behind the grille. It looks like it's clipped in.
Is that what it looks like to you guys?
#6 |
I'm trying to remove it so I can have it painted.
#7 |
Oh okay. You should be fine then. Pry it off with a plastic body filler spreader.
#8 | |
#9 | |
![]() ![]() ![]() ![]() Drives: CG 09 Z06 & CG 2SS/RS, M6 Join Date: Sep 2007
CYBER GRAY W/BLACK RALLY 2SS/RS M6, ordered 05/30/09, BUILT 7/31/09 VIN# 31128, Chronic Grin Started - 08/13/09
#10 |
2G1FT1EW2A9101691
anyone done this to the rear bowtie?
If so, post pics and make this a sticky
Ordered: 10-13-08
Built: 3-30-09 (#1691) Recieved: 6-12-09 |
#11 |
I think the rear bowtie is just stuck on w 3m tape heat it up and you can take off but youll need new tape to get it back on good luck
Finally shes ours!!! Vin 2G1FK1EJ2A9158996
#12 | |
| Thread Tools | |
| how to remove front "SS" | pharmd | Cosmetics Modification Discussions | 15 | 06-17-2009 02:04 AM |
| Front Facia Removal | King Mouse | 5th Gen Camaro SS LS LT General Discussions | 13 | 06-08-2009 04:40 PM |
| No confirmation number? | jamesc1123 | Camaro Price | Ordering | Tracking | Dealers Discussions | 12 | 02-21-2009 10:49 PM |
| 1SS standard equipment and options | Tran | Wiki | 1 | 11-05-2008 04:34 PM |
| 1LS standard equipment and options | Tran | Wiki | 0 | 10-18-2008 10:13 PM |
