sjm autoprod
Old 02-27-2013, 05:34 PM   #1
Chevrolade
Drives: 2010 2SS/RS
l99 to ls3 conversion need help
I need to know on the new valley ls3 cover there's a nipple at the very front of it I don't know where to run it
Chevrolade is offline   Reply With Quote
Old 02-27-2013, 08:09 PM   #2
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
Are you running a catch can? If not it there is a short plastic pipe you will need. It connects to the intake manifold, right side just behind the throttle body.
The PCV hose routing is different between the L99 and LS3.
LSX Camaro is offline   Reply With Quote
Old 02-27-2013, 08:42 PM   #3
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
I'd run a catch can, LsX's have had a poor Pcv design since 1998!
Old 02-27-2013, 08:54 PM   #4
Motion427
Drives: 2010 2SS/RS Red Jewel L99
When I did my L99 to LS3 conversion.I just used a plug.(actually it was with the valley cover)
I'm still running the L99 PCV system routine.
Motion427 is offline   Reply With Quote
Old 02-27-2013, 09:31 PM   #5
rahallfly
rahallfly's Avatar
Drives: 2010 2SS/RS
the kit should have came with a little rubber line that looks like a U and plugs into intake. when u hold the hose up that looks like a U there is only one place it will go. And Yes if you go with a catch can this is where it goes!!
TSP VVT2, OBX LTs Catless mids, Flowmaster, Half K&N, Half Fastlane Pipeline CAI, Tuned by RDP Motorsports! Thats the main fun adders
SHAKE ANNNNNNND BAKE!!!!!
rahallfly is offline   Reply With Quote
