Old 06-17-2009, 03:05 PM   #1
tjd24
Thank you Oshawa/St.Cats!
tjd24's Avatar
Drives: 2010 2LT RS 2G1FC1EV4A9103434
Vararam Ram Air V
What's everyone's thoughts on the Vararam Ram Air V - see link: http://www.vararam.com/g8.html
They claim +35HP - link gives some spec details & the price is $369 for the G8 GXP version which has an LS3 engine - their sales email response indicated they've used this for their Camaro offerings though not yet posted on their website. They're completing the v6 LLT version now.
I've posted same to the LS3 / L99 Engine and Powertrain Discussions - I'd just make sure Vararam has fully tested the Camaro LS3 / L99 before assuming its "plug & play" on yours. Sales email for questions = sales@vararam.com. Here's a link to a Motor Trend article on the G8 GXP and its verison of the LS3 http://www.motortrend.com/features/a...ook/index.html.
As for the V6 LLT version - I am waiting on specs and install instructions to be sent to me before I order. Also asked questions on how the unit deals with water splashes getting into the intake which is an issue with open filter CAIs. This unit appears to have some protection but asked anyway.
If any member has experiece with Vararam from other models please chime in...
http://www.hubgarage.com/mygarage/tjd24 http://ny5thgen.com/TJD_RS.htm
#3434 Born 4-15-2009, Delivered 5-22-2009 BBOMG 2/3/4 & booked for #5
tjd24 is offline   Reply With Quote
Old 06-17-2009, 03:51 PM   #2
Xanthos
PWA Relapse
Xanthos's Avatar
Drives: Formerly-Stick
Not sure if the HP claims are correct, but their CFM ratings are certainly not. Mathematically, even if you were ram air pressurizing the air box @ 155 mph, the straight pipe leading from the air box to the throttle body would have to be a huge **5 INCH** diameter in order to flow 1900 CFM. The filter may flow that much, but the intake itself certainly won't. Since that looks to be a 3 inch pipe, we're talking more like 600 CFM max. However, 600 CFM would be more than enough for a 3.6L engine, and the ram air would certainly reduce pumping loses.
- Xanthos
2017 1LT/RS A8 Hyper Blue Metallic
Xanthos is offline   Reply With Quote
Old 06-17-2009, 04:10 PM   #3
trudawg660
Drives: 2006 Dodge Charger / 2SS IOM
i have been looking for a dyno with this but i cant find one to actually prove this, sounds like a lot of hot air at the moment.
trudawg660 is offline   Reply With Quote
Old 06-17-2009, 04:28 PM   #4
Kyle2k
LVL 50 Troll Stomper
Kyle2k's Avatar
Drives: 2010 Camaro
- Xanthos
It's not all about diameter though is it? Moreso surface area right?
Kyle2k is offline   Reply With Quote
Old 06-17-2009, 04:58 PM   #5
Xanthos
PWA Relapse
Xanthos's Avatar
After the air flows across the surface area of the filter, it must be recompressed to flow through the pipe and into the throttle body. No matter how much air will flow through the filter/air box, it will ALWAYS be limited by how much air can flow through that pipe.
- Xanthos
Old 06-17-2009, 05:04 PM   #6
Kyle2k
Kyle2k's Avatar
Drives: 2010 Camaro
- Xanthos
By that standard the TB is always going to limit you then anyway- so as long as the rest of the intake can flow more- why does it matter?
Old 06-17-2009, 05:07 PM   #7
Xanthos
PWA Relapse
Xanthos's Avatar
The point I was trying to make is that if they're fabricating CFM ratings to make their product look better, maybe they're fabricating horsepower ratings as well.
I've always been interested in making a ram-air system. But I think I'll be making/designing my own.
- Xanthos
P.S. - And by that token, you'd have to have a 5 inch (~120 mm) throttle body in order to flow that much air.
Old 06-17-2009, 06:36 PM   #8
patriotpa
Drives: 02 Silverado, 09 Vue, 10 1SS
Location: Tired of apologizing when we should be kickin' butt!
So if the CAI pipe is > the throttle body it won't make any more power than a tube = throttle body. Correct?
patriotpa is offline   Reply With Quote
Old 06-17-2009, 07:28 PM   #9
The_Blur
Jayhawk USN
The_Blur's Avatar
Drives: Demon Super Sport
Ram air is not possible on the Camaro without significant modification to the hood and front end. The hood latch is directly between the faux air inlet on the SS and the intake. Moving this would require the installation of hood pins and the removal of a large amount of body work.
