Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Wash/Wax/Detailing and Cosmetic Maintenance Parts
Old 02-27-2013, 02:28 PM   #1
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
PRESALE: Adam's NEW Deep Wheel Cleaner
A SPECIAL PREORDER OFFER FOR OUR FORUM MEMBERS
Adam's Deep Wheel Cleaner is probably one of our most anticipated launches this year,
so we wanted to give our loyal forum customers the first chance to jump on it!
All orders that include Deep Wheel Cleaner or the New Trim & Lug Nut Brush begin shipping by Monday March 4th.
As a PreOrder Special Bonus - Use the code PRESALE1 to take 10% off your order
Plus get $5 flat rate shipping anywhere in the continental US
And orders of $50 or more will receive TWO FREE Edgeless Utility Towels!
NEW Deep Wheel Cleaner Special Introductory Price! (click the image to order)
Adam's Deep Wheel Cleaner is the ultimate way to remove stubborn brake dust and metallic contamination from your wheels. The thick formula clings to wheel surfaces and allows the european derived formula to melt away the stubborn brake dust commonly left behind by many of todays high-performance braking systems. The color changing formula lets you know its working, turning to a deep purple as it activates and does the hard work for you.
Best of all Adam's Deep Wheel Cleaner is safe for all wheel finishes. So whether you have factory clear coated wheels, aluminum, powder coat, or paint the highly effective cleaning solution will remove the stubborn brake dust, but will never harm your wheels.
With active cleaning agents and advanced surfactants the formula is perfect for cleaning away the worst, most baked on brake dust commonly found in the barrel of your wheels. Simply spray on, allow the cleaner to activate, and then agitate using one of Adam's Turbo Sticks or Wheel Woolie Wheel Cleaning tools (sold separately).
Adam's Deep Wheel Cleaner is great for more than just wheels too! Have a light colored paint job like white or silver? Then you've no doubt noticed the little orange iron particles that stick to your paint. Adam's Deep Wheel Cleaner can be sprayed on these little trouble areas and used to dissolve the iron from these surfaces as well.
Adam's Deep Wheel Cleaner is guaranteed to be the best wheel cleaner you've ever experienced!
NEW & IMPROVED TRIM & LUG NUT BRUSH (click the image to order)
Sometimes the right tool for the job makes all the difference, and this is a tool you'll need to get the job done right. Use it with soap and water to clean around badges, inside door jambs, under the hood, your lug nut holes, or even your brake calipers. It's a versatile tool backed with the Adam's 110% money back guarantee!
Our newest Trim & Lug Nut Brush uses the same super soft boars hair as our previous brush, but now set in a completely metal free design with a longer tapered handle thats more comfortable and more durable than our previous version. It works amazing with our NEW Deep Wheel Cleaner to get that hard to clean brake dust out of the hard to reach areas.
To ensure it withstands years of use with cleaning products and water the bristles are set in a completely chemical resistant epoxy, secure set in a the tapered plastic handle, the top of the brush head is then cut to a slight curve to allow easier access into tight spaces around lugs nuts and other wheel crevices.
The 7.5" long handle makes this brush extremely comfortable to work with and the 2.5" long bristles make this the ideal tool to clean away without ever scratching delicate surfaces. When its not cleaning wheels the Adam's Trim & Lug Nut Brush is the ideal way to clean around badges and emblems. Simply dunk in your wash bucket or spray a liberal amount of Detail Spray into the area to clean and gently agitate the area.
Adam's Trim & Lug Nut Brush has great uses around the interior of your car as well. Use it to clean around radio control knobs, door switches, or anywhere those tiny bits of dust and crumbs want to hide. You'll find dozens of uses for this effective cleaning tool all over your car that will not only make your detailing easier and more effective, but more enjoyable too.
CHECK OUT OUR CLEANER & BRUSH COMBO, DEEP CLEAN TIRE & WHEEL KIT,
or DELUXE DEEP CLEAN TIRE & WHEEL KIT FOR EVEN BIGGER SAVINGS!
For More on The NEW Deep Wheel Cleaner or NEW Trim & Lug Nut Brush watch our latest video
Adam's Polishes is online now   Reply With Quote
Old 02-27-2013, 06:36 PM   #2
Adam's Polishes
Guys, I spent the day in the warehouse yesterday when we were filming the video and I attest that this stuff is INCREDIBLE!
