HeadlightArmor
Old 06-17-2009, 05:03 PM   #1
paulv7260
Drives: 2010 Camaro 2SS/RS SIM L99
Time for a tune-up?
A couple of issues:
1. When I start er up and rev there is a mild backfire, not loud but more distinct than a cough.
2. Decelerating then cruising at 1500 RPMS there seems to be a lot of lag and what I think are vibrations coming from the chassis.
3. Car runs smoothly but at idle the lope is noticeable especially under my seat. To be expected with the L99?
860 miles on her. Thoughts from the experts before I take her in? I'm also waiting for the clip to fix the A pillar pop-out problem (its on backorder). Think I can wait until then?
Thanks
Paul
2SS/RS SIM, L99, Black Interior, Sunroof, Polished 20's
Ordered 11/29/2008
Delivered 06/05/2009
VIN 2G1FK1EJ2A9111158
paulv7260 is offline   Reply With Quote
Old 06-17-2009, 05:40 PM   #2
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
I don't think it needs a tune. Sounds like it has issues. Take it to the dealer asap!
Old 06-17-2009, 05:56 PM   #3
MONEY
Black 2ss/rs Mid-August
MONEY's Avatar
Drives: 1999 Silverado, 1978 Corvette
BLACK 2SS/RS INFERNO ORANGE INTERIOR (Ordered 6-10) ....... Pratt & Whitney J58 Jet Engine On Order, (Swap Details Soon!)
MONEY is offline   Reply With Quote
Old 06-17-2009, 06:42 PM   #4
paulv7260
Originally Posted by MONEY View Post
OK, thanks. Making the appointment for ASAP.
Paul
Ordered 11/29/2008
Old 06-17-2009, 06:44 PM   #5
1320junkie
Drives: The Imperial Army
I think its fine..let us know the outcome please
Old 06-17-2009, 06:50 PM   #6
paulv7260
Will do ...
Ordered 11/29/2008
Old 06-17-2009, 07:20 PM   #7
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
Originally Posted by paulv7260 View Post
A couple of issues:
Thanks
Paul
1. how soon after starting it up are you reving it? during startup the engine runs extra rich. reving soon after startup is liable to cause some backfiring as there is excess fuel not being burnt.
not to mention, reving it too soon after engine start is not a good idea to begin with as you are putting excess strain on the motor before the oil gets a chance to circulate thruout.
2. what gear are you in when you are cruising at 1500rpm? try down shifting a gear. then again, you are in the auto.... and when you are cruising, it most likely is switching to 4 cyl mode.
3. let her break in some more.
you can wait on the A-pillar. its cosmetic.
I piss excellence
and fart awesomeness
Old 06-17-2009, 08:27 PM   #8
paulv7260
I first noticed the "backfire" using the remote start so I tried a normal key start followed by a little throttle. Same effect but it is inconsistent. I cannot hear the sound after warm-up but honestly I'm not 100% certain on that.
Its the auto tranny. I haven't even tried the tap shifters yet. If it is AFM then fine but the vibration I feel seems unnatural. A tap on the accelerator and it goes away. No hint of a stall.
That would be easier for me if I could wait to get the A pillar fixed at the same time. I expect the dealer to call me back tomorrow and I'll suggest that.
All-in-all I have no complaints. I love my Camaro. Heck, EVERYONE loves my Camaro
Thanks!!
Paul
Ordered 11/29/2008
Old 06-17-2009, 08:57 PM   #9
CamaroSpike23
Truth Enforcer
Paul
a lot of cars tend to "bog down" at lower rpms. mainly cus you arent spinning the motor much above idle and you arent making much power. add into that that the l99 switches to 4cyl mode when cruising and the slight bog down/vibration is just that of the 4cyl motor pushing a 4000lb car.
I piss excellence
Old 07-17-2009, 01:49 PM   #10
paulv7260
A couple of issues:
Thanks
Paul
I promised an update when I had this stuff looked at so here it is:
OK, waited for break-in to go to the dealer. Did that yesterday with 2300 miles on her. I was really lucky because the mechanic that looked at my car also owns a 2010 L99 SS AND he is a tranny specialist.
On item 1 he says it is normal as the start-up mixture tends to be rich and leans out as the engine warms. Unless GM does a new program that's the way it is.
On item 2 he says it too is normal and his car does it too. He chalks it up to the program trying to conserve as much fuel as possible.
Item 3 is normal and I figured that out long ago so I didn't ask the mechanic.
The A-pillar fix was done weeks ago.
Paul
Ordered 11/29/2008
Long time tunring over TJ91 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 10 06-19-2009 09:30 PM
Okay Camaro5 Family - Time to help Emjay!!!! Emjay 5th Gen Camaro SS LS LT General Discussions 328 05-22-2009 02:40 PM
Time Is Right for a Sleek, Fast, New Camaro -WalletPop camaro5 5th Gen Camaro SS LS LT General Discussions 22 02-03-2009 06:41 PM
GMPP LNF Tune The_Blur General Automotive + Other Cars Discussion 22 01-07-2009 05:57 PM
will dealer tune after gmpp header/intake/cat? s.norman 5th Gen Camaro SS LS LT General Discussions 4 11-03-2008 09:23 PM
