Solo Performance
Old 02-27-2013, 06:09 PM   #1
BossHogg
Mexican SS
BossHogg's Avatar
Drives: Black 2SS/RS
** Rear Camber Kit **
I dont know if i can wait until April 1st or longer for Pedders to get more of the " Rear Camber Kits " they are out of stock just my luck..... Both tires are leaning in at the top and im really scared to take any kimd of road trip because im gonna eat the inside of the tires up....... But idk just seems as though im gonna have to wait it out ughhhhhhhhh.........
Black 2010 2SS/RS...
Dyno Tune..
Volant Cold Air Intake..
Custom Installed Escort 9500 Ci Radar
Smoked Tail Lights-Reverse Lights -Front/ Rear Corner Lenses
Painted Bow Ties front & rear
Pacesetter Long Tube Headers
Magnaflow Competition Cat Back Exhaust....
Eibach Pro Lowering Kit
Painted Heritage Grille
1969 Camaro Emblems
Phoenix Gold I-Amp Sound System
22 inch Replica Wheels:
VMAX Ported Throttle Body
BossHogg is offline   Reply With Quote
Old 02-27-2013, 06:54 PM   #2
sting808
Drives: 2010 SS RS
Try contacting Raymond's Performance, a sponsor on this site. Or Wretched.
After 3 years, my camber bolt was stripped and couldn't tighten at alignment shop. I got my rear camber eccentrics from Raymond's last month. He had them in stock. I believe they're in Indiana.
sting808 is offline   Reply With Quote
Old 02-27-2013, 07:01 PM   #3
BossHogg
Mexican SS
BossHogg's Avatar
Can u pm me a cost on it, i wonder if its the same as Pedders?
Dyno Tune..
1969 Camaro Emblems
Old 02-27-2013, 07:09 PM   #4
Synner
Drives: not stock
Your rear camber is that far off? What is it set at and when was your last alignment? Seems odd you can't get it to a reasonable number.
Synner is online now   Reply With Quote
Old 02-27-2013, 09:19 PM   #5
BossHogg
Mexican SS
BossHogg's Avatar
My alignment was last week, the car is dropped with Eibach springs and they have the camber in the rear maxed out... It's supposed to be -.040 and its -1.2.....
Dyno Tune..
1969 Camaro Emblems
Old 02-27-2013, 11:10 PM   #6
Rob@WretchedMS
Drives: His Wife Crazy
Boss, I believe i have 1 set of rear camber bolts left, as well as front camber adjusters. Let me know if i can help.
Rob@WretchedMS is offline   Reply With Quote
Old 02-27-2013, 11:14 PM   #7
BossHogg
Mexican SS
BossHogg's Avatar
Can u pm me the info.... 70605
Dyno Tune..
1969 Camaro Emblems
Old 02-27-2013, 11:15 PM   #8
BossHogg
Mexican SS
BossHogg's Avatar
I'm cool on the fronts it's the rears that's off...
Dyno Tune..
1969 Camaro Emblems
Old 02-27-2013, 11:25 PM   #9
Rob@WretchedMS
The front camber bolts do not allow any more adjustment, as there is already sufficient adjustment up front already. What they do however offer is they make adjusting the camber much easier and allow you to much more accurately set the camber to the exact setting that you want.
pm sent.
Old 02-28-2013, 08:05 AM   #10
jeremywes
jeremywes's Avatar
Drives: 2012 Camaro SS
You should have more than enough adjustment in the stock rear eccentrics. I have the Pedders alignment kit but could go from 0 to -2.2 with OEM setup.
jeremywes is offline   Reply With Quote
Old 10-22-2013, 04:26 PM   #11
Bradstracks.com
Drives: 2013 Hot Wheels Camaro
I only lowered my Camaro 1", and I have an issue with rear cmaber too. Even with the camber cams turned all the way in, the rear camber is 1.3º.
Bradstracks.com is offline   Reply With Quote
Old 10-22-2013, 04:29 PM   #12
Rob@WretchedMS
the stock adjusters only allow a certain amount of movement, the Pedders bolt kit allows full movement and will get you the results that you want.
Let me know if you are interested and i will get you pricing, etc.
