Caryle Racing
Old 02-26-2013, 07:30 PM   #1
Jer4251
Camaro Addict
Jer4251's Avatar
Drives: too many
10' LS3 exhaust on 13' Z Vert
Well i went ahead and removed the stock exhaust from my 2013 Z vert. And put on my stock 2010 SS exhaust with a muffler delete setup and quad 4" tips. Only small issue with this setup is the pass side pipe is really close, bumping, the rear diff. Maybe a wack or two with a BFH will do the trick, test drove it and didnt hear it making any noises so it may be good as is. Sounds better than the ZL1 exhaust if you ask me. but still needs some longtubes to sound perfect
its this setup with both resonators but with 4 tips
2013 ZL1 Vert
1990 IROC-Z Vert
1996 SS Vert #1468
1991 Z28
2014 Sierra Denali
Jer4251 is offline   Reply With Quote
Old 02-26-2013, 08:47 PM   #2
Jer4251
Camaro Addict
Jer4251's Avatar
Drives: too many
sorry for the crappy pics, ill get som better ones in the day light. and a sound clip, drivers side needs adjusted a smidge. its closer to the heat shields than the other side,. also didnt run heat shields on my SS with this, wasnt sure how the fit would be with these tips
came off of this car
2013 ZL1 Vert
1990 IROC-Z Vert
1996 SS Vert #1468
1991 Z28
2014 Sierra Denali
Old 02-26-2013, 11:57 PM   #3
Trackman
Trackman's Avatar
Drives: 67RS Camaro ,Black 2013 ZL1
Trackman is offline   Reply With Quote
Old 02-27-2013, 12:32 AM   #4
Jer4251
Camaro Addict
Jer4251's Avatar
Drives: too many
I didnt care for the sound of the dual mode exhaust (already pulled the fuse). Im not getting rid of it, it will stay in storage. once i install my longtubes ill test both out again to see what one sounds better
2013 ZL1 Vert
1990 IROC-Z Vert
1996 SS Vert #1468
1991 Z28
2014 Sierra Denali
Old 02-27-2013, 06:12 AM   #5
toyosuprablue
Drives: 2013 ZL1 Black M6
Good amount of weight saving im sure, even though its from the one part of the car we don't mind alittle extra weight
toyosuprablue is offline   Reply With Quote
Old 02-27-2013, 10:32 AM   #6
Jer4251
Camaro Addict
Jer4251's Avatar
Drives: too many
still a lot of weight savings. those mufflers were heavy. my delete setup i can carry one handed
2013 ZL1 Vert
1990 IROC-Z Vert
1996 SS Vert #1468
1991 Z28
2014 Sierra Denali
