Old 02-26-2013, 12:46 AM   #1
KlugSS
Guest
Posts: n/a
TSP Cam'ed Camaro
I finished working on my buddy's 2012 Camaro SS. He wanted to try to get 500 whp out of a cam only so we will see how close we get. Our dyno appointment is March 1st, Friday.
Mods:
Texas Speed 235/239 .639 .623
PRC .670" Spring Kit
Texas Speed 2" Tube Headers Off Road Extentions
Borla 2.5" Cat-back
Fast 102 Intake Manifold
Stock Throttle Body
Roto-Fab Dry Intake
160 degree Thermostat
Bocsh 80lb Injectors
e85
Start up video isnt the best quality since all we had was a go pro and a phone and it was in a small garage so the sound is a little off.
http://youtu.be/sjZELy2o0Qg
Video is uploading right now so it may not play
E70 we will retune and shoot for 500rwhp on real e85
This is a eddy current dyno NOT and inertia dyno.
Old 02-26-2013, 01:04 AM   #2
Fast6.3
Fast6.3's Avatar
Drives: 2016 2SS coupe 2015 3LT Stingray
Sweet build man i would have worked on the heads rather than the fast i think it would be money better spent as the ls3 manifolds flow pretty well and the fast is pricey but it looks killer. Hope you make your goals With the lift on your cam i would recommend aftermarket rocker as it has been mentioned that the stockers max out at 625 lift the geometry is wrong with lifts higher than that at a minimum i would do the trunnion upgrade just my thoughts
Ported intake manifold and throttle body kooks 2" headers no cats
Fast6.3 is offline   Reply With Quote
Old 02-26-2013, 01:05 AM   #3
429
Drives: 2010 camaro ss
TB and 2.5" exhaust going to hold it back a few horses. I predict 485rwhp, considering the big headers, fast, and e85. Few extra ponies in the crank pulley too if you swapped to an underdrive
429 is offline   Reply With Quote
Old 02-26-2013, 01:22 AM   #4
KlugSS
Guest
Posts: n/a
We will be doing heads on it within a few months then we will upgrade. Otherwise i would have recommended it now.
I have never seen a throttle body add hp on a dyno so i wasn't going to waste his money on one. 2.5 wont hold this car back at all, hell i even run 2.5 on my 714 whp cobra.
Old 02-26-2013, 01:40 AM   #5
IOM Black Diamond
HT5 COTW 1/21/13
IOM Black Diamond's Avatar
Drives: 2010 Camaro Inferno 2SS RS 6M
IOM Black Diamond is offline   Reply With Quote
Old 02-26-2013, 01:49 AM   #6
Bo White
Bo White's Avatar
Drives: 2010 Summit White 1SS
Get that TB ported.
Old 02-26-2013, 01:49 AM   #7
Denis
Denis's Avatar
Drives: 2010 SS
sounds like a beast. let us know what she puts down!
Old 02-26-2013, 06:27 AM   #8
quincy speeder
Drives: 2011 Camaro SS
From experience the 2.5" exhaust will hold back power.TB is good for 5-10hp too if the cold air can flow it.
2010 SS, 230 Cam, ARH headers,Airaid intake, 160 t-stat,3.90 gears 475hp/430tq. -old setup
added- Procharger F1-D, alky control,FIC 96lb,fuel system- 810hp/735tq- 10.3 at 136mph , 1.75 60'. see how long it lasts.
Thanks to Slowhawk Performance.
2008 C6, 427ci,YSI,mcleod clutch,Alky control, built tranny, custom fuel system. 985rwhp, best 1/4 -9.4 at 152mph. still trying to get the shifting down:(
quincy speeder is offline   Reply With Quote
Old 02-26-2013, 07:44 AM   #9
biggerisbetter
lll
biggerisbetter's Avatar
Drives: 2010 camaro ss L99
very nice
biggerisbetter is offline   Reply With Quote
Old 02-26-2013, 12:39 PM   #10
SPCBA
Drives: pleather and Chiclets
good choice on parts. did you get the scoop and washer bottle relocate for he rotofab intake?
question on the cam...why did you choose such a long duration? the poor heads and its internals wont benefit or like above 600
SPCBA is offline   Reply With Quote
Old 02-26-2013, 01:03 PM   #11
429
You are mistaken.
Old 02-26-2013, 01:33 PM   #12
KlugSS
Guest
Posts: n/a
No we didn't get the scoop or washer bottle relocate.
This car will be getting heads in the near future. So no reason to swap cams twice.
And this thread
http://www.camaro5.com/forums/showthread.php?t=255898
Old 02-26-2013, 01:43 PM   #13
KlugSS
Guest
Posts: n/a
You are mistaken.
Care to elaborate?
Have to remember a 90mm throttle body will flow 1200 cfm and a 105mm will do 1500 cfm. A fast will only accept up to a 102mm is stock forum.
Old 02-26-2013, 02:00 PM   #14
429
Even on a 100% bolt-on car, you are leaving power on the table with the 90 vs the 102, regardless of any cfm equation you can come up with. You will see manifold vacuum with the 90 over 6000 rpm, guaranteed.
This isn't a 4.6L cobra. (which would ALSO gain power going to a 3" exhaust)
Don't mind me, my n/a car makes well over 600 through an automatic.
