Emblempros
Old 06-17-2009, 03:30 PM   #1
CmB
OMG Bumblebee!! UM NO!!
CmB's Avatar
Drives: IMO 2SS RS LOADED!
Removing the interior panels
Anyone have information on how to remove the door inserts. I want to swap out the LEDs and dont want to just rip off the panels. Also the dash panels as well. Thanks,
CmB is offline   Reply With Quote
Old 06-28-2009, 01:11 AM   #2
Camaro Insider
Camaro Insider's Avatar
Drives: chevy..what else?
I KNOW YOUR DOOR PAD IS HELD DOWN WITH A FEW DIFERENT SIZE TORQES SCREWS AND A FEW PHILLIPS SCREWS AROUND THE PERIMITER OF THE THE PAD AND I BELIEVE THERE IS ALSO WHATS CALLED A "MONSTER CLIP".THESE CLIPS CAN BE A TRICKY.THE REST OF YOUR DOOR PAD IS HELD ON WITH A PLASTIC CLIP.IF YOU DECIDE TO REMOVE THE DOOR PAD YOU MAY REQUIRE A TOOL TO REMOVE THESE CLIPS THEY REALLY ARE'NT MEANT TO BE REUSED TO MANY TIMES IF AT ALL.I LIKE TO DO MT OWN STUFF TO BUT I WOULD RECOMMEND TAKING IT TO YOUR DEALER IF YOU'VE NEVER REMOVED ON BEFORE THEY CAN BE TRICKY AND IF YOU DAMAGE THE MOUNTING HARDWARE YOU MAY BE PARKED A WHILE. HOPE YOU LIKE DRIVING IT AS MUCH AS WE DID BUILDING IT
Camaro Insider is offline   Reply With Quote
Old 06-28-2009, 01:15 AM   #3
Camaro Insider
CAN YOU BE MORE SPECIFIC ABOUT WHICH DASH PANEL YOUR TALKING ABOUT
Old 06-29-2009, 12:56 PM   #4
CmB
CmB's Avatar
I want to take off the color panels in the doors and replace the led behind them with a brighter one. I have heard I have to take off the entire door panel so I am going to try that this weekend.
Old 07-02-2009, 08:05 AM   #5
camarorick
camarorick's Avatar
Drives: .
Could you post some pics if you do remove anything... TIA
camarorick is offline   Reply With Quote
Old 07-13-2009, 10:04 PM   #6
ozman2005
#8504
ozman2005's Avatar
Drives: 2016 Camaro 2SS
+1
Did you end up getting the plastic panel off?
2016 Camaro 2SS Hyper Blue, A8, NPP
Past:
2010 Camaro 2SS/RS M6, Silver Ice Metallic w/ Cyber Gray Rally Stripe package, Inferno Orange interior, factory "perma-grin"
VIN: 2G1FT1EW1A9108504
Delivered 7.7.09
ozman2005 is offline   Reply With Quote
Old 09-28-2009, 04:56 PM   #7
aldaran
aldaran's Avatar
Drives: 2016 Camaro 2SS/RS
I guess this fell through.
aldaran is offline   Reply With Quote
Gained HP from removing mufflers. +17hp (with dyno) lawdogg149 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 26 06-16-2009 03:14 PM
Removing CAMARO lettering jdanza Cosmetics and Lighting Modification Discussions 9 06-05-2009 09:19 PM
Removing Dealer sticker/decal from the Camaro? VictoryRed08 5th Gen Camaro SS LS LT General Discussions 25 04-13-2009 10:08 PM
Removing Badges Shurenuff 5th Gen Camaro SS LS LT General Discussions 29 02-09-2009 12:42 PM
Removing the Cats? ctk1 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 55 12-27-2008 10:59 PM
