Rick@Livernois
Old 02-26-2013, 11:26 PM   #1
the barber
the barber's Avatar
Drives: 13' Sw 2ss Ls3
160 degree thermostat
What are the benefits of installing one of these, don't know much about this one..
the barber is offline   Reply With Quote
Old 02-26-2013, 11:36 PM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
This has been discussed NUMEROUS time. A simple search would have given you your answer.
http://www.camaro5.com/forums/showth...ree+thermostat
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 02-26-2013, 11:43 PM   #3
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
Your going to cause a huge debate with this one. The benefit is to try and keep your car cooler for longer. It opens at 160 degrees and starts cooling the motor sooner. The hotter your coolant the more timing will be taken out resulting in less power. I think eventualy the motor both stock and 160 T-stat will end up at the same temp and timing retard, its just a question of how long it takes to do it. This is good for drag racing after a cool down because while in the staging lanes the cars coolant is circulating sooner. I have 1 in my car. 50 percent of shops recommend it and the other half dont. I think this is one of those debates that will never be resolved.
Old 02-27-2013, 12:23 AM   #4
BigBlock69RS
Ed
BigBlock69RS's Avatar
Drives: 2013 AGM Camaro 2SS/RS/1LE
It's mostly a kludge around cooling issues. Really all you are doing it making the engine take longer to get up to temp. If you have cooling issues you should address them.
It actually can damage the engine if you drive short distances constantly and the 160* thermostat prevents the car from ever getting up to temp and burning off the sludge in the oil.
If you drive long distances or distances long enough to come up to temp even with the 160, then really only adds extra wear with all your engine tolerances out of spec since the car takes longer to warm up.
Ask yourself this if coming up to temp fast didn't matter why do cars have thermostats at all? Why not just run the cooling system full blast from engine startup? That will obviosly result in lowest coolant temp for longer...
BigBlock69RS is offline   Reply With Quote
Old 02-27-2013, 03:59 AM   #5
the barber
the barber's Avatar
Yet a simple search is can not b done on my mobile device. If I found the answer I would not have asked
Only reason I asked was because I'm about to order a CAI and the company I'm ordering from has a couple "free items" to choose from one was this thermostat
Old 02-27-2013, 04:01 AM   #6
the barber
the barber's Avatar
Since I do not track the car or drag it, yet, I think its definitely not worth installing for now thanks for ur guys inputs really helps out alot
Old 02-27-2013, 11:03 AM   #7
SPCBA
Drives: pleather and Chiclets
i dont think its worth it anyways. if you have cooling problems get a better rad and fans.
SPCBA is offline   Reply With Quote
Old 02-27-2013, 11:10 AM   #8
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1951 Mercury
Can't speak for drag racing, but it's one way to have the car cool down faster between passes at the drag strip. An electric water pump would better but I don't run one of those in a daily driver.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 02-27-2013, 11:11 AM   #9
presholt33
Drives: too numerous
Does anyone have a GM part # for the 160 for a ls3?
presholt33 is offline   Reply With Quote
Old 02-27-2013, 11:13 AM   #10
SPCBA
electric pumps scare me haha i am not a professional driver and would never have one of those on any of my cars
Old 02-27-2013, 01:58 PM   #11
Pro Stock John
Writer
Me too.
PROJECT HEAVY CHEVY
Old 02-27-2013, 02:13 PM   #12
akCamaross
akCamaross's Avatar
Drives: 2011 Camaro 2SS
radiator, fans, cowl hood or some type for ventilation should really help you out. And those dont damage the engine.
2011 Camaro 2SS - SIM - M6 + Mods haha
akCamaross is offline   Reply With Quote
