Old 02-25-2013, 07:30 PM   #1
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
Stage 8 Fasteners
I have a set of ARH 1 7/8 I am installing. Looking at get some of these Stage 8 Fasteners so that the bolts don't come loose. Tried to do some research, but not sure what I need. Anyone else use these and know who I can order these from?
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, RX CC, GFX, Subs.
rberns is offline   Reply With Quote
Old 02-25-2013, 07:32 PM   #2
grocerygetter
instigator
grocerygetter's Avatar
saw those on stacey david's show one time. jeg's or summit man. post up what you think...I was thinking about them too. They're pricey, be ready.
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 02-25-2013, 07:37 PM   #3
Motion427
Drives: 2010 2SS/RS Red Jewel L99
We used them a few times. Nice product.
Motion427 is offline   Reply With Quote
Old 02-25-2013, 07:39 PM   #4
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
I have them. You can buy them at Texas Speed for like $38
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 02-25-2013, 07:40 PM   #5
rberns
rberns's Avatar
I've gone onto summit racing and http://www.stage8.com/gm.html But I am unsure what part number I need. Seems like it will be about $50 or so which isn't bad. I am just not sure what I need.
Old 02-25-2013, 07:42 PM   #6
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
http://texas-speed.com/p-427-stage-8...bolts-hex.aspx
or
http://texas-speed.com/p-428-stage-8...-12-point.aspx
Either will work fine. Your choice. Hex head or 12 point.
Old 02-25-2013, 07:46 PM   #7
rberns
rberns's Avatar
Originally Posted by daveagogo1 View Post
Thank you.
Old 02-25-2013, 07:50 PM   #8
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
No problem. They work well. Also the stock bolts from GM work well too. You can reuse yours. If you want top of the line at a premium price. That would be ARP. Those run about $100
Old 02-25-2013, 08:39 PM   #9
rberns
rberns's Avatar
So whats the difference between ARP and Stage 8?
Old 02-25-2013, 08:45 PM   #10
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
If your just wanting to make your cars bay look nice then yes it's worth it but they are a PITA. If your worried about the bolts backing out then just use the stock ones cause they won't back out as long as you torque them right.
Old 02-25-2013, 08:51 PM   #11
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
+1
Sent from my HTC One X using Tapatalk 2
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline   Reply With Quote
Old 02-25-2013, 08:54 PM   #12
rberns
rberns's Avatar
Your saying ARP is a pita or Stage 8 is the pita? Since this is a summer/show car I would like the engine bay to look nice. One of the guys I talked to said that I will need to retighten my bolts if I choose to go with the OEM bolts and I know that he torqued them down to the correct specs.
Also I notice that ARP has studs and bolts. What would be easier of the two for installation and also look good?
Old 02-25-2013, 08:58 PM   #13
BLK2SS
BLK2SS's Avatar
Drives: Black 2SS
I've used Stage 8 before, but I prefer the split lock bolts.
http://www.jegs.com/i/Percys/760/310...rentProductId=
BLK2SS is offline   Reply With Quote
Old 02-25-2013, 08:58 PM   #14
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Stage 8 is grade 8 steel with "locks"
ARP is hardened Stainless steel. Stronger and more heat, corrosion resistant.
Honestly it is all up to you. Stock bolts work just fine and you could re use yours. Or you can buy the locking type that can be a bit of a hassle but do work. Or go with the ARP . All depends on what you want and what you want to pay.
Use OEM gaskets and torque bolts down properly from the inside out and you will be fine. Simply check them again after a bit of driving to ensure they are set proper. This SHOULD be done on ANY new bolt down of parts.
