HeadlightArmor
Old 02-25-2013, 08:25 PM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Question Water Injection NOOB
So so this is not about my car. I have boosted my 2007 GSXR 600. Im running about 6psi with a GT2560R turbo. I am not running a intercooler. I was looking to get advice on some water injection kits. The bike will be driven daily and raced at the same time. My compression is 12.5:1 right now witch is stock for this bike. I was wondering if I need the water kit and how much one would be for what I have. What kind of water do I run in it? Ive been told windshield wash fluid works fine. ill need something kinda cheap cause I will be going threw a lot of it. The bike has not been put on the dyno just yet. Can I have the water system kick on at 4psi and kick off when the pressure drops below 4? and where do you install the jet over each cylinder or just in the front part of my intake?
MODS 6.0 forged iron block, Texas Speed Stage3 cam, custom twin turbo, Tripple 450 pumps, DW2200cc injectors, BMR Springs, sways, endlinks, bushings, tailing arm, toe links, DSS aluminum driveshaft, G-Force 1000hp axles, Brake master drilled rotors, ACT twin disk (1550ftlb), MGW shifter, Race Star wheels 17x4.5 with MT front runners 15x10 with Hoosiers, AEM gauges, G-Force II boost controller
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 02-25-2013, 08:42 PM   #2
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
I have never seen one for a bike, but if they are like for 4-wheeled vehicles you can inject in the manifold. You should get a progressive controller that has it start spraying at a certain psi and increases linerally to the maximum psi you set. I know mine won't start spraying below 5 psi, but perhaps kits for motorcycles will. I wouldn't use washer fluid because it has dies and you can never be certain how much methonal there is. I would buy some 100% meth at a race shop and pick up some distilled water at a discount store. Then mix it about 70% meth to 30 H20.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 02-25-2013, 09:16 PM   #3
hunterv6
Always bet on Black
hunterv6's Avatar
Drives: 2011 turbo LS, 2012 f 150,
Place it after the air filter like nos kit will be the best place. If you can get a nos spray bar tie the meth injector into it. Most of the guy I know run a 50/50 or 60/40.
Sent from my iPad2 on space mountain
<font color=#0066cc>http://www.camaro5.com/forums/showthread.php?t=283263</font>
hunterv6 is offline   Reply With Quote
Old 02-26-2013, 01:27 AM   #4
2010_camaro
here is the set-up.
