Caryle Racing
Old 02-26-2013, 03:44 PM   #1
R8cerX
R8cerX's Avatar
Drives: 2010 CamaroSS
Modern Muscle (Va.) ported TB tested on dyno
Just wanted to give out some great news. I base lined my Magnacharged 10 Camaro SS, then installed a Modern Muscle (Va.) ported throttle body. The gains speak for themselves...just check out the graph below. The throttle response is sooooo much better/quicker than with the stock throttle body.
Just so everyone knows, we did NO tuning before or after the install. We tried to keep everything the same temp wise. The car baselined a little lower than the last time it was on the dyno, which doesn't really matter as far as what the gains from the TB were. The highest number the car ever made was 595rwhp with everything optimized...perfect weather, car cooled down completely, etc, etc.
Due to time constraints, we put the car on the dyno "hot" made a pull for the base line, swapped the TB (3 minutes) and made another couple of pulls.
Frank
10 Camaro Magnacharged- 595rwhp/585rwtq, full exhaust, Pedders Justice/ZL1 sway, Stoptech brakes and 21" 3 Pc. Forgeline wheels
99 Corvette- 497rwhp/490rwtq-402 N/A, 6pis/4pis brakes...fun track car/daily driver
2010 Camaro 2LT/RS...257rwhp/234rwtq SLP CAI and IAT relocated, Eibach springs and Flowmasters
R8cerX is offline   Reply With Quote
Old 02-26-2013, 05:44 PM   #2
1989GTA
Drives: 1989 GTA Trans Am
So, what I take from this is the more modified or better breathing the car is the more effective a ported throttle body becomes. 25hp is quite an improvement.
1989GTA is offline   Reply With Quote
Old 02-26-2013, 05:48 PM   #3
SUKXOST
Do you even lift, bro?
SUKXOST's Avatar
Drives: 2013 1LE Camaro
My 1LE (645WHP/597WTQ) build/journal Thread:
1st ever 1LE COTW http://www.camaro5.com/forums/showthread.php?t=255461
SUKXOST is offline   Reply With Quote
Old 02-26-2013, 05:49 PM   #4
Supercharged SS
Drives: 2010 Camaro
You will never see anything close to 25 rwhp on a N/A car.
Is the ported tb the same size as the stock one? Only ported?
Old 02-26-2013, 05:51 PM   #5
Supercharged SS
Drives: 2010 Camaro
LS3 car?
How many psi?
Any other mods?
Old 02-26-2013, 05:54 PM   #6
DuskSS
Bayou City Muscle Cars
DuskSS's Avatar
Drives: 2013 2SS Dusk Edition
I dunno lethal swears that a ported intake and tb work very well in conjunction with other mods.
On other cars ported tbs and mafs gave good upgrades.
Sent from my SPH-L900 using Tapatalk 2
Lethal Racing Stage V
PER 418ci Forged LS3
530/520 SAE
DuskSS is offline   Reply With Quote
Old 02-26-2013, 05:57 PM   #7
Supercharged SS
Drives: 2010 Camaro
It's debatable what gains you'll get on a n/a. Some will say none and the others will say 5-10. No more than that. A ported tb is more about throttle response. A pd blower car is different but it needs to be bigger. Just ported a tb on a pd blower car and gaining 25rwhp is suspect. I gained 25 rwhp with a 102mm tb. Much larger than a ported stocker.
Old 02-26-2013, 07:28 PM   #8
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
Well any restriction you can remove in front of a positive displacement supercharger will show gains and even some boost increase. IDK about 35lbs of torque and 25RWHP though. That seems like alot for a 90mm TB.
Old 02-26-2013, 07:37 PM   #9
Supercharged SS
Drives: 2010 Camaro
That's what I'm thinking........
Old 02-26-2013, 08:35 PM   #10
429
Drives: 2010 camaro ss
looking at the dips on the graph, that car has some serious tune/kr issues.
429 is offline   Reply With Quote
Old 02-26-2013, 08:43 PM   #11
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
I agree to all, this is the second time they've posted a suspect dyno graph.
Old 02-26-2013, 09:43 PM   #12
David Weber
David Weber's Avatar
Drives: Walk to work
Hi guys this is Dave Weber from Modern Muscle. The TB results are what we get back from customers and that is all. The post made of the NA dyno run also shows a fair amount of torque increase and the peak number was in line with what you would expect (10-13 peak). All I can say is NA was tested in Germany and boosted in Virginia Beach. The one in Virginia Beach was already a second design. We have been porting heads for about 30 years and throttle bodies for about 7 years. This is our first attempt at the GM line. We do try to listen to all customer input and continuously improve our product. We will keep posting as we get feedback.
David Weber is offline   Reply With Quote
Old 02-26-2013, 09:55 PM   #13
Supercharged SS
Drives: 2010 Camaro
Where's Bo White when you need him? Does he have a beacon or something like Batman that'll draw him to this thread?
Old 02-26-2013, 10:37 PM   #14
BFASTNOTLAST
BFASTNOTLAST's Avatar
Drives: 2012 SS LS3
From a business perspective one would think if a company trying to break into the GM line like you said, would take it upon themselves to provide the most data and several tests (Dyno, Track) before the outrageous claims of one car. Seriously, I understand your in the business to make money but to enter the C5 forum with far fetched claims especially the NA car a month ago or so really turns people off. You have been in business and porting heads for thirty years, maybe it's just me but I would have expected more out of an introduction rather than going off what a customer claims on his own.. Facts and data speaks volumes. So on a side note all the NA guys should be able to put a 102TB on their cars and expect more than what you claim. Pretty sure the 102 doenst do much for a NA car and for sure not nearly as much on a stock car. In the end your first claim was dynoed at an "Independent shop" with a gain of 13hp and 17tq. Its a safe assumption that a 102 would make atleast 20 right? If that was the case there would be a lot more of them out there no matter how much they were. So, now that I'm done ranting and raving in the end all the camaro owners or who ever for that matter will spend their money on the go fast fix, but when it seems unrealistic the red flag goes up and they wont buy. I get it, there is an ass for every seat and some will bite for the sales claim but most will probably say
I said to much as it is, much luck in your quest. Sorry if I offended anyone, it's been one of those days.........
BFASTNOTLAST is online now   Reply With Quote
ported throttle body, supercharged camaro