Not shown in the video is a Mini Cooper we had to mess with for a while that had 8 months of caked on brake dust on the front wheels. We used the Deep Wheel Cleaner on it and it just melted it away like it was nothing. Pretty wild!
Old 02-27-2013, 07:07 PM   #3
Sapper12b
HTCC Member
Sapper12b's Avatar
Drives: 2013 Camaro SS
How does it affect painted calipers ?
Sapper12b is offline   Reply With Quote
Old 02-28-2013, 10:09 AM   #4
Adam's Polishes
It's safe for all finishes since it's pH neutral, but it would still be a good idea to try in a small test area to make sure.
It's been tested on polished aluminum, which is about as finicky as it gets, with no ill effects.
As with any wheel cleaning product, always remember to never apply to a hot wheel and don't let it dry on the surface and you'll be good to go!
Old 02-28-2013, 07:20 PM   #5
Jeffm
ICANHAZ
Jeffm's Avatar
Drives: 2013 CRT 1SS/RS
what about Matte Black rims.
Jeffm is offline   Reply With Quote
Old 03-01-2013, 06:59 AM   #6
Twilborne
Twilborne's Avatar
Drives: 2013 Blue Ray Blue 2LT
I ordered a bottle of this. Then I watched the video. If i have to scrub it with a brush like it shows I can do that with soap and a rag. We will see.
Twilborne is offline   Reply With Quote
Old 03-01-2013, 08:09 AM   #7
Adam's Polishes
I think you'll find this much more effective than soap and a rag.
It's a purpose-built formula that's made to remove heavy metallic brake dust and metallic-based contaminants without the need for heavy scrubbing...which is never good for the finish on your wheels.
Old 03-02-2013, 04:33 PM   #8
Al C.
Al C.'s Avatar
Drives: ZL1 #529 "El-Jefe"
What's the difference in your product than the other European "wheel cleaners" that do the exact same thing, i mean this technology isn't new.. Not tryin to put u guys down but I can name 2 off the top of my head that do the same.
Al C. is offline   Reply With Quote
Old 03-03-2013, 10:45 AM   #9
Adam's Polishes
Great question!
Two of the biggest differences will the price point we will come in at and the smell, or lack thereof.
Some of the similar cleaners currently on the market will curl your nose hairs when agitated. Ours has undergone many, many reformulations in an effort to avoid that trait, and I think we nailed it.
Smells like cherries when applied, then gives off a very slight odor when agitated. Compared to some others, it's a night and day difference.
Plus it carries a 110% guarantee.
Old 03-03-2013, 11:49 AM   #10
Al C.
Al C.'s Avatar
Originally Posted by Nick@Adams View Post
Great question!
Gotcha..
Old 03-03-2013, 12:04 PM   #11
GB EB
GB EB's Avatar
Drives: 2014 Stingray 2LT/Z51
If I add additional items will I get 10% and 5 buck flat rate shipping for entire order?
*CAMARO5 CAMARO OF THE WEEK 3/21/11*
*1ST PLACE - NAVAL STATION SAN DIEGO CAR SHOW 4/17/11*
*PEOPLE'S CHOICE AWARD - SAN DIEGO FREEDOM FESTIVAL CAR SHOW 7/4/11*
*TROPHY RECIPIENT - GREATEST SHOW ON TURF 9/11/11*
*1ST PLACE MODERN MUSCLE - CORONADO SPEED FESTIVAL 9/23/11*
*AWARD OF EXCELLENCE - GOOD GUYS DEL MAR FALL NATIONALS 11/27/11*
*1ST PLACE / '82&UP CAMARO/FIREBIRD- FORT WALTON BEACH FF SHOW 2/16/13*
BUILD THREAD: http://www.camaro5.com/forums/showthread.php?t=120353
GB EB is offline   Reply With Quote
Old 03-03-2013, 06:31 PM   #12
Adam's Polishes
Yep. :flag2:
Old 03-04-2013, 12:30 PM   #13
zcorvette04
zcorvette04's Avatar
Drives: 2012 Chevrolet Camaro 2SS/RS
Can Adams ship to an APO? Man I hope they can
zcorvette04 is offline   Reply With Quote
Old 03-05-2013, 10:38 AM   #14
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: CGM w/Black stripes
along with removing brake dust, will it remove hard water spots on painted rims?
BMR Suspension, SLPTVS2300, GFORCE Driveshaft & HalfShafts, Kooks with cutouts and other fun things.