I also doubt the accuracy of the numbers.
FM: The_Blur/1110/USN//
TO: Camaro5//
INFO: RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
SUBJ: Operation Demon//
REF: Buy at Invoice, Forum Rules
1. RESPECT ALL CARS. LOVE YOUR OWN.//BT
warn 145:155 ban
Old 06-18-2009, 11:22 AM   #10
MontyCarlo
MontyCarlo's Avatar
Drives: 2010 2LT/RS auto IBM
No. Everything along the air's path costs you some power. It's not just the most restrictive point that counts. You lose some in the filter no matter what, some in the pipe no matter what, some in the throttle body no matter what... it's just that if there's one part that causes a much bigger loss than the others, then improving the good parts won't benefit you much anymore.
FAQs:
1. No, I do not have any strong opinions about the Monte Carlo.
2. Yes, I know what my name looks like.
3. Yes, but the medication helps immensely.
2LT/RS IBM/gray #21,895 ordered April 21st, delivered July 3rd
MontyCarlo is offline   Reply With Quote
Old 06-18-2009, 03:07 PM   #11
Xanthos
PWA Relapse
Xanthos's Avatar
While this is somewhat true, its mostly true due to the pressure drop (a less restrictive filter will get you closer to the ideal 1 ATM of pressure) not due to maximum flow - your intake will never be able to flow more CFM than the most restrictive point.
Period.
End of story.
That said, filters, intake length, etc all factor into the final pressure drop of the system - i.e. they slow down the incoming air, reducing the net CFM. Improving the total flow at the filter will improve the overall efficiency (i.e. reduce pumping loss) of the system. So having a good intake is still worth it, but you'll never fit more than ~525 CFM through a 60mm throttle body, for example.
- Xanthos
P.S. - This is another major reason that I prefer short ram intakes to longer cold air intakes. Less pumping loss = crisper throttle response and better top end power. Your low-mid range power is affected more by exhaust/tuning anyway.
Old 06-18-2009, 03:47 PM   #12
MontyCarlo
MontyCarlo's Avatar
Perhaps Bernoulli's Principle is failing me, but there should be no such thing as "maximum flow" for any given point. Apply a bigger pressure differential across something, and there will always be more flow through it, with the flow rate varying with the square root of the pressure and air density differentials.
...unless by "maximum flow" you mean "the flow that would result if every single psi of the pressure differential between the intake point and the engine's minimum operating pressure were expended shoving air through this one restrictive feature," which now that I think about it would be a pretty useful number to have and would be a more practical use of the term "maximum flow" than what I was talking about.
In that case, it would be "you'll never fit more than ~525 CFM through a 60mm throttle body with natural aspiration" or "...with a boost of xx psi or less."
Sorry if that was pointless, but I'm a mechanical engineer who analyzes fluid flow & thermodynamics, I'm kind of bored, and you got picky.
FAQs:
Old 06-18-2009, 03:56 PM   #13
Xanthos
PWA Relapse
Xanthos's Avatar
Yes. I was discussing intake only, and so everything was using N/A theory. In a N/A situation, your maximum pressure (and thus maximum air velocity) will be 14.7 PSI. In a boosted situation, it would be 14.7 PSI + boost pressure, which would increase CFM accordingly. Either way, your intake will always be limited by that one point (which, more times than not, will be the throttle body).
- Xanthos
P.S. - On a related note, I studied engineering physics for 2.5 years before I decided recently to change my major.
Old 06-18-2009, 04:18 PM   #14
Hemlawk
AwesomeBillDawesonville
Hemlawk's Avatar
Drives: CGM 2SS/RS =)
Xanthos, you let that little kid in your sig drive your Camaro?
Order placed on 1/13/11 - Purchased 2/22/11 2SS/RS CGM
Hemlawk is offline   Reply With Quote
Vararam Ram Air V tjd24 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 58 08-22-2009 06:55 PM
RAM AIR TRANS AM FOR SALE. KITT3K Autos For Sale / Wanted 9 05-28-2009 11:39 AM
Ram air kits ? danraz98 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 05-24-2009 02:10 PM
A FAKE SCOOP??!! ARE YOU KIDDING ME??!! MotorCityAgent 5th Gen Camaro SS LS LT General Discussions 222 03-01-2009 08:17 AM
ram air style hood? tsg1391 Cosmetics and Lighting Modification Discussions 1 10-23-2008 05:43 PM
